05-17-2016, 08:00 AM | #1 |
Rep 84
Emissions Inspection w/ Catless DP
Hi all, I'm wanting to do a JB4/Catless DP combo but am required to pass annual emissions inspections (southwest PA). However, all that is required is an ODB scan and not a visual inspection.
Will the JB4 cover up the fact that I'm running Catless and fool the test or is there no way around it? |
05-17-2016, 07:24 PM | #2 |
Rep 358
If I'm not mistaken if you leave the jb4 on it ll just show that the sensor is "not ready" and you won't pass that's why I went catted so I don't have to deal with that btw I'm in RI we do inspections every two years
05-17-2016, 07:44 PM | #4 |
IG @bmwF9xG80
3816
Rep 7,593
Thats why a lot of people are getting ECU Flash by/from reputable tuner, their CEL delete from software will show readiness for inspections!
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
05-18-2016, 04:24 AM | #5 |
Rep 92
I was in your same situation with jb4 and catless downpipe. I tried looking for a tune that would do a downpipe fix but it was only available on the n54. I eventually had to switch back to the stock downpipe and do the drive cycle to get the o2 sensors ready for smog. Passed with no problems. Make make sure you set the jb4 to map 0 so the obd port can read.
05-18-2016, 02:18 PM | #6 |
Rep 275
05-18-2016, 07:00 PM | #7 | |
Rep 191,301
Your best bet would be to remove the DP once a year
05-19-2016, 01:32 PM | #10 |
3442
Rep 79,211
