2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum 19x8.5 ET40 Square setup / Which tires ?
      05-22-2018, 04:14 PM   #1
43-Hoonigan
Drives: F22- Estoril Blue- 220d
Question 19x8.5 ET40 Square setup / Which tires ?
Hello guys, i was thinking about square setup on my F22 (220d)
19x8.5J ET40
Does anyone have this setup ? Which tire you preffer ?
Please post photos of this setup here <3
Thank you guys.
      05-22-2018, 04:57 PM   #2
ramy_who
ramy_who's Avatar
Drives: 2018 M2 LBB, 1989 325is
I can confirm that 8.5 works.
Current: 2018 LBB M2
Gone but not forgotten: 2016 Alpine White 228 xDrive M Sport
Performance Mods: JB4 | Bilstein B14 Coilovers
Cosmetic Mods: Vorsteiner V-FF108 18x8.5 +35 Square | M Performance Diffuser
      05-22-2018, 05:30 PM   #3
Jnat
DisplacementReplacement
Jnat's Avatar
409
Drives: 2020 X3M
What size tires and wheel offset? thanks...
2020 X3M /// MHD Tune
Prior Bimmers
2017 240XI Hybrid / FBO / MHD E40
2015 235XI FBO / MHD E30
2009 335XI FBO / COBB / E30
      05-22-2018, 06:53 PM   #4
ramy_who
ramy_who's Avatar
Depends on many factors.
Stock Suspension
Rim Width: Ideal rim width is 8 front and 8.5 rear. It's possible to fit 8.5-9 upfront but I would not recommend.
Rim Diameter: Rim Diameter is irrelevant but profile does make a difference. 40 profile for 18 inch and 35 profile for 19 inch is recommended the maximum possible profile.
Rim Offset: The more aggressive the better. 37 is the sweet spot.
Tires: Nothing more than 225 front. 235 is possible depending on the tire but I would not recommend. 225 on 8 width rim is stock setup and not only ideal, but highly recommended because the 2 series is very tight upfront. Rear is more flexible with upwards to 255 possible.
Lowered
Rims: More rim width is possible. I wouldn't exceed 8.5 upfront. I wouldn't exceed 9 for the rear.
Tires: Same as above.
Lowered and Cambered Front
Rims: Same as lowered
Tires: 245 is now possible upfront if camber is maxed out.
Hope this helps. Please correct me if I'm wrong about any of my numbers. Word of advice: stick to the stock setup whether you wanna go square or staggered. It will save you a lot of headache and looks better than any other setup IMO.
      05-23-2018, 02:20 AM   #5
43-Hoonigan
Do you have some photos of this setup ?
My car will be lowered
40mm front
30mm back
Tags
8.5, square set up, tires, wheels
