11-24-2015, 02:30 PM | #1 |
Rep 102
Sport mode and moving the shifter to the left position
Question- is my car not in max "sport mode" if I just click sport or sport+? It seems to me if I am in sport+, and move the shifter to the left S/Manual position, the engine is even more aggressive/holds a lower gear than just in sport or sport+. Am I correct in thinking to make the car go as much as possible, I have to be in sport mode + have the shifter in S/M mode?
11-24-2015, 02:33 PM | #2 |
Rep 2,384
Sport = firmer steering & suspension dampening
Sport+ = firmer steering & suspension dampening & traction control off Sport & shifter in D/S = firmer steering & suspension dampening & gearbox in sport mode Sport+ & shifter in D/S = firmer steering & suspension dampening & traction control off & gearbox in sport mode When the shifter is to the left in D/S shifts are more aggressive and slightly faster I think. I THINK what I have above is correct but if anyone else can confirm please chime in! I've seen a ton of threads on this |
11-24-2015, 02:34 PM | #3 | |
Rep 1,797
Only time I don't is when I am cruising longer distances on freeway. No need to run the rev higher and hurt the fuel economy in those situations imo. Just out of curiosity, did you get this car new or used from BMW? These are very basic questions I would think a well trained, cares about their job sales advisor would have explained to you at delivery.
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
11-24-2015, 02:53 PM | #4 | |
Rep 2,942
11-24-2015, 02:55 PM | #5 | |
Rep 2,384
11-24-2015, 02:59 PM | #6 |
Rep 2,942
That's my experience as well. I drive 75 percent in Comfort mode; if I feel a need to be in the power band (i.e., merging with dense highway traffic), I'll simply slide the lever to D/S and let the car rip when needed. Freaked a few people out doing that, hehe.
11-24-2015, 04:23 PM | #7 | |
228i - 2015-03
13
Rep 66
11-24-2015, 04:27 PM | #8 | |
Rep 102
I bought this car new from my local large BMW dealer. These items all seemed straightforward when I was testing/buying the car, but have only made me wonder after a couple weeks driving it. |
11-24-2015, 04:29 PM | #9 | |
Rep 860
In any event I do love the very fast shifting ZF 8 speed rear wheel drive trans that most of us have in our cars. I've drive dual clutch transmissions in other BMW's and also in Porsches, and this transmission shifts nearly as fast with the downside of a dual clutch. |
11-24-2015, 04:30 PM | #10 |
Rep 102
That could make sense, it already shifts down when I put it into sport after I am moving, and then downshifts once more when I move the joystick. It could be an automatic "shift down 1 time when engaging the stick" I guess??
11-24-2015, 04:46 PM | #11 | |
Rep 2,942
Note to the OP: In any driving mode, if you quickly tap the accelerator to the floor, the car will automatically downshift to the lowest gear available for the given speed. However, because Comfort mode has a 'softer' throttle response, it sometimes take the car a bit of time to do this in that mode. That's primarily why I use the D/S setting on the transmission for situational throttle changes. Another note: if you're in manual mode and shifting manually using the paddles -- which you can do in full auto mode as well -- moving the transmission stick either way automatically and instantaneously cancels manual mode.
11-24-2015, 04:46 PM | #12 | |
228i - 2015-03
13
Rep 66
11-24-2015, 05:07 PM | #13 |
Rep 596
Sport and Sport + appear to have the same shift strategy, but moving the shifter to D/S makes it hang on a bit more towards 6k rather than 5k and the torque band.
The point of sport plus, from what i gather, is to allow you to have dynamic traction control and delayed dsc intervention with sport chassis and sport throttle response. Turning dynamic traction on in any other mode defaults back to comfort chassis and throttle (at least in my car) and turning dsc fully off in any mode defaults back to comfort for what seems to be modulation purposes. |
11-24-2015, 07:44 PM | #14 | |
Rep 3,331
Pulling the shifter over engages the most aggressive shift mapping.
Current: '20 X5, '18 M3 ZCP
11-25-2015, 12:59 AM | #15 | |
Rep 248
Sport & shifter in D/S = firmer steering & suspension dampening & gearbox in sport mode & more sensitive/aggressive throttle, traction control allows some slip Sport+ & shifter in D/S = firmer steering & suspension dampening & gearbox in sport mode & more sensitive throttle, traction control in fact is almost off but still there |
11-25-2015, 09:57 AM | #16 | |
Wannabe ///M Car Owner
91
Rep 94
Very close...this is what it does: With the gear selector in regular D and selecting the different driving dynamics button: -Sport: Increases throttle response, Holds out gears longer, Stiffens suspension, Opens second exhaust port (makes it a little louder) -Sport+: Same as sport but activates Dynamic Traction Control**. What DTC does is it allows the cars wheels to spin a little bit but if too much out of control, Traction Control will kick in. With the Gear selector in D/S: -When slid over to the left position, it activates regular Sport mode (same as above). As soon as you either 1. pull the paddle shifter or 2. push/pull the gear selector to change gears, it leaves you in control of the gearbox. I am 99.99% sure it does not change the aggressiveness of the shifts (that's a real ///M car feature). -When slid over to the left position plus hitting the Sport+ mode does the same thing as above and also the same thing as far as pushing/pulling the gear selector/paddle shifter. **While we are on the topic...DTC (Dynamic Traction Control) and DSC (Dynamic Stability Control) are two different settings. Best way to describe the 3 settings are this: Turn the car on and don't touch any buttons- This means Traction Control is fully activated: It's like taking a child to the play ground and and you're helping them down the slide, cross the monkey bars, etc. If you press the Traction Control button once: This activates DTC: Using the same analogy, this is like taking the kid to the park, but taking a few steps back and allowing them to go down the slide on their own BUT if something were to happen, you're there to catch them. If you press and HOLD the button: This turns OFF DSC. This means your at the bar getting banged up and completely forgot you took your kid to the park. Hope all this stuff helps!
I drive a fake ///M car.
11-25-2015, 08:16 PM | #17 |
Rep 5,262
If you are in Sport mode configured it to either drivetrain only or drivetrain and chassis... then putting the shifter in D/S does nothing but to downshift a gear momentarily
Sport mode already includes D/S mode for the shifter |
12-03-2015, 06:49 AM | #20 | |
M POSTER
132
Rep 516
12-07-2022, 12:53 PM | #21 |
Rep 1
I have a 2016 BMW m235i xdrive with an MHD flash tune and a transmission flash. Not sure if that changes what the left position on shift knob (M/S) vs D
For me the comfort vs sport mode vs sport mode + is as described above by a few people. Changing suspension and drive train and take traction control off etc etc. However, there is ALSO 100% a different in the transmission gear changes when it is is (M/S) mode aka moved to the Left. When it is in D mode and I am in sport plus and I drive around it is a very sporty transmission. BUT - when I also put it in M/S mode on the shift know the gear changes are even more aggressive. The easier way to notice this is to go 120 mph. In D setting you will be in D8. In (M/S) setting you will be in S7 gear. Also the way the car holds gears is very different in (m/s) mode versus D. Hope that helps. But once again I have an MHD flash tune and transmission tune. |
