04-18-2015, 10:09 AM | #1 |
Resident BMW Fanboy
259
Rep 866
Hey guys, is there anyway to disable the hill hold assist through coding? When I got my car coded in January my coder said it was not. It's incredibly intrusive and I'm sitting on the clutch for way too long before it releases the brakes...if I didn't want the car to roll back on a hill I would have ordered an automatic one...
Thanks, Dave
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
04-18-2015, 12:27 PM | #2 |
Rep 3,331
Not sure about the 2, but I know in Subaru's the hill holder was a mechanical valve not an electronic control.
Just got back from driving around Europe in a Fiat 500 which has a hill hold feature but it only lasts for a split second and you could feel it let go awkwardly when letting the clutch out.
Current: '20 X5, '18 M3 ZCP
04-18-2015, 01:30 PM | #3 | |
Resident BMW Fanboy
259
Rep 866
04-18-2015, 01:35 PM | #4 |
Rep 757
I'm not exactly sure what you mean by already on the clutch.. I know you mean pressing down. But why. Unless it's time to go. Also explain how it's holding you back... EDIT: you said, it's still holding you back. I'm not on hills a lot but every time I've used it, it seems to let go as soon as the clutch starts to come out/simultaneously adding throttle. I don't notice any clutch burning or indication of excess wear. Seems to work pretty seamless. But for someone who's on hills more often, you'd have more experience.
04-19-2015, 11:08 AM | #5 | |
Resident BMW Fanboy
259
Rep 866
Technically you're not supposed to add any throttle until you are already at the engagement point. When you do this on an incline, you are already at the friction point on the clutch with the car still holding the brakes (because you haven't hit the throttle yet) which is super annoying! I don't notice any clutch burning smell (because i'm not burning the clutch) but common sense tells me i'm slipping the clutch and it's not being converted to wheel movement, so i'm slipping the clutch for no reason which is causing unnecessary wear.
04-19-2015, 11:31 AM | #6 | |
Rep 5,577
04-20-2015, 11:18 PM | #7 |
Rep 80
My previous driver was a Subaru Forester XT with mechanical hill hold, and BMW does it a thousand times better. With my Subie, the brakes took a grab that needed some definite gas and feathering of the clutch to get rolling again. Rush hour commuting was an absolute PITA because even a little bobbing of the nose would engage the hill hold. I got really really good at driving r.e.a.a.a.l.l s.l.o.o.o.w.w in stop and go traffic to keep from having to stop at all costs.
With the 2, it's more that you have a couple seconds where the wheels just aren't going to turn backwards. I've never felt it hampering forward motion, or making it take any different input to the gas or clutch than what you would normally do on flat ground. |
04-21-2015, 02:00 AM | #8 | |
Rep 721
