04-07-2015, 05:27 AM | #23 |
Rep 197
Yes it should - thanks for the input.
Please feel free to add to and/or correct the boost increases in the revised list below. • AC Schnitzer: • Active Autowerke: • AFE Scorcher: +4 • BMS Stage 1: +3.5 (default, according to Trcb777) • Dinan Stage 1: +3 (according to The Nerd) • ESS E-Tronic: • Hartage: • JB4 map1: +3.5 • Manhart stage 1: +4 • RaceChip Ultimate: +3.6 • Remus: |
04-07-2015, 07:44 AM | #24 |
IG @bmwF9xG80
3813
Rep 7,593
Béhème the Remus uses RC module, like ActiveAutowerke uses Speed-Buster Module but has their own tune software more info can be found in their Thread really good tune just a little late in the game folks are now heading Real Software Tune per BR-Performance affiliated friends/network dealers in the USA.
in the N20 engine, Racechip comes stock at 2-3 psi over stock and I've seen it at even 5 psi over stock in the more aggressive settings which would be appropriate for those with mods, as I tested in my stock car for a few days in the cold winter wouldnt dare to do so now in the spring as climate is getting warmer thus vehicle requiring better cooling and parts getting hotter, another tip is I only used Shell/Valero 93 octane in those aggressive testing, i would not touch lower quality (cheaper gas) even if its 93 octane like lets say BP here because i've gotten a lot of jerky feel with BP Hopefully Delnari chaddy74 can chime in on more aggressive settings in the RC to see how much boost it can achieve. I think AlexGT will do too since hes fully modded now
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
04-07-2015, 09:06 AM | #25 | |
Rep 809
I do feel the car is way faster and aggressive (more torque), but the only time I took my car to sea level, I was amazed about how faster the car was, for sure the altitude has something to do here. |
04-07-2015, 09:11 AM | #26 | ||
IG @bmwF9xG80
3813
Rep 7,593
Do you have any Race Fuel or Torco Octane Accelerator ?
04-07-2015, 09:19 AM | #27 | |
Rep 5,262
04-07-2015, 09:26 AM | #29 |
Rep 5,262
04-07-2015, 09:28 AM | #30 | |
Rep 809
I would like to know how much in numbers, does the altitude affect a car's performance. You're good with numbers pikcachu, any ideas? |
04-07-2015, 09:32 AM | #31 |
Rep 193
As far as I know its about 5% for every 1000m for Turbo, and 10% for NA... huge diff...
04-07-2015, 09:37 AM | #32 |
Rep 809
04-07-2015, 09:43 AM | #33 |
Rep 193
04-15-2015, 05:59 AM | #34 |
Rep 197
Revised the RC Ultimate boost increase below. Please feel free to add to and/or correct the boost increases in the list.
• AC Schnitzer: • Active Autowerke: • AFE Scorcher: +4 • BMS Stage 1: +3.5 (default, according to Trcb777) • Dinan Stage 1: +3 (according to The Nerd) • ESS E-Tronic: • Hartage: • JB4 map1: +3.5 • Manhart stage 1: +4 • RaceChip Ultimate: +3 • Remus: |
04-15-2015, 01:23 PM | #35 |
Rep 397
04-15-2015, 02:11 PM | #36 |
Rep 5,262
04-15-2015, 03:03 PM | #37 | |
Rep 115,980
The JB4 does not run an additive system. It runs an absolute system. Map1 can make anywhere from 0 to 10psi more than the factory tuning depending on several factors like oil temp, pedal input, RPM, EGT, gear, etc, etc. Mike |
04-15-2015, 05:43 PM | #38 | |
Rep 210
I would love to get another .75 PSI out of the car. Thanks. |
04-15-2015, 06:14 PM | #39 | |
Rep 115,980
You can with the newer system (the one that comes with only two plugs and says G3_V2 on the circuit board), but to enable your setting you also need to select map 3. The newer Stage1 uses the JB4 interface while the older one used the old Stage1 interface. Mike |
04-15-2015, 06:18 PM | #40 | |
Rep 210
04-15-2015, 08:33 PM | #41 |
Rep 939
I got my bms stage 1 back in Sept 14 and picked up the usb connection in January. The interface I used is actually jb3 and sent to me by bms. Once I got everything hooked up, the default setting was 3.5 and I bumped it to 4.25. I didn't want to go too crazy since it doesn't have the same safety nets and connections the jb4 has.
04-20-2015, 05:27 AM | #42 | |
Rep 197
This approach could possibly be the best stage 1 tune!!! |
04-20-2015, 11:00 AM | #43 | |
Rep 115,980
I responded to your pm as well. Mike |
04-23-2015, 12:42 PM | #44 | ||
Rep 197
