03-21-2015, 12:28 PM | #1 |
Rep 627
Has anyone got EWG wires to work flawlessly on N55?
Everytime I try installing the EWG harness to JB4, I get drivetrain malfunction.
Has anyone got it to work without any codes thrown? |
03-22-2015, 07:15 PM | #2 |
Rep 528
Do you have the correct firmware? Make sure its the N55_FSERIES_EWG_3_0.hex. When I updated it I accidentally updated the F series non EWG firmware, car instantly threw the same malfunction. Just re updated and all was well.
03-23-2015, 03:14 PM | #3 | |
Rep 190,777
if you are still having problems, contact Terry.
03-24-2015, 02:14 PM | #4 | |
Rep 2,494
04-01-2015, 10:36 AM | #5 |
Rep 19
When you have these wires installed, how do you start the car? Press the start button without starting the car, let the dash light up wait about 4-5 seconds then start the car. This allows the jb4 to start up before the drivetrain malfunction kicks in. I have the ewg wires with no issues since day 1.
04-01-2015, 12:51 PM | #6 | |
Rep 627
How are the gains with EWG |
04-01-2015, 03:45 PM | #7 |
Rep 19
I haven't had a chance to get the car on a dyno yet, but after the wires it felt stronger. I just installed the new EWG board BMS has. With this new board down the line tuning EWG car's we will see more results.
2014 EBM/CRD M235i JB4, EWG board, FF Wires, EWG Wires, BMS Intake, ER DP, ER CP, E50, Map 7.
04-01-2015, 05:40 PM | #8 | |
Rep 627
04-01-2015, 09:05 PM | #9 |
Rep 19
Physical upgrade, you pay $130 for the new board and once you send back your old board they send back the $100 core. New board requires no power or ground so they say, however my m235i still required to ground it. So after i cut the power and ground wires then ran into issues with the car not starting, BMS discovered my car still needed a ground. They are saying something is wrong with my car's grounding system . So if you end up getting the new board cut the power wire off, but just disconnect the ground if the car doesn't start then connect the ground, if it does then i guess my car does have a issue.
04-16-2015, 12:52 AM | #10 | |
Rep 627
Thanks! Edit: Damnit!! They don't send to Cali.. Guess it'll have to wait when I go to Jersey for business |
04-21-2015, 01:46 PM | #11 | |
Rep 19
Yes, $30 at the end of the day. I should start a business for people who live in Cali, have it shipped to my house in Jersey and ill send to their house in Cali for a small fee.
