12-25-2017, 10:51 PM | #1 |
Rep 211
On FBO with JB4. What's next: BMS meth kit or ECU tune?
Hi guys. My car is 2014 M235i, FBO (CAI, ER CP, forge BOV, wagner FMIC, catless DP, exhaust) with JB4 + EWG connector. I am limited to running Map 1 or Map 5 due to less than ideal gas here. However, I tried Map 2 and I'm hooked. With the news of F series N55 DME being cracked and thus being able to flash the ECU from the OBDii, I am at a crossroad. BMS meth kit or ECU flash (when the OBDii tuning is more mature) or both?? Some questions (note: I am a newbie in ECU tune and meth, so please bear with me):
1) Which will make more power better: BMS meth kit or ECU flash? 2) If I decide on ECU flash first but I want more power later on, can I use the meth kit with the ECU flashed? Do I need to re-flash the ECU again with a map which is tailored to the meth? Or can the JB4 control the meth which can be integrated with the flashed ECU? 3) For those using BMS meth kits, what size tank are you using and where did you install it? Pics appreciated. I have seen a thread here where the user placed a 1 gallon tank at the small trunk compartment. (http://www.2addicts.com/forums/showthread.php?t=1368013). Can the 2 gallon low profile tank be installed there? I need to have some luggage space in the trunk, so the small trunk compartment is my best bet for installation. Any help is appreciated. Thanks! |
12-26-2017, 07:32 AM | #2 | |
Rep 1,184
My best guess is that they will net you similar power although they achieve that power differently. Methanol will help with power by raising octane, increased fueling and lowing iats. This can allow for increased boost and increased timing advance. Ecu tune can alter these parameters with the tune itself. I am much less familiar with this so someone else can chime in. I plan on having both eventually. You can do an ecu tune and run the jb4 as a methanol and boost controller. I believe you can use methanol with an ots non methanol specific tune as the car will compensate for fueling to some degree. You'd get more benefit from having a methanol specific tune though. At this moment I plan on going with a ots bootmod3 tune in the spring. From there I will get a methanol tune made on bootmod3 and have the freedom to switch between them if I ever need to. *Don't quote me on the power, but from what I've read you can get wmi numbers from a flash tune. I also feel like there are a lot of cars running jb4 and getting similar numbers to ecu tunes. My opinion is that if everything is running perfect and the ambient conditions are perfect you have the potential to run like an ecu tune. Ecu tune will always feel great. I'll let someone else jump in and give a more technical answer. Last edited by jmwilson125; 12-26-2017 at 09:53 AM.. |
12-26-2017, 10:25 AM | #3 | |
Rep 211
I have a few basic questions about the BMS meth kit if you don't mind (BMS website doesn't have that much FAQ on the kit). Say you were on Map 2 before installing the meth kit. After the install, you set the JB4 to map 3 correct? Can't use Map 2 anymore? Is Map 3 like Map 5 (auto tune) but with meth integration? If I like Map 2, can I set up the meth map with similar power delivery to map 2? Also, what are you using for methanol? What ratio? What does BMS recommend? Ok, let me get this straight. For using both an ECU tune and meth kit, the easiest (and laziest) way is: 1) ECU tune first without meth (tune sets boost levels), and then add meth kit and use JB4 as meth controller. For even better power: 2) ECU tune with meth (but this may need multiple logs and back&forth with tuning company to create the optimal map), ECU tune also sets boost levels, and use JB4 as meth controller Is this right? Is back-end flash necessary in the above situation? I am guessing back-end flash is for the power hungry/really keen fellas since BEF will need to tinker around with JB4 to control boost and meth? Any experts around here who can give us some wisdom as well? thanks! |
12-26-2017, 12:22 PM | #4 | |
Rep 1,184
You will probably have some people tell you that's a hack way of doing it. You can decide for yourself. Cheap windshield washer fluid is water, methanol, and dye. Heet is 99% methanol and 1% additive. Some people don't like the fact that there is 1% additive, because they are not sure what it is. A good way to get more info on this is to Google the specific product like " AutoZone -20 winshield fuild msds sheet". The msds is the material saftey data sheet and will tell you the chemicals used. You could probably call or email the manufacturer if you wanted more info. As far as mixing goes, I like to take wiper fluid and mix in heet till I get 80/20 by volume. You can calculate this out. It will vary depending on the wiper fluid used. Just be aware that mixing by weight and by volume are different, but are fairly close. I'm not sure that BMS recommends one concentration over another. I think it's probably best to start at 50/50 and work the mix up higher doing logs. Approximate prices; Boost juice (50/50) $11-12 per gallon Canadian -40 wiper fluid (50/50) $2 per gallon US -20 wiper fluid (33/67) $2 per gallon Heet (99/1) $1.77 per 12 ounces Denatured alcohol (100/0) $15 per gallon Map 3 is not like map 5, it does not "auto tune". However, boost scaling is set based on octane. For 91 octane use 30 scale, for 93 octane use 40 scale, for 93 + e35 blend use 75. That scale corresponds to the maximum boost the jb4 will target. I believe 75 will target a Max boost of 20psi. 40 will target closer to 16-17 psi. Jb4 should achieve 100% of target based on the avg ign value. If you are between 0-2 I think you hit full target. If you are between 2 and 6 you may hit slightly less than target. A higher octane give you a lower avg ign. I believe avg ign is derived by the jb4. All said and done I'll run mine on 93 pump the meth additive set between 50-60. I see a consistent 17-18psi tapering down at redline. My ignition advance is usually between 6-12. I believe you are correct with the ecu tune and jb4. Personally I would run just the ecu tune with no meth. After I was comfortable with that I would have a methanol specific map developed. And yes this could probably be done with logs back and forth. The best way would be in house on a Dyno if possible. It is also possible that someone else that is fbo with meth could have a map developed. The tuner could likely sell you the same meth map with good results. However, every car is differnt, so the best way to do it would be to do one for your specific car and mods. I am not exactly sure what the BEF would be compared to a normal flash. As I understand you can set the jb4bto be inactive and only control meth flow. So your car would be ecu tuned and using jb4 for meth control only. I know some guys have had flash tunes done and they use the jb4 to control boost only. Some guys on pure stage 2 will use 25 psi as "kill mode" and daily drive at 18 psi. I believe that is switched via jb4. I forgot to mention this above, but the default setup only uses meth in map 3. If you were about to run out of meth or didn't want to use it for some reason you can always switch back to map 2. Also imho you will not need to run meth on map 2. The power delivery of map 3 is awesome. Map 2 is a little bit smoother though. Lastly apologies for typos and topic organization. Writing from a smartphone on lunch break. |
12-26-2017, 12:25 PM | #5 |
Rep 1,184
Take a look here too. I think that's the n54 engine, but meth setup is similar. http://www.n54tech.com/forums/showthread.php?p=159161
12-26-2017, 01:48 PM | #6 |
Rep 1,184
Also I'd check this out. Seems like there will be a lot of good options for flash tuning available in the next few months. You may want to hold off on the flash for now.
http://www.n54tech.com/forums/showthread.php?t=49716 |
12-27-2017, 04:05 AM | #7 | |
Rep 211
Is boost juice from snow performance? Don't think it's available in Asia. I think what I'll do is wait for a good ECU tune via OBDii, since it's much easier to install and less of a hassle. If I find the tune a bit sluggish, then I'll consider the meth kit. And thanks for the 2 links! Looks like there's a ton of info over on N54tech. I'll hop over there and take a look. |
12-27-2017, 10:14 AM | #8 |
Rep 181
Why not consider the h20 kit från burger tuning?
Why the need to tamper with ECU? I would never flash a map unless its from a dyno bench for my car - and then when selling the car you need to flash it to stock(or service/get into accident for insurance) If you need more control then just go standalone haltech, ecutek etc. |
12-27-2017, 12:43 PM | #9 |
Rep 190,687
I would do Methanol injection then turbo upgrade
Go with the largest tank available
12-29-2017, 09:08 AM | #10 |
3441
Rep 79,212
Probably easiest to source either windshield washer fluid, Heet or denatured alcohol if you can't get actual VP M1 Methanol.
I prefer to recommend denatured alcohol first as you don't know what kind of detergents are in the windshield washer fluid. Heet is ok but it becomes expensive and tedious with small bottles. |
01-02-2018, 01:49 PM | #11 | |
Rep 1,184
07-06-2018, 08:44 AM | #12 | |
Rep 211
1) Since I already have the JB4, cost is less with the BEF + BMS WMI kit than a custom flash tune with a standalone WMI kit 2) JB4 and BMS WMI: easier integration 3) I bought a family car, so I can now chuck a meth tank in the trunk of this one and not worry about trunk space jmwilson125, I have a few questions concerning the kit, hope you can help me out. 1) Does the BMW WMI kit comes with everything I need? Is the 20 feet meth hose long enough? Does it include teflon paste or thread sealant? Do I need purchase extra wires? 2) What nozzle spec are you running? I am thinking of dual CM5 nozzle since this is most common? 3) I am thinking of the 2 gallon tank in black color. Will I be able to see how much fluid is in the tank if I use the black tank? 4) Did you run the meth hose and wire in the interior or under the car? 5) According to the instructions, I'll need to prime the system after the install which means putting the nozzle in a bucket and pressing the prime/purge button on the app. Does this mean I'll have to remove the nozzle from the charge pipe everytime I need to prime/purge the system? This seems like a PITA since the nozzle connection in the charge pipe (I have the ER one) is quite low and facing downwards. Do I need to prime/purge if I change map selection (like from Map 3 to 5 and then back to 3)? 6) According to the instructions, Ill need to insert the FSB 12v power wire to the fuse box. Do I need to purchase an amp fuse? 7) Where did you install the filter? 8) Any regular maintenance needed apart from regular logging, inspection of bubbles in meth hose and look for leaking? Do you need to wash the filter regularly? 9) And lastly, any pics to show the whole set up? Thanks in advance!!
2014 BMW M235i auto. JB4 & EWG connector + BMS BEF (EWG Race 10 map) + BMS WMI kit (dual BM5 nozzles, 80% meth mix, Boost additive 50, Scaling 60, min flow boost 6.5psi), 98 RON/93 oct pump gas, intake, ER CP, Forge BOV, Wagner Evo II competition intercooler, ER kitty-less DP, eisenmann exhaust, quaife LSD
07-06-2018, 12:03 PM | #13 | |
Rep 1,184
07-06-2018, 12:14 PM | #14 |
Rep 2,214
Plan to do a BEF to accompany the JB4/BMS Meth setup myself, for next year. Should be fun!
I can't give up the ease of meth setup/tuning with the Bluetooth JB4 Mobile app, and ease of tune changing. Nice to be able to turn meth on/off on the fly, and make changes while driving. The integrated data logging, boost by gear options, and live-data gauge setup is also a huge bonus!
07-06-2018, 07:15 PM | #15 | |
Rep 211
I forgot to ask, how's the power deliver with WMI on map 3 compared to other maps? Is it as smooth as map 5 or with even more kick than map 2? PM sent for pics. Thanks again!
10-02-2019, 05:38 AM | #16 |
Rep 211
JB4 BEF WMI Dyno result
Finally had time for a dyno.
Just for sharing for those interested. 2018 run is FBO, JB4 map 1 or 5 (I forgot ). For the latest run, the car is same except with BMS BEF and WMI (see signature for settings) on map 3. Both runs using 98 RON / 93 OCT pump gas. Gained 25Hp at engine and 60.8Nm torque. Quite impressed. Not bad at all.
