02-16-2016, 07:52 AM | #1 |
Rep 351
Iced Brakes
I had a weird experience this morning and figured I'd share with the masses.
Here in the DC area we got a bit of icing last night. This morning, when I pulled my car out of the lot and applied the brakes for the first time I got ZERO response. It was like I was in one if those nightmares where your brakes fail. But, about a fraction of a second later, after more aggressive brake pressure, they bit and I stopped. Has anyone else experienced this ever? I've been though winters in up state NY and never had my brakes freeze like that. I'm not sure if it was the piston locking up or icing on the rotor. Thoughts? |
02-16-2016, 07:58 AM | #2 |
Rep 3,331
Can't say I've had this happen, but if all 4 brakes were unresponsive it is unlikely it was the piston.
It's most likely that some ice built up between your pads and rotors and it took a split second for that to cook off. The same way if your car sits for a long time, the rotors will rust up and your first brake will be extra-crunchy. I would not worry about it. If the car was older, it is possible to get air and moisture in the brake lines (which could freeze) but that's unlikely on a car that's only a year or 2 old.
Current: '20 X5, '18 M3 ZCP
02-16-2016, 08:02 AM | #3 |
Rep 5,577
On an icey road surface?
Were the wheels rotating or locked and just not activating the anti-lock brakes? ABS brakes can be fooled on sheet ice, where there is so little friction the actuators won't work and it thinks the car is stationary. Sometimes on ice with ABS you need to pump or let off the brake and reapply - some people say never pump ABS - but on ice that is old advice. |
02-16-2016, 10:16 AM | #4 |
Rep 818
I always check my brakes in my neighborhood before going out on public streets. This is something everyone should do.. it's like a pre-flight checklist.
I've noticed these brakes need a little bit of heat in them to work to their full potential anyways as well. |
02-16-2016, 10:48 AM | #5 |
Rep 351
Answer to questions: Brakes did not engage at all. Pedal pressed, car kept rolling. No ABS or icy response.
UPDATE: Car did it again after sitting for an hour at above freezing temps. Brought it to the dealer and they put me in a loaner. Service Manager seemed very concerned. I have also been noticing that the clutch has seemed to have less pressure behind it lately (3 days). We'll see what they say about it. |
02-16-2016, 12:22 PM | #6 |
Rep 3,331
Sounds like it's a likely an issue with your master cylinder then. Would be unlikely that all 4 brakes wouldn't respond if it was an issue with the caliper.
You may have some moisture in the lines due to a bad seal or some other issue.
02-16-2016, 12:38 PM | #8 | |
Rep 2,942
This definitely sounds like a master cylinder issue. In fact, the two failures you experienced sound like a redundancy system taking over at the MC.
02-16-2016, 12:53 PM | #9 |
Rep 5,577
A few years back Toyota http://www.thetorquereport.com/2009/..._vehicles.html
02-17-2016, 06:05 AM | #10 |
Rep 351
few years back....bmw. calling the dealer this am for an update. this issue seems likely due to the same engine, model year is off, but it's closer enough for me.
http://www.bimmerfest.com/news/72459...gerous-brakes/ |
02-17-2016, 06:26 AM | #11 |
Rep 130
I have the same problem and it will get checked out at the dealer this week. It happens in icy/slushy conditions and when there is a lot of rain, usually on the highway and after not using the brakes a lot. It will get better right after using the brakes but can return on the same drive.
I wonder if it has to do with the build up of material on the pads or rotors. I tend to use brakes very little - prefer using engine braking with the 6MT. May be the brakes just need to be used more to get rid of build up material? Curious what BMW will say. |
02-17-2016, 06:29 AM | #12 | |
Rep 1,247
I'd say it's much cheaper to replace brakes than to replace the transmission / clutch assembly. |
02-17-2016, 02:19 PM | #13 | |
Rep 351
Dealer found nothing wrong. Go figure. me and Heitzer are crazy,,hah |
02-18-2016, 02:53 AM | #14 |
Rep 195
This is BS, the fluid gets more viscous as the temperature drops. I have been on ice where the brakes haven't worked and I have been on a highway for 4+ hours at freezing temperatures when the brake pedal was as hard as a rock but still managed to transmit to me what the car, wheels, tires, and brakes were doing. In 2016 the enthusiasts on here are suggesting that his master cylinder is faulty? What a joke. The dude wasn't expecting his brakes to perform the way they did because he wasn't used to the temperature variation where he lives.
02-18-2016, 06:10 AM | #15 | |
Rep 351
I'm also confused by your insight. it seems like you're saying that in cold temps the braking gets better? but then say I didn't expect it to get worse...anways... I think the cold temps are affecting the system because as the temp drops the fluid contracts, maybe creating vacuum air bubbles, but that's what the fluid reservoir is for hmmm... Or the cold temps affected the vacuum assured portion if the braking system. these beasts are so complicated it could be a multitude of things. |
02-18-2016, 07:01 AM | #16 | ||
Rep 818
The cold temperatures lead the fluids to become more syrup-like (low viscosity) instead of an easy free flowing fluid w/ high viscosity. When the fluids are cold they transmit less feel to the pedal and feel slower to respond, leading most people to believe that they aren't working properly. A few pumps of the pedal in your driveway/parking lot/neighborhood usually helps at least a little just to get the fluids moving (Along with the clutch pedal). These car's braking systems really aren't complicated... a braking system is a braking system. There are many factors and components but the overall principle/dynamics is the same as any other car. |
02-18-2016, 07:46 AM | #17 | |
Rep 3,331
So either the OP's description of his brakes "not working at all" is an over-reaction, or there is something else going on with the lines/master cylinder. Brake fluid absorbs moisture, and if the brakes have not been bled since the car was new that should be the easiest solution for the dealer to have tried. If the dealer did nothing, I would simply go back, say the brakes feel mushy and demand that they be bled - it should be part of the 2 year service interval on the car anyways and included in the service.
02-18-2016, 07:51 AM | #18 |
Rep 862
Drives: '19 M2 '21 X5
I had my brakes freeze shut before when driving on an ice course for a day. Snow filled rims + warm brakes from heated driving = ice. There was a ton of wind that day so it happened pretty fast. I could brake the rears loose with power but the fronts were a no go.
Had to pull start the car with my truck ( which i brought as a recovery vehicle ) to break the fronts loose. From that point stopping became a 2 step process. Stop, wait 30 seconds, inch forward to brake the small amount of ice that formed before it got to thick. As for OP situation I am surprised that there wasn't enough pressure in the system to break a bit of ice if it had indeed "frozen"? I live in Canada and have driven the car through every temperature range and weather condition imaginable.-40 to +40. Wind Rain Snow Sun. My brakes always worked fine. From cold start to 3 hours later on the highway. |
02-18-2016, 03:17 PM | #19 | |
Rep 195
02-18-2016, 03:23 PM | #20 |
Rep 862
There is fairly minimal spring force available to "open" the pistons from the discs though. So they can freeze shut.
Happened to me and a GTR that day. It was bloody freezing though and the rims were FULL of snow. |
02-20-2016, 12:47 AM | #21 |
Rep 195
But instead of not being able to stop, the car would have the opposite effect, correct? The discs would still be in contact with the pads?
02-20-2016, 11:12 AM | #22 |
Rep 862
Yup i couldn't move the car as the front brakes were frozen to the discs.
Pretty unnerving unable to move your car when it is parked in the middle of a frozen lake. This wouldn't be a problem on an AWD car as the torque from the engine could break them loose. Or on the street where you have grip. But with RWD and rears on sheer ice ( not enough grip to push the fronts into rotating ) couldn't do anything. Fortunately the tow start worked because the next option was going into town to buy some antifreeze, warming it up, and pouring it over the brakes which i am sure wouldn't have been great for them. |
