01-06-2016, 10:20 PM | #1 |
Rep 272
228i M-Sport With New Wheels
I took advantage of Black Friday wheel sale and bought a set of Forgestar F14 wheels for stock PSS tires.
I switched winters tire with this setup since it hasn't been very cold in DFW area and took a few snapshots to share. Wheel specs are 18x8.5 +42 for front and 18x9 +45 for rear wheels. I weighted front wheel at 19.4lb and 20.6lb for the rear which are much lighter that the stock wheels at 25.4lb front and 26.2lb rear. |
01-07-2016, 07:55 AM | #2 |
Rep 219
they look good!
I was between these and the CF5Vs, ended up going with the CF5Vs, now I'm just waiting.. they're supposed to be here next week! Is that their "Textured Black" color? |
01-07-2016, 10:12 AM | #4 | |
Rep 272
I'm hoping that it will be an easy color for touch up. CF5V wheel will have been my first choice if they were available in 18" size. |
01-07-2016, 10:15 AM | #5 |
Rep 272
01-07-2016, 12:05 PM | #6 |
Rep 2,384
Springs seem to have been causing issues with the oem struts. Maybe look into ST coilovers? They are a reasonable price point and produced by KW i believe.
01-07-2016, 01:25 PM | #7 | ||
Rep 3,331
Heres a preview of how they came out on our other customer's M235 |
01-07-2016, 02:56 PM | #8 |
Rep 190,730
Looks great!
01-07-2016, 03:44 PM | #9 | |
El Capitán
521
Rep 2,652
That is absolutely perfect! Great job!! Spec's on suspension - doesn't seem as low as H&R Sport Springs?? |
01-08-2016, 09:51 AM | #10 |
Rep 219
03-16-2016, 02:46 PM | #11 |
Rep 3,331
03-17-2016, 09:56 AM | #12 |
Rep 219
03-17-2016, 12:49 PM | #13 | |
Rep 178
-roger
Current: '15 F22 EB 228i | M Sport | 6MT | Dinan | Rotiform | 35% tint | CF side mirrors Gone: '11 B8 A4 | '08 Infiniti G37 Coupe 6MT | '04 E46 M3 6MT |
03-17-2016, 05:22 PM | #14 | |
Rep 3,331
Perfect semi-aggressive fit IMO |
05-16-2016, 07:47 PM | #16 |
Rep 3,842
What offsets and wheel widths did you end up with? I was thinking of going 19x8.5 et44 and 19x9 et53. I've read on the net that this setup works without rolling the fenders or scraping. I would go with 235 tires front and 255 rear.
07-09-2016, 12:29 AM | #17 |
Rep 22
07-15-2016, 02:52 PM | #20 |
Rep 3,331
07-15-2016, 03:39 PM | #21 | |
Rep 3,331
At +45 it touches. I recommend a +42 or 43 max on the front, but if you run a tire that hangs over the edge of the wheel, theres a chance it'll rub the inner suspension component. The rear and tire setup should work great! We can get those specs with the Forgestars. Let me know if you'd be interested in a set! |
