05-17-2017, 09:21 PM | #1 |
Rep 317
Drives: Melbourne Red 2016 M235i
Misfire @ ~100+MPH
Hey folks.
BMS JB4 Stage 2 Map 2 @ 91 Octane (Don't judge me lol) ER Charge Pipe ER 4" Catless M Perf exhaust No codes thrown, but butt-dyno notices an inconsistent pull. Car went into limp (Drivetrain Malf) one time, but never saved a code (on car or JB4). I'm assuming I need to change spark plugs? Thinking NGK N20's. What have some of you switched to? Assuming my ignition coils are okay Don't mind changing those as well, just want to take it step my step. Can attach logs later, tomorrow after work. Cheers!
Past: 2008 BSM BMW 128i 6sp w/ EU spec interior.
Past: 2010 BSM BMW 128i 6sp +Msport 2016 MR BMW M235i Instagram @project_kristi |
05-18-2017, 03:26 PM | #2 |
IG @bmwF9xG80
3813
Rep 7,593
Post the message message here if you haven't already http://www.n54tech.com/forums/forumdisplay.php?f=35
You'll get some logs advice from more experienced ppl than on this forum and you're able to upload csv file on n54tech. I'll bet you they'll start off by saying map2 is prob too aggressive for your low octane
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
05-18-2017, 04:05 PM | #3 |
Rep 1,931
how much gas did you have in the tank?
If less than a quarter tank, the gas will slosh around to the back while on it hard, car will throw a CEL go into limp with drivetrain malf because no fuel got to the pump.
www.nybmwcca.org
05-19-2017, 02:46 PM | #5 |
Rep 1,503
I can almost promise you that upgrading coils will not help your inconsistency. Change your map and re log the car.
FBO M235i r
F80 M3 |
05-20-2017, 03:31 PM | #6 | |
Rep 317
05-20-2017, 03:31 PM | #7 |
Rep 317
05-20-2017, 03:39 PM | #8 | ||
Rep 317
Just looking for some quick spark plug advice (if anyone's in the same boat I am) not looking to upgrade coils. Maybe you could take the time to actually read the post without being rude? I run Map2 because I enjoy pushing the car. Get over it. Map1 isn't spectacular , and Map5 auto tune is totally bogus. Sometimes I go higher, sometimes I don't. I'm running 91 since I'm commuting so much right now. Don't need your attitude here, child. |
05-21-2017, 12:38 AM | #9 | |||
Rep 1,503
Your car boost level is too high for your fuel and your car doesn't like it, neither of which will be changed by changing to N20 plugs nor coils, plain and simple. Either way you need to post a log or no one can help you.
FBO M235i r
F80 M3 |
Drpoomanchu307.50 JP's M2xx20.00 |
05-21-2017, 09:23 AM | #10 | |||
Rep 647
To add, i believe Luminous and a few others are on stock ignition other than plugs making 550+WHP. Dont think thats an issue. |
05-22-2017, 03:06 PM | #11 | |
Rep 317
Cheers! |
05-23-2017, 08:43 AM | #13 |
Rep 1,931
I've been on the s55 plugs for a little less than a year without any issues.
Ppl say the ngk n20s are better, i have not seen anything to back this up. When its time to change them, I will go the n20 route tho.
www.nybmwcca.org
05-23-2017, 10:27 AM | #14 |
Rep 647
In what ways are they superior...? N20's are 2 steps colder than N55 plugs correct..? I was under the impression that S55 plugs were one step Colder than N55's. I always thought plug choice was relevant to application. Curious to hear your findings.
05-30-2017, 04:35 PM | #15 | |
Rep 317
Been reading good things. Side note, no issues in cold weather. So, I guess it's time for an FMIC.
