10-18-2017, 06:18 AM | #23 |
Rep 1,161
do you get the flag up on the dash to indicate launch control is active?
I noticed on the bimmercode app that there is an option to enable LC. but I ignored it as I have the 6MT and didnt think it was on the car. I'll go check it out over the weekend to see if it can be coded.
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
10-18-2017, 10:32 AM | #24 | |
Rep 1,117
Drives: 2015 BMW M235i
10-25-2017, 08:18 AM | #25 |
Rep 1,161
Just tried this.
Works on my 235i 2014MY. Accelerator full down and revs held at 3.5k. Off we go traction control lights flashing away. Lost concentration and forgot to change from 2nd to 3rdbefore the redline and the car pulled back automatic to avoid over revving. Was up to 60mph faster than I thought in 2nd gear. Will give it another go to properly confirm tommorrow ?
2014 M5
amw896582.50 |
10-25-2017, 12:09 PM | #27 |
Rep 286
10-25-2017, 11:42 PM | #30 |
Rep 2,214
I haven’t sent an m240i owner confirm, yet, however I’m thinking it can be coded in based on Bimmercode..
10-26-2017, 08:07 PM | #31 |
Rep 30
I have a 16 M235i and tried this as well but it worked in comfort, sport, and sport plus.
1st gear, p-brake off, clutch and gas to floor. it revs up to about 4.5k then stops responding to additional throttle input and settles back down to hold at about 3.1k. |
10-27-2017, 03:05 AM | #33 | |
Rep 1,161
So thanks for confirming already.
2014 M5
10-27-2017, 11:39 AM | #34 |
Rep 525
You can test this in your garage, if you wanted to. You don't have to physically move. Just see if you get the lower rev-limit with the clutch depressed. If it does, then you have LC. If not, then you don't.
Dylan861330.00 42395_skyline57.50 |
10-27-2017, 02:59 PM | #35 |
Rep 97
yeah i can confirm with my 228i that it seems to hold revs in comfort, sport and sport +. So I've never tried this but would i just literally mash the gas, take my foot off the clutch (no feathering). Will this damage the transmission or car?
10-27-2017, 03:10 PM | #36 | |
Rep 5,369
1) Cause wheel hop (the tires are spinning and catching, causing a violent movement and drivetrain shock) which could snap a half shaft. 2) The tires could grip instantly, directing all that power to the input shaft of the tranny and snap it. The best way to launch a car on street tires is with a decent amount of launch rpm (2,500-4,000rpms) and clutch slip where you're getting just a hint of wheelspin. This requires concentration, clutch/engine/tire feel, and a general disregard for clutch longevity. Too much clutch slip will burn the clutch. Too little and you might roast the tires or bog the motor. Wheel hop (bullet 1) or a complete bog (bullet 2) are the worst launch situations. If you ever feel the wheels hopping, push the clutch in immediately, DO NOT stay in it. |
10-27-2017, 04:39 PM | #37 |
Rep 525
I thought all BMW MT had the CDV..? If so, I wouldn't worry so much about breaking anything (and I can't imagine BMW didn't think that through before offering to the general public), although wheel hop might still get the really unfortunate. Still, XutvJet's advice is pretty solid.
10-31-2017, 03:55 PM | #39 |
Rep 1,117
Damn eh! Must be only pre 2017 models only. Must be something available in the coding though. Where are the software wizards?
11-12-2017, 12:22 AM | #40 |
Rep 509
Drives: 2016 M235i RWD 6MT
I just had my snow tires installed on Thursday, launch control would have no traction here. Will try it in April of 2018
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
11-12-2017, 02:12 PM | #41 |
Rep 5,369
