2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Tune Recommendation for my Mods?
      06-29-2016, 12:02 PM   #23
kdog26372
Drives: 2015 M235xi BSM
Originally Posted by qafwfk7pNkou View Post
the AA8 is very difficult to install/uninstall due to location of one of its sensor plugs. I think it is an excellent piggyback but really not easy to take on and off.
Not true, it take all of 15 minutes to install this tune. If you are referring to the cam sensor plug, you just need to know how it comes off and then it is as simple as can be. You need a long thin flathead screwdriver and you slightly pry up on the ribbed tab while pulling plug to release, it's really quite simple. But, a flash tune will be better, so irrelevant to this post.
      06-29-2016, 12:07 PM   #24
kdog26372
Originally Posted by Info@EnzoPerformance View Post
The process is quick, once we receive the ECU it gets tuned and sent out same day, next day air.
So it's just a generic tune when done remotely or do I tell you I've got X and Y mods and you have a tune to match that? I'd think I'd want custom flash to support my setup vs. generic as that's what I have with the piggyback now.
      06-29-2016, 12:24 PM   #25
crbalch
The Schwab
crbalch's Avatar
Drives: 2020 AW M340xi
2017 BMW X1  [0.00]
2016 BMW M235xi  [0.00]
Good question, I am curious as well.
      06-29-2016, 12:33 PM   #26
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
Enzo has tuned dozens of f22's so he has flashes that will match your bolt ons.
If you want a DYNO tune to your car, you will need to bring your car in.
www.nybmwcca.org
Current Cars:
      06-29-2016, 12:36 PM   #27
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
I thought that was the way it operated, appreciate the input!
Wish I still lived in Stamford, I would be to Enzo in a heartbeat for a dyno tune. I think the flash will be just fine though!
      06-29-2016, 12:37 PM   #28
bryan_G01
bryan_G01's Avatar
1165
upgrade your charge pipe while the ecu is in the mail.
www.nybmwcca.org
Current Cars:
      06-29-2016, 02:29 PM   #29
Info@EnzoPerformance's Avatar
587
Drives: F10 M5 700R+
None of our tunes are generic, we have been working with these platforms for some time and have reached a point where we can package our tunes depending on application.
Bolt on components like intercoolers, intakes and chargepipes do not need a custom file and do very little to change the parameters where a custom tune is necessary. Downpipes, upgraded turbos, fueling etc is a different story. We spent weeks developing a solid calibration on ronanz N55 PS2 and now offer that tune as a package for customers who have a similar setup.
FSociety3812.50
      06-29-2016, 08:40 PM   #30
DfVgyCjmFQnu
Drives: 2015 m235i Auto Coupe
I had this tune on my car and returned it in favor of an Enzo flash tune.
The cam sensor is indeed the most difficult issue.
No way I could remove this tune in 15 mins, and definitely no way I could install it in 15 mins unless I had hands the size of a small child or woman.
      06-30-2016, 05:44 AM   #31
BentZero
BentZero's Avatar
What about warranty issues? Supposedly one of the benefits of a piggyback tune is that you can remove it and the dealer won't notice that you had a tune installed. I'm guessing that they'd notice an ecu tune. Also, if for some reason my ecu needs to be flashed for some repairs or whatever the ecu tune is gone, right?
      06-30-2016, 05:44 AM   #32
BentZero
BentZero's Avatar
What did you think of the AA8?
      06-30-2016, 08:26 AM   #33
587
We keep your factory file in our database along with your VIN specific tuned file in the event your ECU gets updated or erased.
Of course a reflash is on the house in the event you do lose your file
      06-30-2016, 08:49 AM   #34
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
From my understanding, the ECU flash is pretty untraceable. Unless you blow your motor and try to warranty it, BMW will have no reason to ever look into your ECU. My dealer is very mod friendly so I am not overly concerned, but no matter what, a tune can leave traces behind (piggyback or flash).
If BMW really wanted to dig, they would be able to find something, but I wouldn't worry too much.
      06-30-2016, 11:04 AM   #35
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Enzo,
Please clarify this for me.
I run e35 99% of the time. Do you have a specific flash (not dyno tuned) for that? If so, what happens if I'm stranded with only pump gas available to me?
Or..
Would I basically use a pump gas tune as my base flash? If so I assume the e35 will help, but won't take full advantage of the e35. I would just use JB4 stack map 6 to get the most out of the e35?
Thanks.
      06-30-2016, 01:07 PM   #36
kdog26372
Well I have normal man hands and it's a 15 minute job. I find the cam sensor quite easy to get off with a long flat and skinny screwdriver. I'm sure the Enzo is a better tune option, but I wouldn't go with a RaceChip because of fear of the camshaft sensor that's for sure.
      07-09-2016, 09:29 PM   #37
Michall
Drives: 15 M235i
crbalch I can't PM you anymore
"crbalch has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
      07-10-2016, 11:05 AM   #38
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
Fixed
      07-10-2016, 11:14 AM   #39
Michall
Drives: 15 M235i
Originally Posted by crbalch View Post
Fixed
      07-10-2016, 01:21 PM   #40
DfVgyCjmFQnu
I liked it! No problems at all with the software itself. I ended up going with Enzo for much more power and the ability to have a CEL delete for a catless downpipe.
The AA8 was far more time consuming for me to install/remove than I expected due to the cam sensor connection. I was looking at a piggyback as a removable solution for dealer visits. However, removing and reinstalling was too much effort.
I'm sure many other people have no problem with the AA8. My free time is very limited and it simply took too long.
      07-10-2016, 02:37 PM   #41
BentZero
BentZero's Avatar
Sweet, thanks for the info. AA's site says that the install takes about an hour. I'm intrigued by the Enzo tune though. That much more power seems like it will shorten the life of the engine a decent amount though. :/ Any concerns there?
Build thread
      07-11-2016, 05:26 AM   #42
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
I am also located in the Chicagoland area. I contacted ENZO tuning about 2 months ago. They told me to contact Jonathan or Chris from Midwest Performance Cars for removing the ECU. The only thing which is holding me back is that my car is my DD so I need it everyday and the whole process will take at least 3 days.
Maybe in the future there will be a dealer which does the ECU tuning in our area.
Anyway, IMO the ECU tune is the way to go.
I'm a Chicago based Flash tuner just returned from a 10 day tuning and training session in Brazil got my equipment all ready to go. Check us out ACF Performance we still have our old website up that's all in Portuguese but our new multi lingual site is going to be launched very soon. PM for more info.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      07-11-2016, 01:56 PM   #43
crbalch
The Schwab
crbalch's Avatar
2017 BMW X1  [0.00]
Anyone know of charge pipes outside of ER? Don't really want to spend $400 on them
      07-11-2016, 02:11 PM   #44
Michall
Drives: 15 M235i
Interesting. Do you have any info/data/dyno regarding the AFC Performance tune?
What's the price?
