01-04-2018, 08:09 PM | #1 |
Rep 28
Car won't keep time...CEL is on
I posted this in the tuning section, but didn't have much luck getting any responses. Hoping someone might have an idea where to begin!
My 2015 M235i won't keep time...in that the time displayed in both the instrument cluster and nav screen never changes. You can set it, but it'll never advance, either in automatic mode or manual mode. Additionally, the car has thrown the codes of P15FD and P15FB, which both relate to "Engine switch-off time: Too slow during engine operation" and "Engine switch-off time: Too slow during after-run" Would it be safe to assume that because the clock isn't 'ticking', that it's thinking the engine is 'dieseling' after shut-off, thus tripping a code? My rationale in thinking this is that further reading about these codes indicates "The diagnostic function compares the internal timers of the DME and the instrument cluster when the ignition is switched on again while the control module is in its shutdown phase" Could...could a simple battery disconnect kick start this damn clock??
2017 ///M2 Long Beach Blue M6 Last edited by Draab2006; 01-04-2018 at 08:29 PM.. Reason: Poor formatting |
01-04-2018, 08:16 PM | #2 |
NewFinishColumbia/detailer
604
Rep 2,096
That's the first thing that I thought of after reading your post. I would try that and leave it disconnected for at least 20 minutes before hooking it back up. After you get it back together then try and set everything again, drive it, and then see if the codes come back.
01-04-2018, 08:25 PM | #3 |
Rep 28
Glad to see I'm not the only one who thought that...I will do that and report back. My web searches hadn't yielded many results about these codes in particular, so if I can solve this hopefully it'll help someone else in the future. Thanks!
2017 ///M2 Long Beach Blue M6 |
SteveInfante604.00 |
01-06-2018, 12:03 PM | #4 |
Rep 28
Yep...disconnecting the battery for 20 minutes fixed the issue. What a strange anomaly; glad it was simple! Hope this helps someone else in the future.
01-06-2018, 03:06 PM | #5 |
604
Rep 2,096
I'm glad that worked for you. Now we know....
01-06-2018, 08:14 PM | #6 |
Kingslayer
411
Rep 1,479
That's a happy ending. Glad it worked out for you OP.
12-21-2019, 02:08 PM | #7 |
Rep 14
Hello Draab2006
I have the same code P15FB on my '14 328i xdrive - External Engine Off Timer Incrementation Too Slow During Engine Running My clock is also frozen. My car was coded in 2015. Has yours been coded? I am going to try and disconnect the battery for 20 min and see what happens. Last edited by Dimundz; 12-21-2019 at 03:37 PM.. |
12-22-2019, 08:42 PM | #9 |
Rep 86
Just stumbled on this and what a big help! I had my car running on battery during testing of new retrofitted lights and afterward it has not kept time - every after two resets. I'll have to try the tactic of disconnecting the battery to see if that solves my issue.
Thanks for posting!
Current: 228i M Sport
Former: E85 Z4 3.0, E89 Z4 35is, 28 others.... |
12-22-2019, 10:27 PM | #10 |
Just Copacetic!
177
Rep 616
Our cars are computers on wheels - similar to re-booting a computer solves the problem! Good to know, thanks!
'01 X5 3.0 AlpWhite
