2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum What is this hanging cable on the wind deflector??
      03-29-2024, 01:59 PM   #1
NKOTB2015
Drives: Lexus LS460, Toyota Sequoia, B
So...I have this wite hanging from the wind deflector...I figured it's some sorta tension cable to retract the pins to install/Uninstaller the defector on to the car but when I pull on it, nothing happens with the pins.
So, what is it for and is there a way to fix it? I'm tempted to just cut it off but wanted to ask here first. Any input would be appreciated!
P.S. I need to remove the 2nd row headrests.
      03-29-2024, 07:49 PM   #2
cdn240cab
cdn240cab's Avatar
Drives: M240 Cab
It's probably part of the locking mechanism or spring to keep it open. I wouldn't recommend cutting it. Talk to your dealership.
      03-30-2024, 02:54 PM   #3
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
The thing will fold at the joints to allow removal. I do like the fact you have a knob to undo the rear pins to flip up the base to stow luggage underneath it. That spring may be from the internal area that holds the unit flat after you unfold it. May as well cut it off as I don't think there is a way to put it back inside and have it work.
On the head restraints, if there is a button on the seat where they go in, press it and pull up otherwise just pull up strongly and be ready for them to hit you in the face when they come out DAMHIK.
      03-31-2024, 10:17 PM   #4
NKOTB2015
I think im just gonna cut it off. It doesn't seem to have any effect on the functionality of the deflector.
As for the 2nd row headrest, I popped the mechanism housings (ones that cover up the headrest guides) and pulled the clips that lock the headrests in place. Headrest came right out.
Thx for your feedback.
jzeiler4320.00
