BMW M2 Forum > BMW M2 Discussions > How do you minimize carbon buildup in M2 intake ports?
      02-25-2016, 12:16 PM   #1
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
It's great that the N55 based M2 is getting great reviews however I am bugged that with mileage the performance is sapped with gradual carbon buildup in the intake.
I'm not convinced that by using Shell 93 it won't build up.
(I have yet to transition to direct injection / still have port inj. NA BMWs.)
Thoughts ?
Not sure the B58 design resolved the issue found in the N54/5, but still wondering about this.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      02-25-2016, 12:20 PM   #2
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Drives: F80 ZCP 6MT, R55 Clubman S 6MT
Walnut blasting every 40K miles should do the trick. I prefer it to seafoam.
My delivery experience and beach photoshoot here.
      02-25-2016, 12:32 PM   #3
G80indy
Save the Manuals
G80indy's Avatar
Yeah I know about that. That's the "fix"--
It's extreme IMO.
I'm more interested in prevention and the engine design
2023 G80 6MT, CCBs
      02-25-2016, 12:49 PM   #4
PrematureApex
Drives: N55 X1, N54 135, s54 m3
Thoughts ?
Why would gas help? It's a DI engine. That's the point, the fuel never touches the valves.
There is no solution.
It's extreme IMO.
Extreme? It's no big deal.
A few hours to do yourself, or a few hundred to get it done by an indy. Hardly a big deal every 3-5 years.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      02-25-2016, 01:00 PM   #5
OG///M
Always +10MPH
OG///M's Avatar
Drives: 6MT
Thoughts ?
What others already said in addition to redlining the beast at least once everyday as you get on the on ramp.
      02-25-2016, 01:16 PM   #6
PrematureApex
Unfortunately, it doesn't do a damn thing. That's more for exhaust side buildup some other cars have (E39 M5, for example IIRC).
There are track-only N54/55s out there that still have buildup.
That being said, anecdotally, the N55 is less prone.
      02-25-2016, 01:25 PM   #7
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
It's extreme IMO.
Is there another way that is more "simple"?
      02-25-2016, 01:28 PM   #8
PackPride85
Drives: M2
I believe Porsche recommends their own DI cleaning service every 60k miles where they actually remove the head and hand clean it. Not cheap, but it does the trick.
I've had a BG DI service done on my mazdaspeed 3 where they suck in some cleaning agent through a vacuum line similar to seafoam. Never had it scoped to see if it worked but my gas mileage is still solid after 8 years and 110k miles. https://www.bgprod.com/catalog/gasol...ction-cleaner/
Or you buy a BRZ that has both DI and port injection and not worry about it.
      02-25-2016, 01:45 PM   #9
paradoxical3
Drives: BMW
This won't be an issue. I visually inspected my valves at 70k miles of hard use and there was no point to clean them; they were so clean that the shop said that I wouldn't even be able to tell a difference if we blasted them. The PCV system is way better on the N55 than it is on the N54. The shop walnut blasts many N54s (several a week) and have never come across a N55 that was worth doing it under 100k miles.
Appreciate 8
skiparock182.50
jefe2000740.50
      02-25-2016, 01:52 PM   #10
PrematureApex
So the rumors are true. Thanks!
      02-25-2016, 03:12 PM   #11
LDSM
LDSM's Avatar
Drives: ...
thanks for the info, I've read a few other N55 owners saying the same thing.
      02-25-2016, 03:49 PM   #12
JohnNC-M2CS
Drives: M2 CS on order
2020 BMW/M@ CS  [0.00]
2016 M2  [10.00]
2011 BMW 1M  [9.50]
What about using a can of BG44K in the fuel tank every 3 - 6K? I've been using it for years on my cars, that average 75 - 85K before I sell them, and never had a performance issue that I could detect.
      02-25-2016, 04:09 PM   #13
PrematureApex
Again, it's a DI engine. The fuel doesn't touch the intake valves. Hence the buildup problem.
Nothing about fuel, in the fuel, etc. has any bearing on the issue.
      02-25-2016, 04:27 PM   #14
craina
Drives: 2020 m2c
Regular WOT is known to slow the buildup.
      02-25-2016, 04:52 PM   #15
JohnNC-M2CS
2016 M2  [10.00]
2011 BMW 1M  [9.50]
Bah, I should have know that, thanks.
      02-26-2016, 01:28 AM   #16
Nine Lives
Nine Lives's Avatar
United Kingdom
602
Drives: Austin Maxi
Yep,
The ' Italian tune up ',still the original and best way to cure all known engine problems
      02-26-2016, 04:08 AM   #17
goodboy1451
Drives: BMW 1M Coupe
Yes there is. Keep it in the garage and don't drive it.
      02-26-2016, 06:20 AM   #18
ORIGIN M.
Drives: ///M
You drink walnut puree.
      02-26-2016, 06:28 AM   #19
PrematureApex
Known to? Again, that's for preventing/slowing exhaust side build up, not intake side which we're talking about. Track only N54s (and even N55s) have the issue.
      02-26-2016, 06:33 AM   #20
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Originally Posted by PrematureApex View Post
Know to? Again, that's for preventing/slowing exhaust side build up, not intake side which we're talking about. Track only N54s (and even N55s) have the issue.
Just stop answering...people don't read the responses anyway.
      02-26-2016, 06:34 AM   #21
PrematureApex
It's brutal. They read something on the internet, then re post it, without any attempt to understand the problem, etc.
JTO245276.00
      02-26-2016, 07:13 AM   #22
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Ummmm. Right.
Well, that, and the answers to the questions are usually right in the thread. I technically answered it theoretically because I understood it to be similar to my N54 notwithstanding combustion characteristics, and then I was given more information not 3 posts down.
Reading is fundamental, folks. Fundamental.
m2
