05-16-2016, 05:29 PM | #23 | |
Rep 1,503
FBO M235i r
F80 M3 |
05-17-2016, 09:53 AM | #24 | |
Rep 133
Aside from the in-dash controls, are there any benefits to the OBD2 firmware over the last positap firmware? I recently installed the Bluetooth adapter so I don't care as much about in-dash controls, but felt changing to OBD2 might provide other benefits, or at a minimum allow for continuing support from BMS. Thoughts? Edit: Muting active sound alone might be worth it. |
05-17-2016, 03:00 PM | #25 |
Rep 108
Mind snapping a few photos when you do the install and posting them?
2024 BMW 340i xDrive |
05-17-2016, 03:14 PM | #26 |
Rep 1,422
+1 I got mine from burger and awaiting install.
05-19-2016, 11:19 AM | #27 | |
Rep 1,503
FBO M235i r
F80 M3 |
05-20-2016, 12:05 AM | #28 |
Rep 1,422
Ya, I've got positap and my JB connect won't display the oil and water temp gauges.
05-20-2016, 02:57 AM | #29 |
Rep 4,522
Guys,
I'd suggest steering clear of OBD2 v6 of JB4 FW and use V5. Lots of OBD2 FW users moving from v5 to v6 FW reporting that v6 ign timing is learning down more than up.... BP
Current '22 X3M LCI.. |
05-21-2016, 04:24 PM | #30 |
Rep 133
Terry is working on a fix and has a test fw, I would imagine they'll release an update soon.
05-21-2016, 05:03 PM | #31 | |
Rep 4,522
http://www.n54tech.com/forums/showth...t=39551&page=3 Although it's still beta atm. Terry has upped the sample rate for cylinder logging
05-21-2016, 05:53 PM | #32 |
Rep 133
So I spent some time today installing the flex fuel and ewg harnesses, plastic weatherproof case, and obd2 cable. I decided to go through the firewall at the hood release cable grommet. This was truly fairly simple and I highly recommend it. I used a hook tool to pull the grommet off and expose the hole, which created plenty of space. Then you simply push the obd2 cable through the hole and you're done. I wasn't able to get the grommet back on, but I didn't exactly try very hard.
Note: I think I'm going to try making a second hole in the grommet to past the cable through there so as to maintain function of the grommet. |
lazyleung1.50 |
05-25-2016, 10:17 PM | #33 |
Rep 2,368
I fed it out through the door jam and into the engine bay from inside where the door closes. Ill post some pictures later but it was ideal because since my car is manual as well it was near impossible for me to get the OB2 cable through the grommet.
Follow my builds:
05-25-2016, 11:17 PM | #34 |
Rep 2,368
This is my solution.
Follow my builds:
05-25-2016, 11:18 PM | #35 |
Rep 2,368
Follow my builds:
05-26-2016, 09:28 PM | #36 |
Rep 1,422
Nice Sperry Topsider.
Do you think the wire is gonna get frayed in the jamb like that? |
05-27-2016, 08:17 AM | #37 |
Rep 108
05-27-2016, 10:17 AM | #38 | |
Rep 2,368
My intention was to go under the deal by drilling a hole for the cable on the backside I just haven't had time yet.
Follow my builds:
05-27-2016, 10:22 AM | #39 | |
Rep 1,422
05-27-2016, 10:28 AM | #40 | ||
Rep 2,368
Follow my builds:
05-27-2016, 02:52 PM | #41 |
Rep 133
05-27-2016, 06:07 PM | #42 | |
Rep 1,422
Thanks. |
06-01-2016, 12:45 AM | #43 |
Rep 509
Drives: 2016 M235i RWD 6MT
Has anyone had any issues from the dealers after the JB4 install?
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
06-01-2016, 03:00 PM | #44 | |
Rep 133
If you have an auto you'll want to use the other grommet referenced in this thread as it is simply blocking an otherwise unused hole through the firewall. The tough part for me was making room in that hole with the clutch line going through it. |
