First Service Question and Warranty in Regards to Winter Wheels |
11-24-2015, 11:10 AM | #1 |
Rep 241
I have a few questions for you guys
1: Computer seems to pinpoint service at 11,500 miles, does this sound correct? I thought it was every 10,000 miles. 2: Will they adjust the emergency brake under warranty if I ask them to do it when I bring it in? 3: One of my speakers is blown out (was like that when I first got the car). Would they cover that? 4:Will they void my corrosion/suspension warranty for using aftermarket BBS wheels and 215/50R17 tires if I bring the car in with that combination? 5: Also, I coded the office function into my headunit. Should I remove that before I bring it in for service? Thanks |
11-24-2015, 11:18 AM | #2 | |
Rep 5,980
2) If the parking brake does not seem to be functioning properly, they should bring it back to its proper function under warranty if the car is under warranty. 3) If the car is under warranty, the speaker should be covered. (Based on your questions, was this a used car?) 4) No. There is no issue, unless you are complaining about a defect in the wheel which they did not supply. I am running BBS SR wheels for 3 seasons, and the service advisor merely mentioned that he thought they looked very good. Your tire size, which is also my winter tire size, is well within the accepted variation for overall outer diameter. 5) Sorry, not familiar.
11-24-2015, 11:31 AM | #3 |
Rep 1,047
Don't bother. I had Office coded into my car as well. I went in for a software issue and they ended up doing a software update - they didn't mention it, and I still have Office after the update. Honestly they aren't gonna even think about it.
11-24-2015, 11:42 AM | #4 | |
Rep 1,095
previous: 2003 E46 330i SMG
11-24-2015, 11:57 AM | #5 | |
Rep 886
Same goes for changes to the car outside of manufacturer's tolerances. If you tune the ECU and your car subsequently throws a rod, you'll find you have no warranty for that failure, as the increased engine power is a reasonable proximate cause for that type of failure. However, if you tune your car and the power seats stop working, your warranty on those items remains in effect, as the engine power output is unrelated to that type of failure.. Now, the value of that act to someone in Poland is, shall we say, pretty small.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 11-24-2015 at 12:05 PM.. |
11-24-2015, 12:03 PM | #6 | |
Rep 5,980
