2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum 2 Series Photos and Videos My M235i blue estoril
      11-12-2017, 10:09 PM   #111
BcolaM235
BcolaM235's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [0.00]
David great build! I just had some problems with my seats for my M235 (broke the motor, and was interested in putting the competition seats in mine. I've had trouble locating some and only found a full set for $6000 USD. Any chance you could help point me in the right direction to find a set? I could just do the front seats for now as well.
      11-12-2017, 10:18 PM   #112
wanofakind01
Drives: '17 BMW M2 6MT, '16 BMW X1
Awesome build, subscribing to follow!
      11-13-2017, 05:09 AM   #113
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
here are links on ebay of complete interior M4 and M2
https://www.ebay.fr/itm/BMW-F82-M4-4.../202088368469?
http://www.ebay.fr/itm/BMW-M-F87-M2-...53.m1438.l2649
https://www.ebay.fr/itm/Bmw-F87-M2-L...53.m1438.l2649
https://www.ebay.fr/itm/BMW-M4-F82-S...53.m1438.l2649
http://www.ebay.de/itm/BMW-M-F82-M4-...YAAOSwaB5Xvaab
      12-24-2017, 07:55 PM   #114
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
new rear diffuser carbon style M3
      12-24-2017, 08:00 PM   #115
aozer
aozer's Avatar
995
what spoiler is that?
      12-24-2017, 08:05 PM   #116
david51
david51's Avatar
France
538
Drives: bmw M3 F80
a copy style M3 bought on aliexpress
      12-25-2017, 03:10 AM   #117
derfl
Drives: F30 335i
How is the fitment, David? Like OEM?
Do you have a link which one you ordered?
Do you also have a link for the trunk spoiler for me. Thanks.
Thanks and merry Christmas!
      12-25-2017, 06:04 AM   #118
david51
david51's Avatar
France
538
Drives: bmw M3 F80
hello thank you very much and Merry Christmas too
for the fixation, it is necessary to disassemble the rear bumper and to make like the following video
https://www.youtube.com/watch?v=7_pUmcCRBOU
https://fr.aliexpress.com/item/F22-C...813418702.html
https://fr.aliexpress.com/item/F22-M...722279107.html
      12-25-2017, 07:13 AM   #119
derfl
Drives: F30 335i
Thank you David.
So it's not possible to attach it like the original performance diffusor with just plug and play?
I have to disassemble the whole bumper and drill holes?
Thanks
Regards
      12-25-2017, 07:21 AM   #120
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thank you David.
Thanks
Regards
no it is not plug and play.
you must absolutely dismount the bumper otherwise it does not hold.
I tried to mount it without dismounting the bumper and the result was slightly cracked in the center
the seller should have warned me before he had to dismount the bumper to fix it
      01-25-2018, 01:44 PM   #121
bubbajan21
Drives: BMW
Originally Posted by david51 View Post
The assembly of the front seats are very easy, for the rear there are modifications.
So that it works perfectly for the front seats it is necessary to use the original modules of your bmw
First off, let me say this is a beautiful build!!
Can you elaborate a bit on what is required to fit the rear seats?
      01-26-2018, 06:57 AM   #122
david51
david51's Avatar
France
538
Drives: bmw M3 F80
for fixing the backrest simply replace the original fixings instead
      01-26-2018, 07:00 AM   #123
david51
david51's Avatar
France
538
Drives: bmw M3 F80
for the sitting part, we must remove the metal bar bottom otherwise it does not fit
      02-04-2018, 05:14 PM   #124
Dponce228i
Drives: Bmw 228i 2014
So nice
      02-17-2018, 04:16 AM   #125
BabyHannibal
BabyHannibal's Avatar
South Africa
Drives: BMW ///M235i & E36 ///M3
Hi David
I love your build
Are those the only two modifications that need to be done to get ///M4 seats to fit my ///M235i?
Thank you
Regards
      02-17-2018, 11:57 AM   #126
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by BabyHannibal View Post
Hi David
I love your build
Thank you
Regards
yes it is just a resume the original backrest and for the seat must remove the metal rod to insert it thoroughly.
for both sides, they must also be modified inside
      02-18-2018, 02:48 AM   #127
BabyHannibal
South Africa
What must be modified inside David?
Apologies for all the questions.
      02-18-2018, 08:01 AM   #128
david51
david51's Avatar
France
538
Drives: bmw M3 F80
here is the metal rod to remove on the sitting part
and the 2 sides must be removed from the foam or is the arrow
      02-20-2018, 07:53 PM   #129
cossied
Drives: 2008 z4 3.0si
m4 seats
Hi, I have fitted the M4 seats in my 125d, wired the power and Kcan and had the electric seat option coded. My car came with heating but no power seat. The electric adjustment works and lumbar but the memory feature doesn't neither does the heating as I suspect the car is still using Linbus to control the heat. Do I need more coding done ? Thanks Ed
      02-21-2018, 12:29 AM   #130
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
have you added the following option
S459A=Electric seat adjustment with memory
S494A=Heated seats
      03-09-2018, 06:25 AM   #131
Bibopp
Drives: BMW M235i
Salut David, petite question niveau confort :
que donnent les jantes en 19 niveau confort ?
J'ai celles d'origine en 18 et suis pourquoi pas tenté par des 19 mais j'ai lu plusieurs avis indiquant que du 19 sur le chassis de la M235i, état donné qu'elle n'a pas ete concue a la base pour du 19, peut faire perdre en confort et la rendre trop " dur / raide " sur routes degradées.
Merci à toi
      03-10-2018, 12:19 AM   #132
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Merci à toi
Salut Bibopp
C'est légèrement plus durs en mode sport mais pas raide non plus avec des
pneus non runflat par contre avec des pneus runflat c'est surement un peu
plus raide.
Je connais une personne qui est monté en 20 la oui cela doit être durs
