06-26-2014, 07:25 PM | #23 |
Rep 100
Drives: 2015 M235i xDrive
Does anyone know if there are any EaS 'equivalents' in the greater NYC area who do mods like this?
06-26-2014, 07:35 PM | #24 |
Rep 5,373
Is it me or is the bottom left corner not aligned properly?
Those with OCD will understand. Otherwise, well done.
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
06-28-2014, 08:31 PM | #27 |
Rep 5
Installed today, very DIY
I installed the gauge today. It is not that difficult to do and like Tom from EAS stated, very DIY. You need a #25 torx driver, 10mm socket, a small flathead(2mm blade), trim removal tool and patience. The instructions won't hurt either, even if they come from the F30. Just pay attention because the F30 and F22 are not an exact match. Luckily the wires are color coded and make the differences easy to spot. It took about an hour as advertised, even if I was very careful removing the trim. As a disclaimer I do work on electronics as a job, but this is no different than installing a car stereo.
06-29-2014, 01:01 AM | #28 | |
Rep 661
06-29-2014, 07:00 AM | #29 |
Rep 3,071
Where did you buy and the cost???
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
06-29-2014, 10:24 AM | #30 |
Rep 5
pictures are in the instructions
I talked to Brian at EAS and explained that I bought the gauge from them and needed install instructions. He talked to the installer and emailed me the instructions for the F30. There are pictures of process are in the file. The only differences are that there is only one light connector to disconnect on the tray under the glove box, the COM 2 and 3 are reversed between the F30 and F22 models. But like I stated earlier, the wires are color coded (connectors are also color coded) and there are only 5 to deal with spread over three connectors(2-COM 3, 2-COM 2 and 1-COM 10). The pin locations are clearly marked and easily removed. As for the trim, if you follow the instructions and do it in the correct order, you might not need the panel removal tool. Firmly pull up the door trim and tap to reinstall at the end. I pulled the vent out with my hands, as it is only held in with clips. The cost was $849 from EAS. The only reason I didn't post the file is that there was confidentiality statement at the end of the email that said I couldn't redistribute it. I suggest you give EAS a call on Monday and they should be able to help you out.
06-29-2014, 10:44 AM | #31 |
Rep 5
Finished Pics
I know it doesn't help the install process, but here are pics of the finished product. As for losing the vent, I live in Florida with temps in the 90's every I really don't notice the difference in cooling the car.
09-18-2014, 06:47 AM | #32 |
Rep 69
Does this have teh ability to display speed digitally in KPH? Im debating this or http://www.p3cars.com/bmw-1-series/p...tal-interface/. I would really like the ability for digital seed readout as well as monitoring functions.
09-18-2014, 06:50 AM | #33 | |
Rep 233
09-18-2014, 11:09 AM | #35 | |
General
8115
Rep 18,814
Drives: BMW
At approximately 1:50 you can see the configuration menu, in which MPH/KPH is accessible.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
09-18-2014, 01:39 PM | #37 |
Rep 347
I'm curious as to where they're pulling the oil temp info, in this wired setup, since it apparently isn't available through the OBD port.
F22 * (N55 + 6MT) ÷ PSS = FUN
01-31-2015, 08:41 PM | #38 |
BD_e92
358
Rep 1,748
02-02-2015, 12:04 PM | #39 |
General
8115
Rep 18,814
Drives: BMW
Awron is fully compatible with JB4.
02-02-2015, 01:13 PM | #40 |
BD_e92
358
Rep 1,748
10-15-2015, 11:12 AM | #41 | |
Rep 2,363
Thanks!
Follow my builds:
10-15-2015, 02:43 PM | #42 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
Looks great but $1000 for a temp gauge?? Well above my pay grade haha
10-15-2015, 02:49 PM | #43 | ||
General
8115
Rep 18,814
Drives: BMW
A proper flash tune and the Awron display would be the best of both worlds.
10-16-2015, 10:03 AM | #44 | |
Rep 8,942
