07-26-2016, 05:36 PM | #23 | |
Rep 630
Drives: 2021 G80 M3
09-03-2016, 10:39 PM | #25 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
How can these sport tunes even claim 14 or 15 psi and only put down 302whp on a dyno jet at that. Just curious that's all :
FBO-PS1 and stuff
FSociety3812.50 |
09-04-2016, 09:17 PM | #27 | |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
I think the issue is with companies claiming HP numbers strictly for marketing purposes. If Dinan was to try to sell a sport tune as a 10WHP gain, they would sell approximately zero. However, claiming X HP on a dynojet sounds better so they can market it. Its just slightly misleading when you actually break it down... |
09-13-2016, 08:24 AM | #28 | ||
Dejan
1753
Rep 4,197
At that point no amount of marketing or dynojet gimmick numbers will make a difference.
FBO-PS1 and stuff
09-13-2016, 08:49 AM | #29 | ||
Rep 3,129
As far as the numbers go there is no manipulation of these numbers for "marketing purposes". The test in question in this thread simply had everything going against it with a hot/humid day and 91 gas. Considering the conditions it was run a 10/35 gain is pretty respectable. Max gains on the platform would be 30/40 so its not like its that far off. The horsepower loss in delta is expected given that would occur at the upper end where the car is pulling back due to the heat it was run in. |
BMWZ41909.50 |
09-13-2016, 11:10 AM | #31 | |
The Schwab
473
Rep 1,605
I appreciate the acknowledgement of a superior flash tune, and I totally understand its not for everyone. I just wanted to at least share some other perspectives with potential buyers that think they are going to be grabbing an additional 30/40 to the wheels with a $300 boost controller. Its simply not realistic. |
09-13-2016, 12:11 PM | #32 |
Rep 5,372
How is using a Dynojet "fluffing" the numbers LOL Perhaps you're new to the game, but news flash, manipulating numbers on a Mustang dyno is REALLY easy. Since you can vary the load, you have a ton more control. This is great for all out tuning because it lets you tune for varying load conditions. It also allows for sneaky individuals to manipulate the numbers. Period. A Dynojet is simple. It's a weighted drum. The car spins the drum over a set amount of time and TQ (and HP) is derived. Damn simple and the readings across machines throughout the country are relatively consistent. The only way to manipulate the numbers with the Dynojet is to screw around with the correction factors, strap the car down excessively tight, and/or take heat soaked numbers and use those as baseline and compare to a "cold" run (i.e. stronger numbers).
Dynojets are great for gauging power gains assuming you're using the same machine and ideally the same overall conditions and cool downs. Strap the car on, run it a few times to get baselines. Install mod, run it a few times, and then compare average numbers across the graph. It's not rocket science. The gains/losses are what they are. If the car gains 30-40whp/wtq across the powerband, then the car will be about .3-.4 seconds and 3-4 mph quicker/faster in the 1/4 mile. With that said, gaining 40-50whp/wtq across only a small portion of the powerband will not result in a much quicker car. Hell, you could gain 50whp/wtq from 6000-7000rpms and the car will hardly be measurably quicker/faster because you're only in that range for a very small period of time. You need to look at the overall powerband. If the mod elevates the powerband across the entire rpm range, the car will be much quicker/faster. If it only elevates the powerband on a few spots, then the car will likely not be quicker/faster. Aftermarket intakes are a prime example of this. Gaining 15whp from 3500-4500rpm will not make the quicker/faster. I promise. |
09-13-2016, 01:39 PM | #33 | |
The Schwab
473
Rep 1,605
You also mention "sneaky" individuals manipulating data, yet that points right back at the manufacturers that advertise this stuff. Take a look at the Dinan graph. "Dinan Measured Max HP/TQ - 362/375" - sorry, but to the untrained eye that is misleading. To further your point of usable HP - the advertised gain is at 4k RPM, but then drops by 30% at 4.5k RPM, and never goes up again. So I stand by what I said about it being misleading. Look, most manufacturers do it, so I am by no means singling out Dinan. It is just unfortunate for the first time modder to pick something like this up, assume they are going to get 30 WHP, only to find out they gained a whopping 9 WHP, and probably less in real world testing. |
10-03-2016, 09:37 PM | #34 |
Rep 27
I installed this over the weekend and can attest that the difference from 3k to redline is quite noticeable. You'd be hard pressed to feel a 10hp increase, my butt dyno tells me that gains are much more in line with a 25/35 bump in hp/tq
For <$300, it's great bang for the buck. |
BMWZ41909.50 |
10-04-2016, 05:26 PM | #35 |
Rep 122
The majority of piggyback tunes are a great bang for the buck. I too have a Dinantronics Sport and am happy with it. The best test I did (for myself) was to use the tune for a week and then take it off for a few days. There is a Big "dyno-butt" difference.
10-04-2016, 07:12 PM | #36 | |
Rep 5,103
Unless you have an iPhone then I guess you can't do that.
10-05-2016, 07:48 AM | #37 |
Rep 122
10-05-2016, 10:55 AM | #38 |
Rep 5,103
You could pick up a used android for something like $40...don't need a plan just the Bluetooth. At least you'd be able to fool around with the settings until Apple releases the app to Dinan.
Just a thought....
Bestia64.50 |
10-06-2016, 10:28 AM | #39 | |
3441
Rep 79,211
Different dynos, different cars, different elevation, humidity, ETC ETC all factor in. The delta is what matters and even that can be manipulated to extent depending on the conditions of the dyno. 1 quick example is doing hte stock dyno on a heat soaked car in the hotter part of the day. Then doing your glory run on a cold vehicle, cold day and first run of the day. Also ventilation of the area and the fans blowing on the vehicle will attribute to power gains/losses differences. So many factors. |
11-02-2016, 05:54 PM | #42 |
Rep 5,103
Here's the link:
https://itunes.apple.com/us/app/d-sp...169979276?mt=8
