08-04-2021, 04:46 PM | #23 | |
Rep 164
But, as you suggest, it may be more accurate to say: car+country+regionally-regulatory-specific. Though that doesn’t bring us close to an equation. Also, do you think they print less than full-load pressures on the door without stating so? … and would they print the high speed tuning pressures on the door if they apply to regionally illegal speeds? I don’t know, but I’m starting to suspect that the exact mathematical equation they use may include words. |
08-04-2021, 06:37 PM | #24 | |
Rep 6,031
08-05-2021, 12:15 AM | #25 | |
Rep 164
(I’m imagining that lighter cars on the same tires can carry more weight in occupants and baggage before reaching the same ultimate load limit. In that case we’d all (those of us with the same oem tires) be at the same GVWR and, therefore, the same psi … which we don’t have.) |
08-05-2021, 12:57 AM | #26 |
3626
Rep 3,593
For the 2017 M240i with a manual transmission and a maximum permissible weight in Canada (similar to GVWR) of 1980kg / 4365lbs, the following are the tyre pressures (bar/psi) for different tyre sizes and speed conditions:
18” 225/40-18 runflat all-season tyres all around: Below 160km/h - 2.4/35F, 2.7/39R Above 160km/h without high speed synchronization option - 2.6/38F, 3.0/44R 18” 225/40-18F, 245/35-18R summer tyres Below 160km/h - 2.4/35F, 2.7/39R Above 160km/h without high speed synchronization option - 2.4/35F, 2.7/39R Above 160km/h with high speed synchronization option - 2.6/38F, 3.0/44R |
08-05-2021, 02:10 AM | #27 |
Rep 77
I'm intrigued by this thread. I literally just picked up my new car less than a week ago. It's a week 25 build, M240I Coupe with a 6MT and staggered PSS tires. recommended pressure is 35 up front and 41 in the rear.
08-05-2021, 12:30 PM | #28 | |
Rep 164
Does this present the theory that - for a ‘17 MT coupe in Canada - the door says either: • 35 / 39 Or • 38 / 44 ? |
08-05-2021, 12:39 PM | #29 |
3626
Rep 3,593
It says 2.4/35, 2.7/39, probably as there is no speed limit above 120km/h across the country, so the "over 160km/h" tyre pressure would not be valid on public roads.
08-05-2021, 01:31 PM | #30 | |
Rep 6,031
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 08-05-2021 at 01:36 PM.. |
08-09-2021, 01:26 PM | #32 | |
Rep 164
Regardless, my car lists 38 and 45. With an occupants/baggage never exceed weight of 785. We all seem to agree that the door psi’s are for max load (although it seems some cars list partial load numbers along with max). So my psi’s are likely for about 605 pounds more than my car ever carries when I drive it hard. And because my door is 1psi off of the high speed tuning psi’s listed in the book, it seems my door may be advising for a load and speed scenario I never encounter. SHORT VERSION: Unless I start frequently carrying three friends and bags at 110 mph, it seems wise to target lower pressures for better ride and handling (and tread wear). …Maybe significantly (up to 15%) lower. While the dealer, and many shops, continue to pump them all the way up for legal CYA Last edited by SoftShoe; 08-09-2021 at 01:39 PM.. |
Tags |
bar, kpa, pressure, psi, tire |
