F Chassis Tune Comparison N20/N26/N55/S55 - LAST UPDATE 02/12/2018 ** Active Added |
09-14-2016, 08:24 AM | #45 | ||
Rep 1,287
09-14-2016, 08:25 AM | #46 | |
Rep 1,287
09-19-2016, 08:35 AM | #47 | |||
Rep 1,287
09-19-2016, 01:13 PM | #48 |
Rep 190,750
09-19-2016, 01:35 PM | #49 |
Rep 1,287
09-19-2016, 01:41 PM | #50 | |
Rep 190,750
AFE gives you 3 psi Jb4 stage 1 gives you 4psi Map 1 offers more power than AFE
09-20-2016, 08:24 AM | #51 |
Rep 1,287
OK thanks. So either way JB4 will give me more power regardless of the stage. I appreciate you clarifying that for me.
09-20-2016, 10:14 AM | #52 |
Rep 190,750
Correct
09-21-2016, 09:06 AM | #53 | |
Rep 201
Drives: 2017 GT350
I remember reading this from awhile back from "N54 Mike" regarding the aFe Scorcher and its boost as I was always under the presumption it was 4.5 psi myself....... "It's based on the same analog technology as the BMS Stage1, only instead of being set to 3.5psi as the Stage1 is, they set it to 4.5psi. BMS prefers to have CAN bus access in place for the higher boost levels so keeps those for JB4 level performance. FWIW awhile ago BMS added the DB9 port back to their Stage1 tune so technically it can be adjusted from 0-6psi using the Stage1 interface and USB cable. So to match it up with the AFE set it to 4.5. The better solution though is to add the extra wires and JB4 box at that point. The rest of the connections on the harness are meant for upgrading to the JB4. The idea is you just swap the box out for $150, connect the extra wires in the harness, and have a full JB4." -Mike |
09-22-2016, 09:50 AM | #54 | |
Rep 190,750
As for the BMS comments, you are correct. BMS does not feel comfortable adding more than 3,5 psi without can access Stage 1 is never meant to be the tune for max power, this is a simple tune (easy install and uninstall) to make noticeable power for a cheap price. Users looking to get max gains should opt for a complete tune like the JB4 stage 2
09-22-2016, 10:00 AM | #55 | |
Rep 201
Drives: 2017 GT350
10-17-2016, 08:31 PM | #56 | ||
Rep 447
Drives: 2011 750i
So I'm leaning towards the A8 since I'm really not going to add DPs or any other big mods. I currently just have an AFE intake and don't plan on going any further. I'm also not a fan of having a unit that needs to be plugged into my ODB2 port and needs to be connected to the car's battery. Once I get into the car and have this unit setup to my liking, I just want to get into my car and go, the have the power be there when I want it. What do you think?
10-17-2016, 09:57 PM | #57 | |
Rep 190,750
01-29-2018, 03:04 PM | #58 |
Rep 190,750
Active Autowerke OBD Flash Tune
How: Connect Simon Cable to OBD port and upload your new map (No ECU removal needed). Pros:
Cons: Does not reset flash counter Price: Starts at $800
02-12-2018, 01:28 PM | #59 |
Rep 190,750
Correction about the last post.
Active OBD tune locks flash counter until stock map has been re-uploaded It also gives the user the ability to load stock map at any time
02-23-2018, 11:09 PM | #60 |
Rep 26
https://network.perfexpert-app.com/results/PEBSMH7QOO
To support the Simon3 I'll share my setup again. Nic at AA is helping me fix this issue I'm having with the flash, but the malfunctions lit up do not impact performance but it's annoying and shouldn't have anything lit up. I am not throwing any codes either. |
02-26-2018, 10:04 PM | #61 |
Rep 26
Upgraded to 3.5Bar sensor on my M235i with much smoother powerband with smoothing practically off, it's on the lowest possible smoothing. This run hit 28psi but later in the day I had a misfire in cylandar 4, but cleared the misfire, backed boost down to 23-24 and it's smooth. FYI - dinantronics sport in race mode with 97 octane had boost raise from simon3's 22psi to 28.5psi. Sport cat will be installed Thursday and I'll post more then to highlight the Simon3 success on my car. The constant pull feels amazing through the powerband. I'll be installing new spark plugs too because it's time.
441WHP 506WTQ https://network.perfexpert-app.com/results/DxFAS1fMF4 Last edited by Masterongear; 02-26-2018 at 10:12 PM.. |
09-19-2018, 11:49 AM | #62 |
Rep 190,750
Bootmod3 By PTF
How: Connect Enet cable to OBD port and upload your new map (No ECU removal needed). Pros:
Cons:
Price: Starts at $595
10-01-2018, 02:58 PM | #63 |
Rep 190,750
[*]-40 seconds flash time[*]transmission flashing
Added for BM3 pros
10-27-2018, 08:28 PM | #64 |
Rep 148
10-30-2018, 09:41 AM | #65 |
Rep 190,750
transmission flash does increase clamping force thus helps the extra power ( less slipping)
