11-10-2017, 04:08 PM | #1 |
388
Rep 889
weird deep resonance
over rough pavement, new snow tires, new MP exhaust. car has deep resonance from left front, sounds low down inside or below car. seems that the stereo can produce it sometimes as well. seems to be road speed dependent, not engine speed.
very strange and quite irritating. |
11-10-2017, 04:30 PM | #2 |
Rep 2,214
Could it be the "Active Sound"? It's the phony engine sounds that come through the stereo..
11-10-2017, 06:01 PM | #3 | |
Rep 1,184
11-10-2017, 07:14 PM | #4 |
388
Rep 889
ASD is off, plus this is much louder than ASD.
It’s a single tone, doesn’t rise or fall with speed or engine revs. sometimes there, when car speed over slightly rough pavement is right. something’s picking up and amplifying tire/wheel vibration or the like ... except it seems some notes from the radio will do it as well, but only sometimes. couldn’t get that to happen when stopped, so not certain on the radio thing. |
11-10-2017, 09:18 PM | #6 |
Rep 478
Stop worrying about stuff and enjoy driving your new car? I'd also suggest stop modding it, until you settle into every day life with it. Let it rest for 6 months or so, then figure out if you need to change anything more.
'22 M440xi GC (BSM/Tacora) Previous: 2017 M240i Convertible; 2016 X5 50i; 2017 Boxster 718s; 2012 328iT Sport; 2009 X5 3.0; 2006 M3C; 2006 530xiT; 2003 325xiT; 2002 330i Sport; 2001 Z3 2.5; 2001 330i.
CAMOETO140.00 |
11-10-2017, 09:21 PM | #7 |
Rep 56
Remove all variables first and re-examine. Empty cup holders, center console, glovebox, trunk. Everything. Had a weird resonance that was caused by a can in the door cup holder. Drove me crazy.
2016 F23 AW M235xi
11-11-2017, 05:47 AM | #8 |
388
Rep 889
it’s not the snows: i can hear them, too, and their tone is higher, more of a ringing, and changes with road speed. the resonance does not. plus, with window open, i hear them, but not the resonance, outside.
agreed on eliminating things by emptying the car, and i’ll do that. there’s not much in it, since it’s new, but there is stuff. it was not making the noise the first few days on the snows, nor first few days with MPE. Just started yesterday. It’s like a panel is loose, or possibly something underneath bumping, but it’s a low dull drumming kind of sound, not a sharp rattle. As for just enjoy the car, sure, but this is loud enough and resonant enough that even with radio loud, you hear it. on a trip it’d drive you crazy. natch, i’ll take it to dealer if emptying the car doesn’t fix it. |
11-12-2017, 07:01 PM | #9 |
388
Rep 889
Is the exhaust pipe from engine to rear on the left side of a left hand drive M240i? I just had the MPE put on before the noise started. I wonder if in hooking it up they may have allowed the exhaust to bump against the car somewhere along the way.
Guess not according to the pics I can find ... still, that's the most recent change before this weird drumming noise. |
11-13-2017, 02:12 PM | #10 |
Rep 2,873
Looks like you are thinking to bring it to the dealership, which would be my suggestion. Might be worth considering an alignment check, as that can give you a sort of low grinding noise (at least that was what tipped me off that I was out of spec). Also might try pulling the stereo fuse to see if that stops it, as a way to r/o the ASD and related stereo acoustics.
11-13-2017, 03:24 PM | #11 | |
388
Rep 889
I figure they might find something, might blow me off. If it's the tires I wonder if a different brand of snows from the Contis might be quieter. |
11-14-2017, 07:16 AM | #12 |
Rep 2,873
The tire noise I get tends to be very surface-dependent, so it will on-off as you hit patches of different pavement and vary with speed. Mis-alignment would tend to be more steady like you describe, may vary with turning. I suspect that my car was poorly aligned from delivery, since the noise I questioned had been there all the time, but went away once they corrected alignment. That start-up rattle may be a common feature of the sport exhaust valve - you can search for a thread here that does into a lot of detail about what is normal vs. stuck valve (but wouldn't expect it to give a deep rumble, seems more like it makes a rattle).
11-14-2017, 09:54 AM | #13 | |
388
Rep 889
11-15-2017, 07:22 PM | #14 |
388
Rep 889
I'm starting to think that the noise might actually be mostly the tires. Are the Conti WinterContacts particularly loud? I'm sure I'm getting some resonance, sometimes, from a body panel or the exhaust but it could be the tires starting things. I may have to find some grass to drive on as a test ...
11-20-2017, 04:13 PM | #15 |
388
Rep 889
Took car to dealer today and shop foreman drove it. He seems pretty sure all the noise is the ContiWinterContact tires. I'm not convinced but not willing to give them the car for a day to search for a sound he can't even hear.
11-24-2017, 09:02 AM | #16 |
Rep 1,608
What????? There's something louder than ASD?
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 |
