04-01-2020, 04:21 PM | #112 | |
Rep 204
09-28-2022, 10:32 PM | #113 | |
Rep 337
09-29-2022, 03:51 PM | #114 | |
Rep 1,015
Many thanks. |
09-29-2022, 05:10 PM | #115 |
Rep 337
Sure. You have the protool app. I'm not sure how to use esys. Lowering to 85A increases the firmness in all adaptive modes and is the most noticeable in Sport+ of course. I'll attach screen shots of the options in protool. I'll try to get some screen shots of DSC options I played around with later. Both the steering and DSC options made the car more sporty and I can power through corners quicker and more stable now. But, it will depend on your setup and preferences as to how it feels to you. You just click on steering, edit coding and max current. 85A with tolerances was way too stiff and through the whole balance of the car off. Didn't drive right but the 85A works for me. Correction, the factory coding was 105A not 120A. 120A makes the steering a tad more quicker and lighter.
Kernel Kurtz345.00 |
09-29-2022, 05:17 PM | #116 | |
Rep 337
09-29-2022, 05:53 PM | #117 |
Rep 337
DSC screenshots. There's tons of options here and will take some exerimenting to see what you like.
1. DSC_codierdaten_allgemein, I changed the option c_funktion_ccc_dsc_ekr from disabled to enabled. It increased a more dynamic feel and firmed car up a bit. Together with the other options I'm about to mention increases this behavior and balance of car. It did seem to cause a little more wheel spin powering through corners but you can control it. Sport + the car powers out of corners fast. 2. DSC_codierdaten_lieferant_conti, i changed options, c_AMR_1_c and c_AMR_2_c to a coding status of 2. c_AMR_3_c i left stock at 2. From my testing, it seems AMR1 is for DSC, AMR2 Sport and AMR3 Sport+. Nothing written in stone. This is all based on feel. It feels like the brakes front axle may be activated more on fast tight turns. It also making the car feel stiffer and more solid like the brakes front axle could be pretension or more damping. Probably brakes though. Coding with higher numbers, the car feels more soft and loose. Lower number the reverse effect. I also changed c_TCS3_c to 1 which lowered some of the braking assistance with lane changes. Higher number on this one makes the car transition quicker and firmer feel. This helped me sense the above options stiffened the feel. Last, I changed C_Lampe_ASC_c to a 1. It says anti power hop. I found it reduced the braking intervention a little and made the car feel soft with lower numbers but I think I may feel a little more power. tweak as needed to find the sweet spot for your setup. Most of this stuff is probably braking and power adjustments. I doubt dampers are effected. |
