04-08-2014, 03:37 PM | #23 |
Rep 148
04-08-2014, 03:41 PM | #24 |
Rep 148
LOL, that's what got me too. The 228 would have been plenty of power for me but once I heard that sound there was no going back!
04-08-2014, 04:00 PM | #25 |
Rep 580
Drives: G20 M340i
This same issue came up when the 1 series was released. There was a Roundel article about why the 128 was the better "drivers car" compared to the more powerful 135. The OP basically rewrote the article, just replace the 1 with a 2. Of course the comparison to the e36 m3 was nice
http://www.1addicts.com/forums/showthread.php?t=407873
04-08-2014, 07:34 PM | #26 |
Rep 435
Saving $10000 buying my 228,vs m235 has been a no brained for me. I can only go so fast and the 228 is more than enough. Put it in sport mode and the torque just comes on...I can be in 4 through 6th gear and when I floor it a sudden thrust just comes on. The sound in sport mode is decent but not same throaty as m235. But the diesel clacky clack is not there compared to a 2012 320 I had as loaner once. If I get a tune on this and after market exhaust look out!
04-12-2014, 09:25 PM | #27 | |
Rep 7,047
The same has been said of the F30. The 328i has less weight up front, and the suspension calibration seems better for the 328i's weight distribution. The 335i has more weight up front, and likely more weight forward of the front axle line. That too contributes to handling, as I'm sure you know. For those who track regularly, and for people like you who know and are more sensitive to such things, will notice it and may end up with the conclusion you did. I don't track, but I do like spirited driving. Also, I prefer the sound of the inline 3.0 more so than the excellent 2.0. And, I like the high speed acceleration better in the 3.0 than the 2.0. Off the line acceleration, and daily driving acceleration both engines provide great torque and feel close in that regard. At higher speeds, such as for passing, the 3.0 shows it's advantage, and of course at acceleration beyond 80 or 90 mph. But that's a given as the 3.0 has more HP. I preferred and got the 335i over the 328i for the reasons stated above. If I did more track driving, or if I lived in an area with a lot of twisting turning roads, then I would likely have opted for the 328i sport. In those conditions the greater power of the 3.0 can't be fully and properly utilized. For the F30 both the 328i and 335i sport models are very nice, and no neither driver/owner should feel superior or inferior to the other. From you review it seems the same holds true for the new 2 series. Sounds like either car is great and which one to get needs to be assessed by what the driver wants more of, and then go with that one with full confidence. |
04-12-2014, 09:33 PM | #28 | |
Rep 7,047
Also, 0-60 is a good test by which to judge daily driving. The 0-100 run is different, and of course favors the car with higher HP. Since the vast majority of us don't live on the track as we drive in the real world, the lighter 228i makes for a serious consideration that may fit more drivers. The 235i and 335i offer a different fell in power delivery and sound. Whether or not that appeals to a particular driver, only that driver knows. I choose the 335i over the 328i, but it was really close. It came down to the torque and sound of the 3.0. I'll be shopping the new 2 very soon, and even though I'm thinking I want the M235i, I'll keep an open mind and definitely test both versions before making a final decision. The 228i and 328i are very compelling options with that excellent BMW 2.0 turbo. |
04-12-2014, 10:21 PM | #29 | |
Rep 7,047
Just for fun and for my own information I gathered up some info. This is based on the standard model of each car, which means the 235i will show more weight as it comes with certain standard items not included in the standard 228i. When both cars are equipped with same features and options the weight difference will be less. On BMW's site the spec's are listed only for the base model. I'll list the spec's for the AT since both cars use the same trans. 235i AT: Power - 320hp 330lb ft. Weight - 3535 lbs Weight distribution - 52.2% frt and 47.8% rear Weight front half - 1845.27 lbs Weight rear half - 1689.73 lbs Power to weight - 11.05 lbs per 1hp or .091hp/lb & torque - .093lb ft./lb 228i AT: Power - 240hp 255lb ft. Weight - 3300lbs Weight distribution - 50.3% frt and 49.7% rear (Manual version 50/50) Weight front half - 1659.9 lbs Weight rear half - 1640.1 lbs Power to weight - 13.75 lbs per 1hp or .073hp/lb & torque - .077lb ft./lb Total weight difference is 3535lbs - 3300lbs = 235lbs. 335i front half weight is 1845 lbs. 228i front half weight is 1660 lbs. 1845 - 1660 = 185lbs. Most of the 235i's greater weight is indeed at the front. Reminder, when both cars are equipped equally the front weight difference will likely be lower. The 235i comes standard with a sunroof, xenon headlights, power seats, larger brake calipers and rotors, body kit, larger wheels and tires. The 328i and 335i have a similar weight and distribution difference. With equal equipment I think the front weight difference was closer to 110-120lbs. Still, the 235i carries more weight of front, and I believe the 3.0 inline 6 puts more weight forward of the front axle line. The weight and it's placement do make a difference in handling and feel. Just like the 3 series, I feel, BMW didn't optimize the suspension calibration to compensate for the extra weight on the 3 series, and it appears same holds true for the 2 series. Granted, you can hide the weight cause it's there, but suspension tuning can go a long way to compensate for that difference. |
04-14-2014, 12:25 PM | #30 | |
Rep 37
Starting to think the weight difference between an M235i and a comparably equipped M-sport 228i is a lot less than 235lbs. |
04-14-2014, 12:54 PM | #31 | ||
***** noob
1369
Rep 10,479
I can understand the money savings of a 35 vs 28, but for 100 lbs??? Comon now
2006 325xi (Sold)
04-17-2014, 10:52 AM | #32 | |
Rep 6,937
Drives: 2018 M2 AW DCT
04-17-2014, 11:19 AM | #33 | ||
***** noob
1369
Rep 10,479
2006 325xi (Sold)
