BMW 3-Series (E90 E92) Forum
APEX Wheels | Classic Forged Line
11-15-2019, 03:53 PM | #1 |
BimmerPost Supporting Vendor
3593
Rep 6,846
Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST ARC-8R & EC-7R Everything you love about the original, now enhanced with all the added benefits of forged manufacturing. ➡︎ Significantly increased strength ➡︎ Improved brake clearance ➡︎ Paintless knurled beads ➡︎ New premium finishes Order Now ARC-8R / EC-7R Available Finishes Even More Strength “Forged” doesn’t mean strong. Many forged wheels focus on weight reduction so much that they end up with the same load rating as cast wheels. Think all forged wheels are stronger than cast or flow formed? Think again. We've added up to 1,000 pounds of extra load capacity per vehicle compared to our flow formed line. Learn more about why not all 'forged' wheels are strong. The flow formed ARC-8 was our first design, so it features our older barrel profile with compromised brake clearance. Typical blank forgings (the starting point many other manufacturers use) can have even worse clearance than our original flow formed wheel. By developing our own proprietary new profiles and new dies, the 18" ARC-8R and EC-7R can clear Brembo 380mm kits and the 19" version can clear BMW 410mm carbon ceramics. Learn more about why we had to create our own new forging dies to clear big brakes. Not all knurling is created equal. To reduce unwanted tire spin as much as we could, we protected our knurling from paint to keep them sharp. We didn’t take the cheaper shortcut of painting over the bead area, which makes the knurling smoother and rounder. See and feel the difference. Learn more about why our forged wheels have unpainted knurled beads. Our forged wheel line enabled us to release premium finishes we’ve always hoped for. Fully polished aluminum and hand brushed with tinted clear now join a wide range of painted finishes, with more to come. Our forged wheels not only deliver performance, but also provide distinctive new styling as well. APEX is known for stocking a wide variety of chassis specific fitments to meet the needs of a very diverse enthusiast community. We’re releasing those same street, track and race proven fitments and more in our new forged line. New lower production requirements allow us to cater to even the most niche segments of the BMW market that may have previously been off limits. We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a fully forged wheel with an ideal balance of strength and weight. Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX Classic Line forged wheels are tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our forged wheels exceed those ratings by almost 20%. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy. Additional Features Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required. Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps. Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly. TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes. All our forged wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase. Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable. Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. Learn more We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides. For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable BMW Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively. All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse. Order Now ARC-8R / EC-7R Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 11-12-2021 at 05:24 PM.. |
11-15-2019, 03:54 PM | #2 |
3593
Rep 6,846
Introducing the ARC-8R Race Silver Anthracite Satin Black Brushed Clear Polished Introducing the EC-7R Race Silver Anthracite Satin Black Brushed Clear Polished
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 12-16-2020 at 02:52 PM.. |
03-26-2020, 06:42 PM | #3 |
3593
Rep 6,846
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
08-31-2020, 06:15 PM | #4 |
3593
Rep 6,846
APEX Forged: Stronger than ever and ready to ship. Our new forged offerings have significantly higher load ratings with over 1000 LBS of additional capacity for 4 wheels in an 18" diameter compared to our already strong flow-formed wheels! The increase in load rating allows these new wheels to better cope with the demands that sticky tires, heavy cars, and high downforce present. This E90 is track ready with 17" EC-7Rs: Specs: Front & Rear: 17x9" ET42 EC-7R in Brushed Clear 12mm spacer (Effective offset of ET30) 255/40-17 Toyo RR tires
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 12-16-2020 at 04:07 PM.. |
09-03-2020, 10:12 AM | #5 |
Rep 266
Can you guys make these in a copper finish?
2007 335i E92 FBO | MHD Stage 2+ 93 octane | xHP Stage 3 | Fuel-It! Stage 2 LPFP | VRSF 7" FMIC | VRSF Catless Downpipes | ER Chargepipe | HKS SSQV4 BOV | Ultimate Racing CAI
09-10-2020, 05:48 PM | #6 |
3593
Rep 6,846
Several of our EC-7R BMW fitments are available in Satin Bronze!
This is an image of a forged BRZ wheel, but the finish is identical to our BMW wheels. -Tom
09-10-2020, 08:12 PM | #7 | |
Rep 266
My car is a 2007 E92 Pre-LCI with rolled rear fenders. Per your website's guide, can you confirm these will work on my car? FRONT: 18x9 ET31 • 245/40ZR18 REAR: 18x10 ET33 • 275/35ZR18 Thanks!
09-12-2020, 01:55 PM | #8 |
Rep 58
I have an 08 e93 335i with sport package with 18" OEM wheels. I like the ECR7 but the oem wheels are 18x8 (front) and 18x8.5 (rears) and looking at your website I only see 18x8.5 and 18x9.5 so guessing your wheels would not be compatible with the OEM size tires?
09-14-2020, 01:48 PM | #9 | |
3593
Rep 6,846
8.5 is the narrowest wheel we make in an 18" diameter. If you do intend to reuse your stock tires, they will likely be stretched on the wider APEX wheels, but depending on the size, they may still fit. -Tom
09-19-2020, 11:11 AM | #10 | ||
Rep 266
Can you confirm this setup for my vehicle? I'm on H&R Sports springs and Koni Yellows.
09-19-2020, 08:31 PM | #11 |
Rep 1,532
Expert@ApexRaceParts
Looking for the 19" variants of these wheels, I see them in this table but not on the online store. Send me a PM if possible |
09-29-2020, 05:03 PM | #12 | ||
3593
Rep 6,846
18x9 ET31 with 245/40-18s should be a direct fit-up front 18x10 ET33 should fit with a 275 in the rear as long as the fenders are rolled. Quote:
The 19" forged wheels have been delayed and are taking longer than we expected. We should have more details on ETAs and availability for these wheels in 2021. -Tom
10-16-2020, 06:16 PM | #13 |
3593
Rep 6,846
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 12-16-2020 at 03:55 PM.. |
11-06-2020, 02:44 PM | #14 |
3593
Rep 6,846
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 12-16-2020 at 03:59 PM.. |
12-07-2020, 03:48 PM | #15 |
3593
Rep 6,846
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 12-16-2020 at 04:05 PM.. |
01-04-2021, 06:54 PM | #16 |
3593
Rep 6,846
01-22-2021, 04:18 PM | #17 |
3593
Rep 6,846
The fully Forged ARC-8R Unlike our Flow Formed wheels, the Fully Forged APEX ARC-8R and EC-7R are offered with a profile 2 medium concave design even in the higher offset sizes. This allows all chassis to experience the awesome look of concave wheels.
02-05-2021, 04:15 PM | #18 |
3593
Rep 6,846
The Fully Forged EC-7R: More Brake Clearance Thank Any Other APEX Wheel The APEX EC-7R improves brake clearance over the impressive amount offered by the Flow Formed EC-7. Forging allows us to reduce spoke thickness without compromising strength. As a result, the EC-7R has more brake clearance than any wheel we've ever made.
03-11-2021, 07:08 PM | #19 |
3593
Rep 6,846
03-17-2021, 11:41 AM | #21 | |
3593
Rep 6,846
We do not have any discounts available at the moment. If you would like to subscribe to our newsletter to be informed of any upcoming sales, sign up at the bottom of our website home page. -Ian
04-06-2021, 05:13 PM | #22 |
3593
Rep 6,846
