08-20-2019, 08:13 PM | #23 | |
Rep 1,066
Current: 20 M340i
Sold: 19 x3 30i X drive, 18 230i X drive Convertible 18 x3, 30i X drive 16 428i Convertible, 16 X1 X drive, 14 i3 Rex, 14 328i, 14 x1 28i X drive, 08 328i, 03 M5, 99 323i Convertible, 00 z3 M Roadster, 99 328i, 00 323i |
08-20-2019, 08:16 PM | #24 | |
Rep 1,066
Current: 20 M340i
08-20-2019, 11:24 PM | #25 |
Rep 1,352
fmzip that's the same as my car. The one advantage is that you do not have to remove the drive selector switch from the console assembly on our vehicles. You can see my post above and the back and forth between bmtespar .
08-21-2019, 07:46 AM | #26 | |
Spoiler Bandit
1650
Rep 872
So you simply removed the eyeglass holder and the charging base fit right in? How did you secure it to the trim bezel? Tape as well? |
08-21-2019, 01:36 PM | #27 | |
Rep 1,352
08-21-2019, 03:17 PM | #28 |
Spoiler Bandit
1650
Rep 872
Do either of you have the technology package? Just thought about this, if the phone isn't plugged into the USB in the glovebox, do I lose features?
10-17-2019, 01:54 PM | #30 | |
Rep 97
10-24-2019, 06:22 PM | #32 |
Rep 97
I managed to get it installed and looks really great. I am having an issue that it would pause the charging intermittently when I begin charging my phone, did you have a similar issue?
10-24-2019, 11:14 PM | #33 |
Rep 1,066
Sounds like potentially a bad charger. Does the charger start flashing red instead of blue?
Current: 20 M340i
10-25-2019, 12:40 PM | #34 |
Rep 97
My leds light up a little odd in terms of what colors mean what.
green = charging blue = not charging red = charging completed I also have not figured out what green flashing means (Ive seen this one once or twice) |
10-27-2019, 10:34 PM | #35 |
Spoiler Bandit
1650
Rep 872
Finished my install today.
I decided to keep the unit in tact and used doublesided tape to hold it down. The issue I ran into after removing the sunglass holder, there was nothing to tape or glue to. Solved the problem by using a piece of wood. Took a few screws and secured it into the wood from the sides. This way if I ever have to go back to stock, no problem at all. |
12-13-2020, 10:37 AM | #37 |
Rep 1
I have a 428i, which appears to have the same console. This walkthrough helped me immensely. I ordered a used cup holder with ashtray cover on eBay, and retrofitted the wireless charger onto the lower half of the ashtray cover. Came together pretty well, thanks for y’all’s insight!
03-15-2023, 05:15 PM | #39 | |
Rep 232
04-03-2023, 01:02 PM | #40 |
Spoiler Bandit
1650
Rep 872
Are you loooking for this?
https://www.ebay.com/itm/144826631501 https://www.ebay.com/itm/225506002884 |
