03-15-2015, 08:27 PM | #243 | ||
IG @bmwF9xG80
3813
Rep 7,593
Fanboy I didn't get your posts deleted, you're just causing headaches where it is not welcomed. And when you quote something quote the whole thing, I was a mb 2011 c300 owner and told them exactly why I was sharing the post and infact there are 2 more MB owners who have it on their MB cars and confirmed how good it is.
I stand on my words and here's the link http://mbworld.org/forums/c-class-w2...2hp-321tq.html (No longer works since he decided to report it and have the moderators close it) What's wrong with giving back to the forum of the car I use to own? Whats wrong with sharing information they might not know of? There are plenty of people on this board who share info with me. I was going to do the mistake of going with another tune, but my perfectionism made me delay the buy and found aFe scorcher but then found what made more, and the folks who have Racechip are all truly honest and great people. Stop thread jacking please thats why moderators are deleting your post. Thanks for stalking me btw Quote:
If anyone here has Android and wants to use Torque Pro (app) let me know I can PM you the details, it is great in data logging (WHP, WTQ, Ambient Air, Intake Manifold Pressure, Turbo Boost, 0-60 etc) . I use it with OBDLINK Lx which is the Scantool (Bluetooth) and works great. I also use Dash Command but it reads higher which we can assume like crank numbers.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 03-17-2015 at 01:11 PM.. |
03-15-2015, 09:58 PM | #244 | ||
IG @bmwF9xG80
3813
Rep 7,593
Went back down to stock setting today and going to bump up 1 at a time and continue data logging
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
03-16-2015, 08:22 AM | #246 | |
Rep 233
http://www.2addicts.com/forums/showthread.php?t=1098498 |
03-16-2015, 08:39 AM | #247 |
Rep 197
Is it safe to say that stage 1 tunes basically only add boost (some being adjustable) and that the more advanced stage 2 tunes also influence other parameters (some tunes being more customizable than others)?
Given that the stage 1 tunes only modify the signal from the MAP sensor, would the way (RPM, gear, etc.) in which these tunes modulate the signal sent to the ECU be significant, or do they just trick the ECU into seeing boost that is lower by a fixed amount across the board? If one adjusted the different stage 1 tunes to the same boost and compared them, would they perform differently or would they be exactly the same? |
03-16-2015, 12:15 PM | #248 | |
Rep 809
03-16-2015, 12:36 PM | #249 | |
Rep 809
http://www.racechip.com/chiptuning/b...40kw/index.php |
03-16-2015, 05:45 PM | #250 | |
IG @bmwF9xG80
3813
Rep 7,593
Someone tested S1 and made no difference since its dedicated for Diesel engines. What are your settings currently?
03-16-2015, 08:05 PM | #251 | |
Rep 508
03-16-2015, 11:30 PM | #252 |
Rep 39
Bought it for my 2014 M235i (N55) and installed it a week ago. It fits but you do have to work with it to get it back in there. It's like a puzzles and there is only one way it will go. Once you snake it back in it works perfectly. The only hitch is that the hole in the air scoop does not line up with the hole on the frame so it is not bolted in but it doesn't need it to stay put. It is totally secured when you reattach the grid piece after the scoop is in place. Be sure to get the rubber piece locked in all the way around the grid.
03-17-2015, 08:31 AM | #253 | |
Rep 809
03-17-2015, 09:22 AM | #254 |
Rep 596
03-17-2015, 10:35 AM | #256 | ||
Rep 197
You are echoing many of my thoughts.... |
03-17-2015, 03:38 PM | #257 | |
Rep 197
I'm looking for a tune for my completely stock car (motorwise that is) that I can use on the track, and easily bypass for the street. If the RC turns out to have at least as much power as say the afeScorcher, and is quickly bypassable, I'm in. I'm therefore impatiently waiting for more impartial feedback on it's performance. |
03-17-2015, 09:36 PM | #258 | ||
IG @bmwF9xG80
3813
Rep 7,593
03-19-2015, 11:00 AM | #260 |
Rep 5,262
03-19-2015, 06:36 PM | #261 | |
Rep 508
03-19-2015, 07:40 PM | #263 |
Rep 1,040
Would need to confirm with RaceChip tech. support if the bypass plug can be left in so you are running the car in stock mode. The instructions only mention using the bypass plug as a reset device to use before removing from the car. Could be a electronic reset for the cables before plugging the factory cables back in.
03-19-2015, 09:31 PM | #264 | |
Rep 5,262
basically you disconnect the rc box and connect the plug which just connects the 2 wires... making it just a longer wire from the sensor to the ECU.... nothing else... |
