07-05-2023, 02:00 PM | #3 |
Rep 444
I fitted Vorshlag camber plates to dial in more front camber, and that allowed me to fit a square 255/40 on a 17x9et42. It requires a 5-10mm spacer in front and niw I've got around - 2.4 degrees of camber.
If youre not adding camber, the most popular fitment is a square 17x8.5et40 with 245/40's Apex F22 Fitment Guide
07-05-2023, 02:06 PM | #5 |
Rep 444
Swift Springs ~#250F/600R with a 1" drop. My Paragon Brakes rotor kit (stock size) very slightly changed my offset requirements. Im on stock dampers with Dinan Shockware recalibration.
07-05-2023, 02:42 PM | #7 |
Rep 444
The Dinan tune added some compression and dialed back the rebound a bit, which makes the car way more predictable in my opinion. The car bottoms out all the time (even when it was stock) so I feel the bumpstops are worthwhile as an upgrade because the car spends a lot of time on them
The OE suspension was competent enough for my skill level when I bought the car, so upgrading the plates, springs, bumpstops, and damper retune was a better and more economical path for me as I grew as a driver. I'll move to a motorsport-focused coilover eventually but the cost/benefit didnt justify it as a novice and I'm still happy enough with the current setup that im not rushing to swap it for coilovers until parts start wearing out.
07-05-2023, 02:58 PM | #9 |
Rep 444
I did plates first, then did springs, tune, and bumpstops at the same time so I dont have a specific answer. If you are experienced and can swing something like a Redshift Competition or KW Clubsport its going to have a higher ceiling for not much more money. I wanted to keep the variable dampers and see how far I could take them so I took a different route than most.
11-06-2023, 12:08 PM | #11 |
Rep 444
A company called MSS makes an adjustable height, EDC-compatible spring-and-collar system for the F22. I havent seen too many people opt for them because the cost and complexity puts them on-par with most entry-level coilover systems. MSS isnt very forthcoming on their spring rates, but claims to offer a "track" and "sport" oriented options. That should be enough to corner-balance the car like a coilover and keep it close to stock height while still retaining the EDC functionality as a middle-ground solution.
Nativo11.50 |
12-28-2023, 04:40 PM | #12 |
Rep 5,546
Ground Control offers a sleeve over height adjustable spring kit. Multiple F/R spring rates are available. I know it’s available for the F8x but it might be available for the F22. Addition of the rear weight jacker system keeps the rear spring from bending while compressing and makes changing the rear ride height easy.
MSS is popular on the F8x and G8x. As stated above, MSS refuses to release spring rates but their rear spring has a progressive triple spring rate. |
12-28-2023, 05:44 PM | #13 |
Rep 49
Has anyone had a oil issues once high “Gs” are achieved with -3* to -4* front camber combined with today’s Super 200 TW tires?
Would an oil baffled oil pan be needed? |
12-28-2023, 07:05 PM | #14 |
Rep 3,497
That seems odd.
The rates can easily be established by putting them on a spring tester. Of course, the product would first need to be purchased.
12-28-2023, 08:58 PM | #15 |
Rep 5,546
I have used that exact argument. Spring rates are easily established and so I’d the load-deflection curve of a progressive rate spring. They think their triple rate progressive spring is a secret. Not that you’d do it but a main spring coupled with two tender springs could be used to create a system with three different spring rates. MSS just won’t release spring rates. Doesn’t make sense.
01-02-2024, 10:32 AM | #16 | |
Rep 19
Also, what bumpstops did you end up running? |
01-02-2024, 02:09 PM | #17 | |
Rep 5,546
01-03-2024, 08:01 AM | #19 |
Rep 5,546
01-04-2024, 11:58 PM | #20 | |
Rep 444
01-05-2024, 06:29 AM | #21 | |
Rep 5,546
01-06-2024, 08:36 PM | #22 |
Rep 444
That's where I bought mine back in 2018. Harold was great to work with.
