09-05-2014, 03:46 PM | #23 |
Rep 3,435
09-05-2014, 03:50 PM | #24 |
***** noob
1375
Rep 10,479
Holy shiet...M2 killa
2006 325xi (Sold)
09-05-2014, 04:05 PM | #25 |
Rep 287
Drives: '15 GT-R, '02 996TT
Its just the boost settings that you're allowed to change. Its similar to what my Map 5 ran, so those numbers were used in collaboration with a friend and BMS (to verify logs). I don't like Map 5 since it was inconsistent, so I just switched it to Map 6 for more consistency in boost. However, Map 5 broke the 400whp barrier too, so its not much different.
09-05-2014, 04:21 PM | #26 | |
Rep 4,526
No extra FF or EWG wires, HFC DP and MPE. My car came up with a flat torque with peak crank torque if 450lbft and crank power topped out at 380bhp. Car goes like stink !!!
Current '22 X3M LCI.. |
09-05-2014, 05:11 PM | #27 |
Rep 536
i did but its not rocket science. Create a boost curve that suits your mods. I have seen 20psi out of my stock snail
09-06-2014, 02:57 AM | #29 | |
Rep 1,040
Ease of taking off a Stage 1 harness so I can take it in for service without any hassles is important to me. My guess is this box will be the same tech as the BMS but a more simpler harness to store out of the way, and the box looks better without the extra connection that you can't use anyway (COM port). No Dyno plan until next Spring until I get a downpipe added, so for the upcoming cold months this will be just enough power for me until I'm all healed up my Winter activities. |
09-06-2014, 02:08 PM | #30 |
Rep 623
Are you referring to the aFe Scorcher? I don't see one specifically for the 235i, only for the 335i with the N55 engine, should that work fine on the 235i?
Seems to be about $450 though if you get the package deal with the Momentum intake, then it's $700, and considering the intake is about $415 alone, it makes the tuner module $285. Tempting.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec |
09-06-2014, 05:17 PM | #31 | |
Rep 1,040
77-46304 |
09-06-2014, 07:30 PM | #33 | |
Rep 528
I got myself all set up and did my first data logging last night via laptop....took your advice though and bought the OTG cable/app/fuel calc...even snagged a galaxy s3 that my coworker was selling for 40 bucks. So I should be all good for my next dyno sesh. Ran a E85 mix on map 2..... Are you emailing Terry direct with your logs? |
09-06-2014, 07:43 PM | #34 |
Rep 623
Here: http://www.ebay.com/itm/aFe-PRO-5R-A...15218a&vxp=mtr
aFe also has it direct from them for $733: http://afepower.com/shop/details_new...L&&brandID=112
2014 BMW M235i 6MT
09-08-2014, 01:50 AM | #35 | |
Rep 287
I just send Terry my logs or post on the N54tech forum . |
09-08-2014, 09:44 AM | #37 |
Rep 4,526
I upgraded to quaife LSD already to help get more of the power down more of the time.
Works a treat.
09-08-2014, 11:32 AM | #38 |
Rep 926
Great to see you pushing this car. I'm going to do the same.
Any plans for the transmission? How much power are you going to build until you focus on it? I'm wondering the same for the internals. Crank I heard was forged the rods and pistons I heard were not. |
09-08-2014, 03:03 PM | #40 |
Rep 287
I'm going to keep it as is for now, with no plans on the tranny or motor. I don't think I've approached the limits of the motor yet, but I don't launch the car or shift at peak torque, so I don't think it will be an issue.
09-08-2014, 04:53 PM | #41 | |
Rep 4,526
Given the way my car currently gets off the line and goes down the road, I might leave my car at the stage it's at now. It has multiple roles ( daily driver, dad's taxi and my occasional track day toy) so can still do 400+ miles to a tank of fuel, drop 911's and XKR's at the lights and worry lots of exotica on a circuit. |
09-08-2014, 07:55 PM | #42 |
Rep 437
Drives: 2021 X3MC
Out of curiosity are you maintaining the car yourself ( brake fluid oil change etc) or using the 4 yr maintenance plan with all the mods esp down pipe which you can't hide. I'm banished to Eco pro hell during the break in period to keep the revs low. Kudos to you guys with the courage to just enjoy yourself and the car!
09-08-2014, 08:01 PM | #43 |
Rep 5,262
you don't really need to drive in eco pro to keep the revs low...
It's probably a bad idea to break in on eco-pro also as you should actually not stay at same rpms constantly you should drive at wide range of rpms from 0-4k and different speeds |
09-08-2014, 08:14 PM | #44 |
Rep 437
Drives: 2021 X3MC
The Eco pro is more of a self control thing to remind me to take it ez. It has occurred to me though the engine lugs occasionally and it's far better to rev a little than lug the engine. It's sick how a downshift to 7th gets me past 80 in a blink and the speed gong going off (another self control thing). I try to vary the speeds as much as I can but with so much highway commuting its usually between 70-80. Ur probably right though and I should use comfort more. Sport I think will get me past 4500 rpm too easily.
