10-24-2022, 09:37 PM | #1 |
Rep 250
N20 Oil Starvation on Track Commonalities
Are there any common scenarios seen from N20 oil starvation on track (e.g. tire compounds, powertrain mods, etc.)?
I've recently started tracking my 228 m-sport and don't want to starve the engine! Currently stock.
2009 Lexus GX470
10-28-2022, 10:35 AM | #2 |
Rep 93
I dont think i have ever heard of oil starvation being an issue on the N20 unlike the N55. i think the oil pan already has a small baffle that helps. However I do know that quite a few companies manufacture upgraded bearings for the N20 just like the N55. So you could upgrade to better bearings. Other than that, im sure using top shelf oil and possibly upgrading your oil cooler could help if you are running more boost than stock.
10-29-2022, 09:12 AM | #3 | |
Rep 250
I want to ensure I don't destroy the engine but also not trying to modify oiling if not needed. I don't plan to run r-comps ever on this car
2009 Lexus GX470
10-29-2022, 01:05 PM | #4 |
Rep 93
ahh kk gotcha, it was mostly on R comp tires that the N55 reported oil starvation issues. (once again, very few if any track the N20 so we dont have much info on it) But iv heard from multiple beemer techs that the bearings are a sort of Achiles heel on the N generation engines.
So i would look into upgrading to beefier bearings, you could also use motor oil that handles the thermal loads of the track better. I run liquimoly in all my cars. But funny enough my tech told me of another dude who had heating issues with the BMW OEM oil and even liquimoly. his car would drop into limp mode on track after 20-30m. He swaped to redline oil and it never did it again. So maybe consider using Redline oil and upgrade the bearings? |
10-29-2022, 05:15 PM | #5 | |
Rep 250
Appreciate the info! No plans for r-comp and keeping stock power. My 228i m-sport does have the dual radiators, so I am hoping as long as I keep power stock I wont have heating issues.
2009 Lexus GX470
10-30-2022, 11:36 AM | #6 | |
Rep 1,494
Redline doesn't have any secret sauce to it. Old Redline (this year formula) had a lot of esters and newer one has bit more PAO. Lot of ZDDP and that is it. You have a lot of other oils that have stout base and additive package. What happened is that oil he switched to has bit less resistance and that lowered temperature just enough to get him out of limp mode. It is possible in low altitude environment, but really is not appropriate solution. If limp mode is due to oil temperature, beefed up oil cooling is only way to do it properly. By the way Liqui Moly is mediocre oil. Average LL01 oil in Wal Mart has better performance than LM. |
10-31-2022, 12:05 PM | #7 |
Rep 210
Accusump or baffles or both. Otherwise don't take corners fast or you will eventually starve the engine. Pressure drops dangerously even on hard straight line braking with semi slicks.
It depends on your skills, the better ( faster ) driver you are, the higher the chance to blow the engine if you don't address this, and you can find a few threads about this topic on this forum.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger | LithiumNext Battery
10-31-2022, 12:22 PM | #8 |
Rep 105
You should review these threads:
This has some data about oil starvation. Navardi currently sells his baffling solution. https://f30.bimmerpost.com/forums/sh....php?t=1783473 This talks about accusump install on an N20. https://www.2addicts.com/forums/show....php?t=1816447 This thread has, among other things, images and links to a dry sump solution. I would be very wary of going that way as you lose the balancing shafts. https://www.2addicts.com/forums/show....php?t=1781019 There might be some good info on other threads as well but I'd start with those. |
12-28-2023, 05:44 PM | #9 |
Rep 19
Datalog with Navardi Baffled oil pan.
So finally got the Navardi Oil pan installed and got out on track to test it out. I datalogged the oil pressure using Bimmerlink. Overall pressures are looking good. The minimum dips are around 40psi. I haven't tried to correlate it to the track (if it's in corners or braking), but 40 psi as a low point doesn't seem too bad. Any thoughts, or info from those that have been datalogging with a stock oil pan? |
AmuroRay2353.50 |
