06-19-2018, 11:30 AM | #1 |
Rep 36
Hex Tuning - Before and After '15 m235ix
I searched far and wide and didn't find much on VF Engineering/Hex Tuning for our F22s. They seemed to be conservative of sorts after reading some posts on the M3..or maybe it was M5. It seemed reasonable, and I have zero plans of going any further with it so needing to make adjustments isn't necessary. I have a drop in air filter and axle back Remus on the baseline. Anyway, here are the results in the attachment. It doesn't even feel remotely like the same vehicle...
06-26-2018, 02:48 PM | #12 | |
Rep 4
And this is a flash tune correct? I’m really interested considering this is on 91 OCT |
06-26-2018, 03:08 PM | #13 |
Rep 39
So much low end torque, looks really good but I wonder how it would be for RWD? i could imagine alot of wheel spin. hopefully it can make use of all that torque
BMW F22 M235i M Performance
VMR 18" V710 Staggered | M Performance Exhaust | M Performance Splitter | M Performance Diffuser | M Performance Grille | M Performance CF Interior | CF Mirror Caps | CF Trunk Lip | 35% Ceramic Tint |
06-26-2018, 03:22 PM | #14 |
Rep 36
If you had sticky 265s on the RWD, it would probably be ok. I've caught my 265s spinning, but I also chose to go with a tire known for not being sticky. Lol...no issues yet, but it's a ton of fun.
Yes, flash via ODB II/laptop/software. |
08-28-2018, 04:16 PM | #15 |
Rep 36
Still going strong 4k miles later...I put a few car lengths on a brand new S4 a while back from an 80 mph pull. I was fairly surprised with that one, but also didn't know what to expect out of it!
08-29-2018, 11:15 AM | #16 |
Rep 5,369
The mile-high Denver altitude would explain the super high 1.23-1.25 correction factor on the Dyno. Thing is, turbos aren't remotely as affected by altitude as naturally aspirated cars are because turbos will increase boost compensate for the lack of oxygen. Turbos are more laggy at altitude, but power isn't remotely as affected thus, I think the correction factor used is skewing the data a bit. On a Dynojet and with a more common 1 to 1.05 correction factor, a M235x 8AT typically see around ~290whp and ~310wtq. The RWD 8AT around ~300whp/320wtq and the 6MT ~310whp/330wtq.
322whp/350wtq on a Dynojet with a stock M235x is not accurate. At sea level and with a more typical correction factor and the current mods, I imagine this particular car would be making ~340whp/390wtq. Lastly, the big torque spike is simply the turbo overboosting due to a high load situation (i.e. tall gear + low rpm + full throttle = turbo overboost) and altitude. In a race, this overboost would not be experienced in 1st gear as not a lot of boost is made (minimal load due to a lot of torque multiplication at the tranny) and every successive gear change is well beyond 4,000rpms.
