2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning PLEASE HELP! Cylinder 2 Misfire after coil and plug swap
      11-24-2023, 05:25 PM   #1
luperox22
Drives: 2016 BMW M235i
I need help. I did a complete spark plug and coil swap on my 2016 m235. Sitting at about 103k miles. This was done in prevent and the car ran perfect prior.
Now, I am having a misfire on cylinder 2 and the idle is atrocious. I have swapped coils, the misfire doesn't follow. I swapped the new plugs back to old, same cyl 2 code and the idle is even worse.
I truly have no clue what to do at this point and don't really understand how the car is now running like a bag of shit after it being perfect this morning.
Please help me figure this out.
      11-26-2023, 05:05 PM   #2
jb-slow
Drives: m235i
Check the pins in the connector, maybe one bent
      11-27-2023, 06:12 AM   #3
luperox22
Checked ‘em all, no avail. I unfortunately ended up having to take it to a shop. Hoping to hear something positive today. Thanks for replying
      11-27-2023, 10:06 AM   #4
XutvJet
I highly doubt it's anything serious. My guess is the insulators are cracked on two of the plugs, the gaps are wrong (should always stick to stock gaps in almost all cases), or these are knock-off plugs . Did you remove all the crap that was in your way to get to cylinder #2 or did you snake the plug in? Where did you buy the plugs from? Gaps checked?
