05-06-2016, 07:40 AM | #1 |
Rep 1,184
Early Christmas
Unfortunately no I didn't stumble upon a large sum of money and buy every mod that I've wanted.
I installed my JB4 about a week ago. I was super excited, because as I turned my car on for the first time no CEL. O2 sensor and MAF senor codes had been cleared. In was enjoying the extra power for about a week, (roughly 50-100 miles)until I got another CEL yesterday. I immediately opened the JB4 app and Torque Pro to find the fault codes lit up like a Christmas tree. This morning I uninstalled the JB4 before work and still had the codes. They pretty much all seem to be sensor related codes that are pending. I am wondering if maybe the codes need 50 miles or so before the can decide if they are legit or not. Anyone else know if that is how sensor codes work? Anyone familiar with any of these codes or have any clue as to what was wrong? |
05-06-2016, 08:43 AM | #3 |
Rep 1,184
05-06-2016, 09:08 AM | #4 |
Rep 678
Just wondering if you deleted the codes after you removed JB4 and then popped the same fault codes again after driving around? Is the engine light on and acknowledging fault?
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
05-06-2016, 09:45 AM | #5 | |
Rep 1,184
I did clear from both jb4 and torque pro. |
05-06-2016, 04:25 PM | #6 |
Rep 191,382
I suggest you contact BMS, it is either a bad install (unlikely since it ran fine for 100 miles) , your firmware needs to be updated or just a bad Fuel Rail Pressure Sensor
05-06-2016, 04:32 PM | #7 |
Rep 439
Sorry to hear op...these kinda threads are the exact reason I plan to go the Dinan route.
2016 ///M235ix | MP Grilles | MP Pedals | Gloss Black M235i Badge | Dinan CAI | Dinan tune | Dinmann CF Diffuser | MP CF Spoiler | CF mirrors | M2 CF interior | M2 Steering wheel
05-06-2016, 04:36 PM | #8 | |
Rep 191,382
Bad install or bad firmware can happen with any product If the cause was a bad sensor then it has nothing to do with the tune Not sure how in this case Dinan would have been any better over the JB4
05-06-2016, 04:46 PM | #9 | ||
Rep 439
05-06-2016, 04:56 PM | #10 |
Rep 986
Uninstall the Jb4 from all sensors, clear codes, and see if any of them come back....
Did you happen to install a downpipe and swap the O2 sensor wires ? Did you check the seating on all the JB4 harness plugs ? If you connect with the USB interface to the Jb4 does it respond normally and provide normal logging output ? Have you tried updating to the latest JB4 EWG firmware? I've had mine for installed for about 15,000 miles... 10,000 i did all map1, then i installed a catless DP, and switched to map2. I have done about 5 track days (HDPE's) and i have had zero CEL's.. Unfortunately my brake pads have felt the extra boost Yes DINAN is Dinan, but there is no substitute for the JB4. It is a great value tune for HP/$ ratio with great support and logging. I doubt you will find a forum for the Dinan tunes with a ton of people offering to check out logs to assist with validating your install and make sure your JB4 is working up to far (n54tech.com)... Did you ?? Last edited by zipphreak; 05-06-2016 at 05:02 PM.. |
05-07-2016, 12:05 PM | #11 | |
Rep 1,184
I am not upset with BMS I'm just going to do a little more digging and reinstall and try it again. I have also just started talking with Terry @bms. I am sure I will get it sorted out. Also if you dig deep enough you will find that every tune has had its hiccups. Even Dinan. A couple people have gotten chassis malfunction codes with Dinan Basically you run the risk of throwing a code with any tune. You just have to decide if it's worth it to you. |
05-07-2016, 12:25 PM | #13 | |
Rep 191,382
You see more issues with JB4 than other tunes because on the forums JB4 sells more than all the other tunes combined
