06-17-2014, 10:47 AM | #24 |
Rep 4,128
Drives: M235i & G30 540i
I remember reading a thread about this. Too bad it's not allowed in the US. I think the reason had something do with Government control. It's not sanctioned as yet in the US
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
06-17-2014, 10:51 AM | #25 |
1867
Rep 13,043
Drives: BMW M340I G20
Oh land of the free.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
06-17-2014, 08:31 PM | #26 |
Rep 185
It isn't allowed in the US because regulators have not been convinced the benefits (if any) outweigh the potential risks (e.g. blinding oncoming drivers). The major euro manufacturers are lobbying to allow it, but there is no word one way or the other. I expect that it will be allowed at some point, but wouldn't expect to see it before 2016 in the US.
If you order auto high beams in the US, you will see two vehicle chassis codes on the order sheet that disable the active high beams. They are 5AP (Decoding for no-dazzle high-beam assist) and 8S4 (Variable light decoding). The hardware and software coding is all there, but those two codes are what prevent it from working in the US. |
06-17-2014, 09:47 PM | #27 | |
Rep 244
06-19-2014, 02:37 AM | #29 |
1867
Rep 13,043
Yes you do. The button on the end of the turn signal stalk is a two part affair. Upper scrolls through the OBC menu and the lower activates the HBA. (high beam assist)
06-20-2014, 05:51 AM | #31 |
Rep 179
I have this feature (cdn car, i think this comes with the exec. pkg). Tried it last night by putting the lights on low beam and hitting the high beam assist. button. Works as adverised.
06-20-2014, 09:38 AM | #34 |
Rep 2,337
06-20-2014, 09:42 AM | #35 |
Rep 862
Drives: '19 M2 '21 X5
On my Canadian car I have the button but I think the no dazzle is coded. To be honest I have yet to drive my car on the highway at night and have never turned on the high beams in 2 months lol.
Two relevant codes on my car form MyBMW are: 08S4 Decoding, variable light distribution 05AC High-Beam Assistant Another one is German is: 05AP Dekodierung blendfr, fernlichtassistent Can anyone confirm non dazzle high beams working on a stock Canadian car with exec package? |
06-20-2014, 10:02 AM | #36 | |
Rep 1,115
06-23-2014, 01:16 AM | #37 |
Rep 5,262
06-23-2014, 01:19 AM | #38 | |
Rep 5,262
just remove 5AP and 8SA from your VO and code FLA and FEM_BODY module http://www.bimmerfest.com/forums/sho...4&postcount=53 (note: you will lose any previous coding of the FEM_BODY module and FLA, so you will have to re-code it again) damn it, i should have order the damn "high beam assist" $250 option |
06-23-2014, 01:41 PM | #40 |
Rep 5,262
Not sure what 3 pieces you talking but to summarize....
In europe if you get "high beam assistant" you also get the anti-glare high beam (will turn off one headlight individually if there is incoming traffic) and variable light distribution (will make a shadow tunnel so high beam is always on even with cars in front but your don't daze them) In the US if you get "high beam assistant" the high beams when you have incoming traffic go completely off... as anti-glare and variable light distribution is disabled... So you do need "high beam assist" which comes with an extra button on the left lever on the steering...and the cameras to make the system work did this answer your question? |
06-23-2014, 04:13 PM | #41 | |
Rep 5,262
and probably the lever on the steering wheel although you might be able to code it to always on and not need the different lever with the button... here is a DIY for the e9x model |
07-02-2014, 05:08 PM | #42 | |
Rep 349
07-02-2014, 05:24 PM | #43 |
Rep 5,262
Yes, you can re-code the variable light distribution by removing 8S4 from the VO and VO code the FEM_BODY....
or you can probably just FDL code the 2 settings too instead of VO code... This is what VLD does "Variable Light Distribution has several different modes of operation (for Low Beam): 1 - City Light: Shallow and Very Wide Beam Pattern active from 0 - 50kph (30MPH) (Both Headlamps are Panned outwards 12° horizontal from center and 0.7° lowered vertically) 2 - Standard Light: Same Basic Beam Pattern as with 8S4 Enabled and Headlamp Switch Set to Auto. Active from 50 - 110kph (30MPH - 68MPH) 3 - Guiding Fog Light - Shallow and Wider Beam Pattern Enabled with the Front Fog Lamps On and Headlamp Switch in Auto and Speed 0 - 110kph (Both headlamps are panned outwards 8° horizontal from center and lowered 0.7° vertically) 4 - Highway Light - Long Throw Pattern illuminating approx. 25% further than Standard Light. Active from 110 to 250kph (68MPH- 155MHP). (Driver's Side Headlamp is panned 3.5° outwards Horizontal from center and lowered 0.25° vertically, while the passenger side headlamp is raised 0.2° vertical)" take a look at the cheat sheet thread in the DIY coding subforum... http://www.2addicts.com/forums/showt...=997749&page=4 |
07-18-2014, 02:59 AM | #44 | |
Rep 176
