01-27-2018, 11:59 AM | #23 |
Rep 2,214
The little plastic screw on the top of the reservoirs can be responsible as well. Had mine replaced at about 20k kms due to occasional "seepage". Finally, the light had come on and I replaced the screw, topped up about 1L of coolant, and haven't had any losses, since, with a hot summer and track duty. At 40k kms, today, no more coolant loss. Definitely not concerned about consumption through the combustion chamber, that's just not even a concern, of mine, on a BMW.
01-27-2018, 01:19 PM | #24 |
Rep 611
Yesterday, my service department told me that high coolant usage...
(1) is normal, per BMW's cooling system requirements, (2) typically needs topping off at ~5-6K miles but sometimes sooner, (3) will vary considerably based on driving circumstances, (4) is sometimes found to be low after the initial factory fill, and (5) is topped off free of charge at the dealer, when required. (I'm just the messenger.)
—Steve
'19 MX-5 Miata GT-S soft top Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i |
Dylan861330.00 |
01-27-2018, 01:53 PM | #25 |
Rep 2,214
^^ I'd think a decent amount of time would be required to pass, before all of the "bleeding" of excess air in the system happens. Good point, especially with two aux. coolers as well, and for the WAIC on the B58. You have a knowledgeable service department! How they should all be, imo. Some come up with the dumbest reasons for coolant loss, but won't go there.
01-27-2018, 02:05 PM | #26 |
Rep 478
I recently went in for a scheduled oil change and they topped off the coolant without asking. There must be a TSB to check it/fill it.
'22 M440xi GC (BSM/Tacora) Previous: 2017 M240i Convertible; 2016 X5 50i; 2017 Boxster 718s; 2012 328iT Sport; 2009 X5 3.0; 2006 M3C; 2006 530xiT; 2003 325xiT; 2002 330i Sport; 2001 Z3 2.5; 2001 330i.
01-27-2018, 02:30 PM | #27 |
388
Rep 889
It’s usually the done thing to check all fluids, though, so one cannot conclude that anything suspicious is going on.
01-27-2018, 04:09 PM | #28 | |
Rep 400
How can they be so irresponsible of what they say? |
01-27-2018, 08:44 PM | #29 | |
Rep 205
I also find it interesting that based on my experience and other forum members, if the coolant loss happens it seems to occur when the car has 20k miles or less. I haven't really seen anyone one here report having such issues at higher mileages. Also, my car has the N55 engine, so it isn't just the B58 engine that has this problem.
2016 M235i xDrive - Estoril Blue - Coral Red - 35% ceramic tint - M Performance Exhaust w/ chrome tips - Dinan spring set (1/2 inch front 5/8 inch rear) with bump stops - JBSpeed paint matched spoiler - paint matched mirror caps - black kidney grille - BimmerTech backup and front-view camera retrofit
01-28-2018, 11:43 AM | #30 | |
Rep 611
Taking into consideration the sub-20K-mile theory, could the factory be routinely under-filling the coolants to varying degrees, either by intention or sloppiness? You'd hope/think that fluids would be checked at the VPC and/or dealer, however. Alternately, might there be any inherently greater rate of coolant usage when new?? Hard to imagine that possibility. I wonder (out on a limb here), based on my low mileage circumstance, whether BMW might've narrowed the sensitivity of the low-coolant warning for the 2018 model year. Possibly to preclude related warranty issues? My last conjecture: I wonder if coolant issues are equally common on 4- and 6-cyl. models, and among other Series', also? A poll to quantify low-coolant occurrence vs. non-occurrence, mileage, and model would be interesting.
—Steve
01-31-2018, 02:55 AM | #31 |
Rep 109
Go to the unlock menu to see the coolant temp when driving, you will note that collant temp goes until 120°C so it's normal to have to do a top off sometimes.
01-31-2018, 08:58 AM | #33 | |
Rep 400
As long as coolant reservoir tank cap is properly sealed, coolant level does not go down. Even if the cap is not 'perfect' (holds pressure to 12~14 psig, instead of perfect 15 psig), evaporation through cap is extremely small amount. in that case, you may need to add 50 cc in 10 years. |
01-31-2018, 10:26 AM | #34 |
Rep 1,247
01-31-2018, 10:32 AM | #35 |
Rep 1,117
Drives: 2015 BMW M235i
They've been using faulty head gaskets and engines are blowing up due to drinking coolant. Ford finally admitted to it and now they are issuing recalls.
They said it was not an issue for almost 2 years(ish). Sound familiar? Moral is, if you're drinking coolant, I'd be big time skeptical that it's normal. My 235i hasn't lost a drop in almost 3 years. Fully tuned. |
01-31-2018, 11:44 AM | #36 |
Rep 623
I'd hope that if there's an issue like that, that BMW would have quietly fixed it and my new engine doesn't suffer from excessive coolant drinking... really dont want to go through this bs again
I'll report back how much it's got through when I hit 5k miles |
01-31-2018, 12:29 PM | #37 |
Rep 580
02-01-2018, 08:58 AM | #38 | |
Rep 375
stevenvillatoro734.50 |
02-02-2018, 10:24 PM | #39 |
Rep 213
My 145k mile Club Sport has always used a bit of coolant, although UOAs came back negative for any coolant in the oil. Ditto for my 159k mile Mazdaspeed 3, which was still running great after eight years of ownership.
2014 M235i
2015 X1 xDrive28i M Sport 2009 Cooper Clubman 1999 Wrangler Sahara 1995 318ti Club Sport |
02-04-2018, 11:06 AM | #40 |
Rep 3,842
All I have to say is that if coolant levels in a sealed system go down by more than tablespoons, the car is either leaking it or burning it. The latter is especially a cause for concern, cars rarely heal by themselves. Even if the levels stop dropping at some point, personally I would always wonder what happened.
02-04-2018, 01:43 PM | #41 | |
Rep 205
It also seems that the coolant loss is some sort of all-or-none effect. There appears to be a critical time when it tends to occur, usually between 3k-20k miles based on the reports of other individuals on this board who had the same problem. If the car makes it through that period without coolant loss, then it seems it's very unlikely that coolant loss will occur in the future, as I haven't seen anyone post about losing coolant over 20k or so miles, unless they began loosing it earlier.
02-04-2018, 09:07 PM | #42 |
Rep 611
It could be the case that many low-mileage cars - the ones that **seem** to be losing coolant - were under-filled from the factory. My coolant light came on at under 500 miles (from new) and needed over a cup of fluid to be added. No system fault could be found.
—Steve
02-11-2018, 10:33 AM | #43 |
Rep 51
My 2017 240i had the low coolant warning appear at around 8k miles. Took it to the BMW Service center for a top-off. Technician said it wasn't dangerously low but was down a tad. When I asked if it was normal for a new vehicle to lose coolant like that the reply was something like "well you know, wear and tear..."
