12-28-2017, 11:52 AM | #1 |
Rep 205
low engine coolant level at 20,000 miles?
Hey everyone,
so last night I was driving home from work when the "Low engine coolant" sign came up on the dash....when I started the car this morning the light immediately came back on. I was worried about it and took it to a Midas just down the street from my home. I watched the technician put about 2 quarts of coolant in the resevoir. The car is about 2.5 years old with 20k on the odometer. The light went away but I was worried about a possible leak somewhere so I called my BMW dealership and told the service rep who nonchalantly stated that this was normal for BMW turbo engines, but couldn't really explain to me why. He said that during routine service they always make sure to "top off" the engine coolant, and that if the low coolant sign came up that I could "swing by to get the coolant topped off" I've never had to replace the engine coolant of any of my other cars (non-BMW) before and wanted to get other thoughts on this? Should I be worried about a potential leak somewhere?
2016 M235i xDrive - Estoril Blue - Coral Red - 35% ceramic tint - M Performance Exhaust w/ chrome tips - Dinan spring set (1/2 inch front 5/8 inch rear) with bump stops - JBSpeed paint matched spoiler - paint matched mirror caps - black kidney grille - BimmerTech backup and front-view camera retrofit
12-28-2017, 12:17 PM | #2 |
Rep 5,577
12-28-2017, 03:21 PM | #3 |
Rep 177
I've had 3 N55 BMWs and all needed an occasional coolant top off when they were newer. Not sure why either. Don't need to top them off anymore. No problems noted. Oldest car has 86k miles and still going strong.
12-28-2017, 03:42 PM | #4 | |
3626
Rep 3,592
12-28-2017, 04:04 PM | #5 | |
Rep 2,067
My guess is that they have a shitload of overpriced BMW coolant which they need to move - and they've found a way to do it.
2019 X2
12-30-2017, 01:07 PM | #6 | |
Rep 213
2014 M235i
2015 X1 xDrive28i M Sport 2009 Cooper Clubman 1999 Wrangler Sahara 1995 318ti Club Sport |
12-31-2017, 07:17 AM | #7 |
Rep 176
I find this very interesting and concerning. In my long career as a backyard mechanic, if your using coolant and there's no visible leaks, you have a head gasket problem.
It would be interesting to hear comments from a BMW mechanic about why their engines are using coolant. Somehow I don't think it to add some water to the cylinders to keep the pistons washed off. For those who have had coolant added, have you checked the oil to see if it is contaminated? |
12-31-2017, 10:50 AM | #8 |
Rep 1,931
can use distilled water if your in a pinch.
www.nybmwcca.org
12-31-2017, 10:56 AM | #9 |
Rep 5,577
yes, in the summer it may even cool better, In the winter you need to make sure the distilled water isn't diluting the freeze preventing capability of the coolant.
I think coolant also adds rust inhibitors and seal conditioner is that's one reason not to run straight distilled water in the hot temps. (Bryan, I thought you were asking - then I reread) Last edited by overcoil; 12-31-2017 at 03:32 PM.. |
12-31-2017, 03:12 PM | #10 | |
Rep 213
And UOAs have yet to find any evidence of coolant in the oil.
2014 M235i
12-31-2017, 05:42 PM | #11 | |
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
amw896582.50 |
01-02-2018, 09:28 AM | #12 | |
Rep 1,091
Perhaps a similar issue here? Piotr PS. Of course I'd check for any obvious traces of leaks or oil contamination - but with none found, just give it some more time and not sweat about it to much...
previous: 2003 E46 330i SMG
01-02-2018, 04:08 PM | #13 |
Rep 205
After hunting around on the forums, it seems that this is not an uncommon issue with BMW's...
here's a 6 page thread on the 3 series forum regarding coolant loss with the B58 engine: http://f30.bimmerpost.com/forums/sho....php?t=1324221 From other posts, it appears the low coolant light is coming up around mileages of 3k - 20k. Many theories speculated (underfilling from the factory, evaporation losses, turbos internally leaking, etc) but no definitive answers for why this is happening...at least one guy had his turbo charger replaced by BMW for persistently low coolant levels.
01-26-2018, 07:02 PM | #16 |
Rep 205
how many miles were on the car when this was happening? And what was BMW's explanation?
01-26-2018, 08:01 PM | #17 | |
Rep 623
They didn't explain the issue to me or the dealership, just told them to stop taking apart the engine and replace it when the service department contacted them. I suspect its a potential fault with the b58 they know about and are trying to keep quiet. I'm probably trading this for an RS3 once the works done because I don't want to deal with this again out of warranty |
01-26-2018, 08:18 PM | #18 |
Rep 1,117
Drives: 2015 BMW M235i
B58 posts will hopefully not turn into the focus RS forums. Good luck fellas!
01-26-2018, 09:18 PM | #19 |
Rep 913
My experience has been different - needed a top up when we got those steady 20 degree days over the holidays. Not since. I am @ 18,000 miles.
01-27-2018, 08:15 AM | #20 | |
Rep 478
'22 M440xi GC (BSM/Tacora) Previous: 2017 M240i Convertible; 2016 X5 50i; 2017 Boxster 718s; 2012 328iT Sport; 2009 X5 3.0; 2006 M3C; 2006 530xiT; 2003 325xiT; 2002 330i Sport; 2001 Z3 2.5; 2001 330i.
01-27-2018, 10:54 AM | #21 |
3626
Rep 3,592
There may not be a need for a fix, this could be a one-off failure due to something such as a casting inclusion or may be something benign, besides the possibility of an inherent defect. The factory would want the engine back as undisturbed as possible to troubleshoot the problem, even if the dealer could have fixed it easily. The B-series modular engines with common parts have been on the market for almost 4 years now, so an inherent major problem is quite unlikely.
01-27-2018, 11:45 AM | #22 |
Rep 400
Agree
If there was some major issues (either design or manufacturing), it should've taken care already. One thing that worries me is the leak from turbo. If it leaks from turbo after the warranty, it's very expensive fix. |
