10-22-2015, 04:50 PM | #23 |
Rep 555
I think they will retain the M badging, and probably bump in power. The entire debut of the M235i (and in this case the LCI) was catered at a lower budget enthusiast car with the spirit of the older cars. The 235i started life as an M performance model, I doubt they would neuter it midway through production as far as marketing goes.
Even with a 330 or 335hp M240i model, it will still lag enough behind the M2 for it to be a distinct model in the lineup. The M2 is not all about straight speed and power, as far as suspension and brakes etc is concerned it is more M4 than it is 235. It just has a weaker power plant. So even if the power was very close, the M2 is still a distinct enough car to warrant its own market share. Especially if the MSRP stands true, and it is really not far in price from the 235 currently.
11-21-2015, 07:22 PM | #25 |
Rep 6
Drives: 2016 M235i (in Spring 2016)
Any truth to the suggestions that the 2018 M240i with the new B58B30M0 engine will successfully resolve, or at least reduce, the valve stem carbon build-up issues that seem unavoidable on direct-injection engines? If so, I'd consider waiting for the new motor for this reason alone.
11-21-2015, 08:28 PM | #26 |
Rep 8,942
Hoping for different wheels. I hate mine even when they're not bent or cracked, which isn't often.
11-22-2015, 08:49 AM | #27 |
Rep 449
According to the other threads on this forum the model year 2017 vehicle will change from 235 to 240. That means it will probably be in the dealership the same time as the other model year 2017 cars: August 2016 or September 2016.
11-22-2015, 07:18 PM | #29 | |
Rep 860
11-22-2015, 09:04 PM | #30 |
Rep 6
From what I've been reading in my new-vehicle research, all direct-injection engines suffer from progressive carbon build-up at the base of the valve stems to some degree. As I understand it, since there's no over-valve fuel flow to aid with cleaning as in port-injected engines, carbon progressively builds up on the valves of direct-injected engines which will require periodic cleanings to restore original engine power, smoothness and efficiency. Apparently, the installation of a catch can may help delay the onset of severe carbon build-up symptoms, but there is no preventive measure and eventual abrasive media blasting will be required to remove the carbon deposits. Are there any high-mileage M235i owners out there detecting rough idle, power loss or reduced fuel economy that might be attributable to carbon build up?
11-22-2015, 09:13 PM | #31 | |
Rep 860
11-22-2015, 09:53 PM | #32 |
Rep 295
Although the closed deck design of the B58 is a tempting feature. I think the N55 from the M235 shares more DNA with the M2 and is quite tuner friendly to boot. this is very reminiscent to when BMW switched from the N54 to N55 on the 1 series but retained the N54 for the 1M.
Sometimes the newest engine from BMW is not the one to have. Hence BMW kept the old engine design in the 335is as well where the 335i had the pretty tame N55 in it. Don't forget that the M235 N55 30O0 has a steel crankshaft and is a cut above the standard N55 30M0 in the 335i and 345i which has a cast crank. So, the B58 is definitely an improvement over the n55 30M0 (335/435) but questionable if it will be better than N55 30O0 M235. So the one thing I would question is... why if the B58 is a better motor, are they retaining the N55 for the M2?
I love this country!
11-22-2015, 09:58 PM | #33 |
Rep 229
11-22-2015, 10:04 PM | #34 |
Rep 860
11-22-2015, 10:08 PM | #35 | |
Rep 229
Still, consider valve cleaning expected maintenance and expect to do it once or twice over the life of the car, if you keep it past the warranty period. It's really not that expensive and is somewhat offset by the fuel savings direct injection offers. Of all the things that can go wrong with a BMW, this one is far from something to lose sleep over. |
11-22-2015, 10:14 PM | #36 | |
Rep 229
Until an engine is proven by years of service, any guess as to long term reliability is just that. |
11-22-2015, 10:26 PM | #37 | |
Rep 860
11-22-2015, 10:32 PM | #38 | |
Rep 229
http://jalopnik.com/here-s-why-the-v...car-1676466510 |
11-23-2015, 06:59 AM | #39 |
Rep 860
From what I've read (and I've read a lot on this as I'm one of the owners, who happens to be on his third battery after less than 4 years) BMW could change the software for the charging system, which is designed to prioritize fuel economy versus immediately recharging the battery. But if they did that, they would have to go back and change the EPA mileage estimates and speculation is they would have an owner class action lawsuit on their hands. This is in combination with a battery that has to run a coolant pump for quite a while after most engine shutdowns to cool down the two turbochargers sitting in the "V" between the two engine banks (could there be a hotter location for the turbos to be located?) So you have a battery that is rarely sitting in a fully charged state when the vehicle is not being used. Not a recipe for long battery life. Our X5 is now out of warranty, and whenever it's going to be sitting for more than a day or two, I throw it on the battery tender.
11-23-2015, 09:50 AM | #40 | |
Rep 6
11-24-2015, 09:15 AM | #41 | |
Rep 2,384
I have several friends with high mileage N54's. One of which is a 90k mile N54 which has been full bolt on and tuned for almost 60k miles, with slim to no problems. I can't imagine the n55 will be any LESS reliable in the long run. Enjoy it. Keep up with your oil changes, especially if tuning etc. Keep up with regular maintenance and you should be trouble free. |
11-24-2015, 12:51 PM | #42 | |
Rep 580
11-24-2015, 01:15 PM | #43 | |
Rep 229
