06-01-2018, 12:52 PM | #23 | |
Rep 34
06-02-2018, 05:43 AM | #24 | ||||
Rep 329
06-16-2018, 11:11 AM | #25 | |
Rep 160
1. It helps make more power I.e. higher engine temps 2. A larger fmic will impede airflow to the radiator to some degree, which also means higher engine temps All else being equal, a larger FMIC will most likely increase you engine temps, so will a larger downpipe etc...All the power mods you listed will invariable increase and not decrease engine temps. |
06-16-2018, 11:18 AM | #26 |
Rep 63
To piggyback on some thoughts here:
Would the sport oil cooler valve have any practical benefit in helping decrease oil temps in a tuned car? I guess a follow up question would be is it even needed at all or does the stock oil cooler do enough already?
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless 2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30 |
06-16-2018, 06:10 PM | #27 |
Rep 160
From what I understand of it...it basically either shims or removes the oil thermostat. It doesn't actually increase the cooling capacity of the oil system at all. In situations where you have already reached the set thermostat temperature it won't offer any advantages. But in typical street driving where there's intermittent WOT scenarios the valve will let you start from a lower temperature and will allow you longer "heat generating activities" before you reach the same high temperatures. The downside is of course that you will spend longer warming up the car.
Bottom line is it doesn't help increase the cooling capacity of the car but in a street application might give you a few more pulls before the oil temp gets too high. (If that was the case before installation of the valve) |
Jpup26.00 |
06-19-2018, 11:42 AM | #28 |
Rep 1,753
So, I'm confused. If all I'm ever doing is spirited street driving running on a stage 2 tune with a cp and dp do I need an upgraded fmic?
I'm also confused about the dp now. If smog testing isn't a concern what are the downsides of a catless dp? Smell? Is it a lot louder?
06-19-2018, 11:56 AM | #29 | |
Rep 329
About the smell, there is definitely some smell, but unless you ride around with your windows open all day you will also rarely notice it. As far as needing an intercooler that is subjective. Will it help keep your IAT lower on hard driving, yes it will. I imagine you will get more of a consistent temperature during hard pulls. |
BentZero624.50 |
06-19-2018, 05:00 PM | #30 | |
Rep 160
BentZero624.50 |
