09-03-2020, 02:21 PM | #1 |
Rep 4
Harman Kardon retrofit on F22 Chassis
Hi everyone!
I've recently bought an f22 m240i Lci. Overall I'm very happy with the car but the sound system is nothing but desapointing. I know that HK was an option but my car did not came with it and to be onest while looking for the right 240 i did not came a cross many with this option. So with this in mind i made my way to ECStuning, where i find many upgrade parts of the HK kit but in most of them it implies that this are only compatile with cars that came with the HK option from the factoy. I'm aweare of the splicing requierd for the tweeters to be instaled but i wanted to know of any other issue or particularity that i should know before pulling the trigger. I'm planing on installing this miself so any help is appreciated. Is there any cooding requiered? Does anyone know of any other alternatives for a semi plug&play solution? Thanks! https://www.ecstuning.com/b-genuine-...t/51337269362/ |
09-03-2020, 04:05 PM | #3 | |
Rep 507
E46 -> E90 -> F30 -> F23
09-03-2020, 06:47 PM | #4 |
Rep 46
My recommendation is to get the Etons or Focals with the tweeters then buy the HK sails above the door no splicing required with that. Then do the JLs for the back deck they require some pigtails that can be had on ebay if you dont wanna splice. If you are still not satisfied you can put in the SWS-8XI underseats using technics spacers that allow for plug and play and if you still need more bass then you will have to do a dedicated trunk sub. Someone else can speak to replacing the amp cause i didn't do that.
MarcoZandrini447.00 |
09-03-2020, 06:58 PM | #5 |
Rep 8,942
For some reason = it's the lowest cost series and started at $30k USD. They saved money in lots of places, stereo system included. Believe it or not there's an even worse system below HiFi avail ROW.
09-03-2020, 07:18 PM | #6 | |
Rep 507
09-03-2020, 09:42 PM | #7 |
Enthusiast
84
Rep 229
Don't waste your hard earned $$$ on the HK. They have ruined it. If you are willing to spend the $, then go after market.
_______________________________________
2016 M235i XDrive Estoril Blue/Black |
09-04-2020, 02:21 AM | #8 |
Rep 533
I don't have the HK but what the standard system reminds me of the audio on a cheapy Costco-sourced TV that I once returned. I swear, the OEM Bose system on my old '91 Saturn had a fuller, clearer sound.
09-05-2020, 02:18 PM | #9 |
Rep 1,268
The F22 audio systems-hifi and HF-have several issues. First, the speakers are junk. The magnets are small and the cones are paper. The second issue is the amp. It's an adequate amp but it's not tune-able. Lastly, the digital to analog converters in the head unit are mediocre. Retail prices for 2 channel digital to analog converters on www.mouser.com range from less than $2 each to more than $60 each. The differences include sampling rate, conversion algorithm, bits, etc.
The first thing is to create a budget. Then start with the speakers. I recommend that you buy a pair of sails for the component tweeters. Then, select your speakers. Eton, Audiotec-Fischer, Focal all make direct replacement speakers for the front pair. The rears aren't as critical. I went with JL 2 way speakers. The next step is to buy a tune-able amp. I went with the Audiotec-Fischer MATCH 7UP BMW amp. It's tune-ability is daunting. But, I took my time and learned the software and experimented with it. I also added the Bluetooth module to the amp. I tried the USB module first, but my iPhone was finicky and sometimes would stop interfacing with the amp. The Bluetooth module has the latest Bluetooth and format capabilities. JL also make a tune-able amp but it's not plug and play like the Audiotec-Fisher amp, Lastly, chuck the subs under the seat. Like the other speakers they are crap. I'm still researching these. But, the Audiotec-Fischer amp can be tuned for which ever subs you install. |
JonOhh672.00 |
07-13-2022, 09:33 AM | #10 |
Rep 2
I just did this retrofit yesterday. I've bought the complete set with 5 speakers and 5 tweeters plus 2 woofers and one amplifier.
Please note my car is an LCI model that also has ASD right besides the amplifier. You will need two CAN wires + and - to connect the HK amplifier, because the stock one that comes from HIFI doesn't have CAN, but it's easy since it's on the same CAN bus as the ASD amplifier that sits right next to it. Also the speaker grills must be replaced from the back speakers. In order for the best experience use ISTA to code the car and also there is an update in 2021 for the iDrive that also includes an update for the HK amplifier. |
07-19-2022, 06:42 AM | #11 | |
Rep 103
Having formerly owned an F30 330D MSport fitted with HK, I can confirm the F22 HK system is somewhat inferior. |
07-23-2022, 05:00 PM | #12 |
Rep 733
Yeahhh, unfortunately this is one of those instances where aftermarket may be the way to go. F30 HK is pretty lacking compared to the E90 HK/L7 depending on taste (different/less lively surround upmixer, better amp, but generally worse speaker hardware and mounting depth), and the 2 Series HK is without a surround processor, and not as good as even the F30. It's more similar to the mid range BMW hifi systems used on older models, with no MOST loop.
If you can do without surround and rear fill, it has potential with aftermarket hardware though. Oh, additionally, I'm not sure if this holds true for the non-HK 2er amp, but you can code it to different cars which have different EQ and timings. Despite likely being "less correct", I found a remarkable improvement in the soundstage on our 16' F23 w/ HK by doing this- it's livable now. Last edited by JonOhh; 07-23-2022 at 05:27 PM.. |
04-03-2023, 04:35 AM | #13 | |
Rep 4
I'm facing the same issue. I have the Hifi equipment and doesn't come with CAN wires. Did you manage to code everything? Do you have to code itor will it work without code it? |
04-03-2023, 04:54 AM | #14 | |
Rep 1
I’m very interested too. I’ve purchased HK amp to replaced the stock Hifi Amp (674). The harness is exactly the same (no fiber ******ion in 2 series). But when I connect it, I’ve no sound. Suppose it’s need coding !? Thanks for help !! |
05-14-2023, 09:36 AM | #15 |
Rep 4
As far as I could find, HK amp needs CAN line and code it. I'm trying to get more info about how to do it but it's quite dificcult since people doen't convert from hi-fi to harman kardon usually.
05-16-2023, 01:26 AM | #16 | |
Rep 4
Do you know if the coding can be done with bimmercode? I don’t have ISTA so the only tool that I have right now for coding is bimmercode. |
Tags |
audio, f22, harmankardon, retrofit |
