03-15-2015, 08:30 AM | #1 |
Rep 397
Turbo Flutter Noise
I just installed my BMS Stage 1 recently and I noticed if I go WOT @ 1600 RPM in 5th gear (6MT), I hear the turbo flutter and I wasn't sure if it's supposed to be doing that? I have heard that the flutter sound is due to compressional surge which is detrimental to the turbo and engine? Please tell me I'm wrong! I hope I am
03-16-2015, 01:20 PM | #2 |
Rep 415
I have also got the same symptoms as yourself.
My initial thoughts were wastegate rattle as I also have the wastegate rattle on cold start if I hover the revs just above idle. However this disappears as soon as the cold start finishes, so I'm starting to think it isn't this. Hopefully like yourself it isn't something serious. I'm sure someone else can chime in |
03-16-2015, 04:07 PM | #4 |
Rep 397
03-17-2015, 06:26 PM | #7 |
Rep 926
you shouldn't hear any flutter. Compression surge is not good for your turbo. When i had jb4 and bms intake, it was a clean swoosh. i feel like some people here might be getting the term flutter mixed up
03-18-2015, 04:47 AM | #8 | |
Rep 415
I'm going to run my car on map 1 and and 4 to see if the noise is still there using these |
03-18-2015, 06:31 AM | #9 | |
Rep 233
I kno i got a similar sound with my grimspeed boost solenoid on my evo. |
03-18-2015, 12:27 PM | #10 |
Rep 926
03-18-2015, 12:29 PM | #11 |
Rep 926
03-18-2015, 12:38 PM | #12 |
Rep 233
03-18-2015, 01:41 PM | #13 |
Rep 415
03-18-2015, 02:50 PM | #14 | ||
Rep 415
Sorry I thought I had already replied to you. I'm starting to think it is the ewg in action. Due to my daily driving habits my ff and avg ign values increase which mean I hit psi values above my target. Maybe the ewg is working a bit harder trying to keep me around my boost targets? I'm not sure if BMW GENIUS is getting the same thing but the more I think about it the less worried I am. My logs were checked over by Russell at BMS and everything was fine. |
03-18-2015, 03:25 PM | #15 |
Rep 415
03-18-2015, 04:29 PM | #16 |
Rep 757
I can just make out the sound with my exquisite earphones... I think the N20 makes a similar sound. No idea what it is but I have a feeling its normal. Kind of sounds like its building pressure or pushing air through something and it does it at a weird frequency. I believe I've noticed it on my 28.
03-18-2015, 05:35 PM | #17 | |
Rep 415
