11-27-2022, 03:52 PM | #1 |
Rep 214
Boost Taper
I have a 2016 EWG n55 FBO PS2. ( stock inlet )
GFB DV, 93 octane. 750cc injectors. Custom tuned. ( checked maps of 2 tuners ) Less than 15k miles. ( weekend car ) The issue is what the title says. Boost tapers as the rpm goes higher. The wgdc says around 100. No throttle closures. Timings are fine i guess. The HPFP is quiet happy. I have done a 25psi air test. ( no leakage ) Done with a smoke test. ( nothing found ) Diagnosed through ISTA. Have a look at the logs, pics and guide. Thank you https://www.bootmod3.net/log?id=6381...90c6e22f6d46a3 https://www.bootmod3.net/log?id=6381...729b3ec75e4a38 https://photos.app.goo.gl/LAupzRVjZWCYT4o39 Seriously i am fed up past many months 😑 Help please. Last edited by Zinia; 11-28-2022 at 03:44 AM.. |
11-29-2022, 03:02 PM | #2 |
Rep 643
have you tried any of the OTS maps such as the stage 2+ 93 (assuming you have upgraded your hpfp). otherwise you could try the stage 2h map.
M235i rwd 6mt
11-29-2022, 06:42 PM | #3 |
Rep 214
12-01-2022, 07:13 AM | #5 | |
Rep 214
12-02-2022, 08:52 AM | #6 |
Rep 191,163
Did you check with PTF?
Maybe your turbo is bad.
12-02-2022, 10:09 AM | #7 |
Rep 214
PTF says to check ewg and dv. The car isnt showing any codes but i am checking the wastegate again just for satisfaction. Got the turbo from you people 3 weeks back i guess. Once i check the wg and dv once again than i,ll check the turbo thoroughly. Last edited by Zinia; 12-02-2022 at 02:50 PM.. |
12-03-2022, 02:44 PM | #8 |
Rep 214
i did a stock tune wot log today just to get some idea that maybe we can norrow down our problem. The wgdc is not 100 means the wg is working. What other clues do we get from here? Kindly help.
https://www.bootmod3.net/log?id=637c...729bfbde768e84 |
12-16-2022, 03:37 AM | #9 |
Rep 214
Hello
I installed an upgraded inlet pipe. I think the wgdc and boost taper issue is much better. Please advice. https://www.bootmod3.net/log?id=639c...0b43c619bfc96b |
12-16-2022, 07:07 PM | #10 |
Rep 214
05-15-2023, 11:15 PM | #11 |
Rep 1
[QUOTE=mannerism;29647798]Correct link
https://www.bootmod3.net/log?id=639c...0b43c619bfc96b Drift Boss I still can't find information based on your link. Last edited by victorable; 05-15-2023 at 11:21 PM.. |
05-17-2023, 06:03 PM | #12 |
@_sunbish
284
Rep 611
turbo was done for?
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
11-07-2023, 04:09 AM | #13 | |
Rep 1
