07-11-2017, 10:35 AM | #24 |
Rep 2,873
Yes, I think he should post the car for sale in the members section, probably for less than 10 grand, given the terminal engine damage already done. My deposit is in the mail.
And FWIW, most octane boosting operates on diminishing returns - each incremental rise in octane level takes more and more chemical. So you get a bonus when you downmix like this (at least with the older stuff, half 91 and half 87 would yield about 90 - even stronger effect for the lead, but we can't use that anymore ) |
07-11-2017, 12:04 PM | #25 |
Rep 7,047
You kids are silly.
OP, there is absolutely NOTHING damaging to your engine and there won't be even if you got confused and fill up a full tank of 87AKI gasoline. Yes, turbo engines have knock sensors that listen for combustion chamber detonation, and that signal is monitored by the ECU/ECM that will adjust timing to keep detonation/knock from becoming damaging. When this timing adjustment occurs it typically results in the engine not developing it's full power if the driver is calling for it. Even if you smacked the loud pedal as hard as you can your engine will not be damaged because of the lower octane fuel. |
07-16-2017, 06:48 AM | #26 |
Rep 917
Drives: 2015 BMW M Sports Convertible
I guess Americans need reminding which fuel is required and it would be a good addition to join all the reminder alarms you Americans need in cars.
2015 220i M Sport convertible.
2016 225xe M Sport. |
07-16-2017, 08:10 AM | #27 |
Rep 6,028
It's not so much that we are all imminent dementia patients as much as our hyper-litigious society has exploited "failure to warn" causes of action with a history of excessive recoveries.
07-16-2017, 09:06 AM | #28 | |
Rep 2,067
Page 170 of the Owners manual "Gasoline below the minimum fuel grade may impair engine performance". But on the same page it also states "Fuels with a maximum ethanol content of 10 %, (i. e., E10, may be used for refueling . Do not use a fuel with a higher percentage of ethanol recommended or one with other types of alcohol, e.g. M5 to M100; otherwise this could damage the engine and fuel supply system." Dunno, but to me, potentially damaging engine and fuel supply system would appear to trump impairing engine performance as a possible source of concern.
2019 X2
07-16-2017, 11:00 AM | #29 |
Rep 187
Just to add to other's comments - the car's ECU will take care of the lower octane gas by lowering output. it's also the case that putting cheaper gas in on purpose (to save $) doesn't tend to work out because the gas mileage degrades. And, at least to me, the % savings is so tiny compared to the overall cost of the gasoline (and in comparison to all other running costs) that putting anything in other than "the best" makes no sense.
12-05-2017, 02:44 PM | #30 |
Rep 30
So there's not risk of using 87 Octane for the life of the car?
Will the warranty and extended warranty be voided if BMW Canada catches me using 87 all the time? |
12-05-2017, 02:54 PM | #31 |
Rep 2,214
Why the hell would anyone want to do this, though? Go buy a Honda... oh wait.. No, buy a Honda, if 87oct is your thing
12-05-2017, 03:57 PM | #33 | |
Rep 970
If you have engine damage and it can be diagnosed to using cheap fuel (long term), then likely the warranty will not cover any costs. For the sake of $6 per tank difference, don't risk damaging a $50K investment. |
internalaudit13.00 |
12-06-2017, 12:09 PM | #35 |
Rep 17
Thanks to some users on this thread, I am going to invest $4 into this:
https://www.ebay.com/itm/Warning-Lab...-/282424193833 |
