08-30-2018, 07:50 AM | #50 |
Really Twisted
28
Rep 265
Ohh well wow didn't know that. Figured an M care would of gotten better
2021 Jeep Gladiator Rubicon
2015 BMW M235i F23 - Sold |
08-31-2018, 04:26 AM | #51 |
Rep 4,515
If you have deep pockets then TTFS have a solution in the link below
http://tuningtechfs.com/ttfs-n55-hig...p-single-pump/ Discussed on F87post forum thread below https://f87.bimmerpost.com/forums/sh....php?t=1501737
Current '22 X3M LCI.. |
M23528.00 |
08-31-2018, 01:43 PM | #52 |
Rep 147
Bosch also made an HPFP... but have not seen any testing or reviews, price is too good to be true. anyone know about this??
https://www.boschautoparts.com/en/au...-pressure-pump
M2 - Fully Built engine Carrillo H-Beam Forged Rods, cp Forged Pistons- BigBoost Turbo Stage 3 - Fuel It LPFP Stage 3 (dual walbro 450) connected to 950cc port injectors controlled by aic6 - Dual s55HPFP - SSP-R Clutch - CSF Radiator, Oil & DCT Coolers - EOS Intake Manifold - MSR front mountintake system
09-01-2018, 02:02 AM | #53 |
Rep 4,515
TTFS also do oem s55 dual HPFP kit for n55 at over $5k
https://store-xtdgx.mybigcommerce.co...0-5297c3e66d11
07-09-2019, 08:57 AM | #54 |
Rep 38
Hey guys,
Not M235i related but almost the same, I've got an N55 2012 135i with Injen intake, catless downpipe and m performance exhaust and Cobb APV3. When going to track days I been having issues when exiting turn under full throttle in 3rd gear. Usually car goes in heavy Limp Mode and following codes appear. P2EFE – P2F04 – P2F02 – P2EE0 – P2EF4 – P2EED – Yesterday after a few times clearing codes and heading back out I got a smaller limp mode and this code only came up. P2C01 - Switched maps a few time to see if it would change anything, but it didn't the only solution I found to delay the coding/limp mode was being light on the throttle and accelerate gradually at a very slow rate. As of now I changed plugs to NGK 97506 gapped to 0.022 but that didn't change anything. I've been reading around and as of now figured it could be coils, injectors, HPFP, or even that my tune would need to be revised, so before changing everything and not knowing if either its going to resolve my problem. Can someone who has had this issue help me out. |
07-11-2019, 03:44 AM | #55 | ||
Rep 221
st-pierre13.50 |
08-22-2019, 12:51 AM | #57 |
Rep 40
Drives: Alpine white, Coral red M235i
That is something I would really know the outcome of. looking forward to your thread
2014 M235i AW 8AT,
ER: FMIC & DP & CP , BMS: JB4 EWG(OBDII) |
08-22-2019, 06:43 AM | #58 |
DisplacementReplacement
409
Rep 1,100
What about the B58 pump that is mentioned on other forums? Surprised that hasn't been brought up here?
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
09-03-2019, 02:24 AM | #59 | |
Rep 221
Be careful with the lpfp to hpfp hose. Mine leaked and had to get it replaced with a custom hose. |
09-03-2019, 06:19 AM | #60 |
Rep 151
I got a good deal on it and was worried about the stock LPFP burning up to supply the HPFP efficiently. I値l keep the hose in mind. Thanks for the heads up! Figured if I was spending that much on the HPFP, might as well upgrade the LPFP. Better safe than sorry.
12-01-2019, 11:31 AM | #61 |
Dream crusher
984
Rep 2,421
Bringing this older thread back.
Couple of things: I've attempted to retro a M4 hpfp to my N55 around 2016-17. Total disaster. We had to swap out the alternator, new wiring harness for the alternator, new DME, re-pin the DME, problems with the fuel ekp. After all that we went back to stock due to never getting it to work right. Fast forward to now. Helix Overdrive! Have not purchased one yet due to it being so new to the market. Reached out to some who are using it on IG and so far they are reporting no problems. I'll most likely make the move if they are still good by early next year. Anyone here using the overdrive kit?
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
12-23-2019, 02:16 AM | #62 | |
Rep 31
