Two weeks in... are all M240s as squirly as mine in low gears? |
11-30-2017, 11:54 PM | #1 |
Rep 798
So new to the car. 10k mile executive demo CPO. The car is a rocket, but it's almost spooky how much chassis movement there is under hard acceleration in low gears. Is this normal? I feel a little wheelspin, but the sensation is almost like torque steer in a FWD car. I'm coming from an 09 Carrera, which has pretty much unlimited traction, so that could be a factor.
Anyway... feedback appreciated. Thanks.
18 CQM M3
12-01-2017, 12:33 AM | #2 | |
Rep 4,341
Do you have the Supersports or Continentals? Contis are noticeably less traction. Regardless, you have to learn to manage more torque with less traction. Finally, there is no limited slip by default on these cars unless you added aftermarket. This makes it harder to get the power down too. Did yours have the optional limited diff? |
12-01-2017, 12:39 AM | #3 |
Rep 509
Drives: 2016 M235i RWD 6MT
Even with brand new PSS I remember when I stomped it in sport mode while under low gears (1 & 2) up to about 5500rpm the traction control kicks in like mad and you can feel the back end swishing as it aggressively attempts to correct itself. I have to admit I was scared and backed off right away on the first time. Few times after realized that I need to be kind to the throttle to limit the slippage.
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
12-01-2017, 07:07 AM | #5 |
Rep 857
I have a 911, too. Nothing "bites" like a Porsche with all that engine weight in rear. Hit it hard coming around a corner and it just rockets ahead.
That may be altering your perception. The power delivery of the 2 cars is radically different. The BMW has more immediate torque where the Porsche just builds seamless power all the way through. As a friend of mine once said after test driving my 911S, this car is really fast BUT its a different kind of fast than I have ever experienced. I just got my M235IX and I love it. It just feels like its always "charging". Have not hit it hard from a dead stop but it jt takes off from any speed. Going 75 on the tollway the other day and wanted to get around a truck. Gave it a little throttle and made my move--looked down, going 100 mph. WOW.... You can get into a lot of trouble with these pocket rockets |
12-01-2017, 07:12 AM | #6 |
Rep 117
Yeah, definitely true of mine, even with PSS in warm weather. I got the LSD so curious to see if that will affect it, but honestly I kind of like it sometimes.
12-01-2017, 07:16 AM | #7 | |
Rep 798
Thanks for the responses. It is fun, it's just very different from what I'm used to. Yeah the 911 was all top end and very linear. I love the immediate push in the 240, I just have to adapt to the first couple gears. I was starting to think there was something wrong with the car, but I feel better now. Gotta love car foruns! |
12-01-2017, 07:19 AM | #8 |
Rep 798
Hey keep me filled in on how the LSD affects performance please. Maybe that can be my Xmas 18 gift! Too soon right now... wife would veto.
12-01-2017, 10:26 AM | #9 |
Rep 970
Mine acts the same way. First time was pretty scary. Reminded me of my C7 when I first did hard acceleration. Scary. Between the noise of the motor and the car's "twitchiness", I let off pretty quickly.
Off topic: Question on Porsche regarding power delivery. BMW and MINI seem to deliver power low in the RPM range, so you feel a lot of "grunt" early and at low RPMs. Does the Porsche power delivery mimic BMW/Mini's or do you need to build up RPM's before you get that same "grunt"? Test drove a Audi TTS and noticed that "bliping" the throttle at lower speeds didn't transfer any feeling of acceleration or connection to the cabin. I could hear the engine rev w/ the throttle input, but that was about it. If iImanually went to a lower great and got higher engine RPM's, then the car would "buck" and lunge forward as I blipped the throttle. Wondering how a Porsche fits in? |
12-01-2017, 10:32 AM | #10 | |
Rep 4,341
I had the same issue when I first switched to the the turbo motors. I see you have a crazy honda. I think if you approach the throttle like a powerful front wheel drive car where you have to have a lot of throttle discipline you will enjoy it a little more. Here is a good video of a full-lock diff in action. Check it out around 39-44 seconds. https://www.youtube.com/watch?time_c...&v=lEvpnKRLDO4 Congrats and best wishes. |
12-01-2017, 10:37 AM | #11 |
Rep 913
I've found that tire pressure plays a decent role in how 'squirrely' the rear feels under heavy throttle. I find either the PSS or the Contisport ExtremeContact Sports behave the same if they're down a couple PSI and cold. I would imaging the rear subframe bushings on our cars are more forgiving than the ones n a Porsche and definitely than the solid ones in the full M cars and that will play a part in the feeling,.
12-01-2017, 11:05 AM | #12 | ||
Rep 798
18 CQM M3
12-01-2017, 11:07 AM | #13 | |
Rep 798
18 CQM M3
12-01-2017, 11:38 AM | #14 |
Rep 1,117
Drives: 2015 BMW M235i
Ahhhhh the magic of torque and skinny tires.
12-01-2017, 12:18 PM | #15 |
Rep 5,369
I use to think it was cool, now I find it mostly annoying. I'm still on the stock tune and no power mods and my M235 6MT will obliterate the MPSS tires (still have 50% life) in 1st and can spin then easily in 2nd from a 30-45mph punch. Going down entrance ramps, I'll punch it in 2nd and can feel the tires hunting for traction while also accelerating forward and this is on concrete which is usually traction rich. On smooth asphalt, the traction can be really sketchy and can sometimes get it to spin from a roll in 3rd from a 2500-3000rpm punch.
I blame the big torque surge at turbo spool onset and somewhat narrow rear tires. Oddly, my 225/40R18 Michelin Aplin PA4 winter performance tires have FAR better straight line traction than my MPSS tires. I can punch it in 1st with minimal spin and have little traction issues in 2nd. It's awesome but handling isn't remotely as good. I'll be getting the MP LSD in the spring and while I think it will do very little to improve straightline traction, it should help make dealing with the spin a bit more predictable. |
12-01-2017, 12:51 PM | #16 |
Rep 3,842
I experienced the same unstable feeling with my M235i in lower gears or under heavy acceleration in corners. The problem is that the M235/M240 has too much torque for the original size tires. The car resorts to traction control to stabilize the car. The problem is that it isn't the most seamless system. The car hunts and jerks as the traction control tries to reduce power and use braking to control all that torque. If you turn off the traction control (long press DSC button) it activates the "E" differential mode but the car just doesn't have enough traction, it will slide like crazy. This drifting is fun but the car needs more traction.
I upgraded to 235/35/19 front and 265/30/19 rear tires in the new MPS 4S, which has transformed the car. BMW most likely used those smaller tires on the car in order to 1) save money, 2) improve fuel economy for advertising and import duties, and 3) to not compete with the M2 on the track. Dinan springs adds another step towards more control on this car. My preferred tire pressure for street driving with these tires 35F 35R. Last edited by AlpsRider; 12-01-2017 at 01:42 PM.. |
12-01-2017, 12:56 PM | #17 | |
Rep 913
I keep my tires @ 34F and 39R when cold - I generally tweak them based on average temps for the season. I check and adjust pressures every week - yes OCD ... lol.
12-01-2017, 03:52 PM | #18 | |
Rep 798
Thanks.
18 CQM M3
12-01-2017, 03:57 PM | #19 | |
Rep 345
2017 M240i xDrive Loaded 2013 328 xDrive Premium, Executive 2007 335i Premium |
12-01-2017, 04:06 PM | #20 |
Rep 2,214
LSD and good tires will totally change your perspective of the "unsettled" character that the m235/40s have. Just ask anyone who's done before/after reviews, it's very telling that this car "should" have come with an LSD from the factory, but to keep the MSRP in check, they obviously had to cut come corners..
12-01-2017, 04:08 PM | #21 |
Rep 2,873
How the 911 has changed! Used to be that 911's would kill you for that type of behavior (or at least put you into a ditch backwards).
12-01-2017, 04:28 PM | #22 | |
Rep 5,369
I've owned my M235 for 19 months. I've experimented with tire pressures and have noticed absolutely no improvement in straight line traction by varying pressure. The only thing that makes a difference is getting the MPSS tires into the 100+ degree range. In ambient temps below 60 degrees, they're worthless, as to be expected for a summer tire. |
