08-03-2015, 03:01 PM | #45 | |
Rep 219
Correct, the picture are with NO adapters... they look good in the one picture because of the angle... they sat about 3" from where they are supposed to be |
08-03-2015, 03:02 PM | #46 |
Rep 2,384
08-03-2015, 03:02 PM | #47 |
Rep 219
08-03-2015, 03:10 PM | #48 |
Rep 219
Update on my car..
Effed up the front lip. went to park in a driveway that seemed to be in perfect shape but it wasn't.... going to try to fix it now. I'll try to post pictures of the fix |
02-01-2016, 07:29 AM | #49 |
Rep 219
A little update!...
Forgestar CF5V 19x8.5 et40 F and 19x9.5 et45 R 235/35R19 and 265/30R19 Hankook Evo2 V12 Test drove them, but have to wait to use them until Spring gets here... |
04-03-2016, 11:23 AM | #54 | |
Rep 219
I'd share more pics but I'm traveling without my computer, once I get back I'll share some! You can paint it or leave it like it is, it'll look good! |
04-06-2016, 10:33 AM | #55 |
General
2038
Rep 25,989
Your car is coming along nicely! Love the Fahrenheit too! I drive a UM Tuned MK5 .:R!
VMR|Wheels | 714.442.7916 |
04-08-2016, 07:47 AM | #56 | |
Rep 219
UM makes awesome stuff, I had UM on my MK6 R and it was amazing! I'm planning on doing UM for my b7 avant (2.0T) |
05-24-2016, 11:07 AM | #57 | |
Rep 3,842
I was told to order 19x8.5, et 44 with 235/35s on the front and 19x9, et53 with 255/30s on the rear. I really want to go up to 265s and plenty of people seem to be doing it and I also want to run 9.5s in the rear but I was told that 9 is just so much better for this car. Since these are custom wheels there is so much more configuration flexibility. Do you have any rubbing at all? Do I need to drop or go negative camber to run your setup? |
06-01-2016, 02:31 PM | #58 | |
Rep 219
My car is lowered as you can see, on H&R springs, which lowers the front quite a bit more than Dinan's.. my wheels specs are: 19x8.5 et40 235/35 Hankooks 19x9.5 et45 265/30 Hankooks Original alignment specs... at least to my knowledge I had the front fender rolled and SLIGHTLY pulled, when hitting a bump or pothole while taking a turn it rubs. I see other people saying that they are running low and with Michelin PSS's they don't rub... maybe it's just Connecticut roads apparently.. I think those offsets that you are mentioning could work with the car stock but at the same time they seem awful high maybe with the 9's rears instead of the 9.5 is the trick! but the tire will be big... and if you run lower offsets you're going to have a lot of poke. Best of luck! |
06-01-2016, 04:46 PM | #59 | |
Rep 3,842
06-06-2016, 09:42 PM | #60 | |
Rep 73
2016 MG M235i | Black Kidney Grills | MPE l H&R Springs | IND Double Slat Front Grills | M Performance Front Lip | 19" VMR v710 w/ Hankook Ventus v12
06-07-2016, 06:56 AM | #61 |
Rep 219
