12-11-2016, 02:15 PM | #1 |
Rep 780
14 m235i overheat/ coolant explosion under hood
Driving home got a low coolant warning.
Checked temps and all was good (torque app). Popped the hood and coolant explosion. I mean coolant everywhere. And does not hold any more I add. What the hell is going on???
2014 AW M235i Sold
2013 BLK GT500 track pack/ perf pack/ recaros |
12-11-2016, 03:12 PM | #3 |
Rep 780
I looked around the reservoir and saw nothing, with the sheer spray and velocity maybe a coolant hose?
12-11-2016, 04:53 PM | #5 |
Rep 780
Fabspeed Motorsport1005.50 LeeLong9.50 |
12-11-2016, 07:01 PM | #7 | |
Rep 780
Gonna plead to get a loaner from my normal dealer or else I'm screwed on to driving 2 hours up Tuesday to try to get one. |
12-11-2016, 07:18 PM | #9 |
Rep 780
12-11-2016, 08:02 PM | #10 |
Rep 647
that sux, i know, i just cleaned my engine bay due to oil filter cap seeping and landing on the serpentine belt... for miles ! Left a nasty mess... good luck hope they sort it soon.
12-11-2016, 08:14 PM | #11 |
Rep 780
I'm pretty optimistic it'll get sorted, the logistics are just a bit more stretched than I'd like hah.
12-11-2016, 08:27 PM | #12 |
Rep 3,256
12-12-2016, 05:56 AM | #14 | |
Tea wot?
210
Rep 271
Remember that when coolant is under pressure, the boiling point increases well past 100C, you open the lid when under pressure and all of a sudden you have pressurised coolant at 120C spraying everywhere. Second it would probably be worth pressure testing the system when cold to see if you can identify the source of the leak. If no leak is evident then carry out a sniff test on the coolant reservoir, this tests for combustion gases in the coolant, i.e. headgasket failed between coolant channels and combustion chambers. Sniff test demo It would also be worth checking the oil for any mayonnaise, i.e. headgasket failure between oil and coolant channels in the head. |
12-15-2016, 04:13 PM | #15 |
Rep 780
So it was a coolant hose that slipped off a clip apperently. Good news for me.
Also got a Mini as a loaner so that's cool. |
12-15-2016, 04:36 PM | #17 |
Rep 780
Still a bit fuzzy but I think a hose detached entirely
12-15-2016, 06:22 PM | #19 |
Rep 780
Ill ask a bunch more questions when I go pick it up but yeah I'm thrilled it wasn't anything major, I have some minor concerns that temperatures may have been high but I never read above 230F...
12-19-2016, 03:55 PM | #20 |
Rep 190,924
Same thing happened to my 335 last week
Fan stopped working, one of the coolant lines exploded, coolant and smoke were everywhere For a second i thought i lost the engine
12-22-2016, 09:09 PM | #21 |
Car Enthusiast
282
Rep 501
I'm going to take a guess from experience and say it was one of the coolant hoses coming off of the Coolant pump.
If the vehicle ran low on coolant - like nothing in the system...but the ignition was still left on, there is a good chance the Coolant pump is damaged as well. That being said, with your car at the dealer im sure everything will get fixed properly Interested in hearing what the cause was tho |
12-26-2016, 11:12 AM | #22 |
Rep 780
Turned out a hose sipped out of a clip and layed across a belt that rubbed a hole in it- the pressure through the small hole is what propelled the coolant across the engine bay I guess ☺️
