10-17-2014, 12:56 PM | #1 |
Rep 81
Need some guidance/thoughts on 228 package options
Hello fellas,
I'm proudly a new MT, 228i owner (financing approval in process) as of yesterday. I apologize in advance for my long thread, but please bear with me. To give you some background, I live in Canada, and I initially had my heart set on the M235i. I test drove it fully equipped (all 3 packages, executive, premium and bmw connect) and it was amazing. However, after working out the numbers, it was outside of my budget and decided the 228i was more reasonable. Here's my dilemna: My initial thought was to get (keep in mind, this is Canada options): - M sport line - Premium Package Enhanced Which is what I've ordered. However, after looking at the other packages, I'm wondering: - Are the any of the additional packages worth having? Executive Package ($2200) BMW Connect ($500) M Performance Package ($1200) - Adaptive M Suspension and Variable Sport Steering M Track Package ($1200) - M Sport Brake and High Speed Max. with performance tires. Right now, I'm leaning towards adding Executive and BMW Connect which would up my bi-weekly by about $15 and foregoing the M Performance and M Track packages. Reason being that I'm already getting the M sport suspension, and I've heard that the adaptive suspension makes it difficult to do custom suspension work after, and I don't really think I need the rest. Thoughts? The dealership has indicated that there is only one 228 left for the november manufacturing timeframe for a different dealer and they want to buy this car from other dealership, then change the configuration to what I want before starting manufacturing. The order has not been placed yet, so I'm hoping to get some insight as soon as possible. Thanks in advance! |
10-17-2014, 09:11 PM | #2 |
Rep 1,178
Not sure if you've driven the 228 with both the mt and the auto, but personally I think the 4 cylinder needs the auto gearbox. This coming from a guy that drives manuals exclusively. The mt just doesn't pair as well with the 4 cylinder engine.
10-17-2014, 10:12 PM | #3 | |
Rep 6,026
To the OP, the Canadian option plan certainly does seem different than in the U.S. Here, we have a "Track Package" (no "M" in the name), which has four elements: 1) MSport brakes (blue calipers), 2)MAdaptive suspension, 3) Variable Sport Steering, and 4) Michelin PSS non-RFT. This is a wonderful package, although it seems it was broken apart into two packages for you. Here the Track Package is $1600 if on a Sportline, $2200 on a base car. This is a very high priority collection of content for driving entertainment, as well as providing comfort in those situations where the particular passengers or road conditions don't lend themselves to the full Sport calibration. Also, the steering is much improved over the base, and what is not to like about the PSS and MSport brakes?? We don't have an "Executive" package, so I can't be sure if it's similar or not to our "Premium", but those kinds of add-ons are fairly self-explanatory and easier to discern the value of having. |
10-17-2014, 10:25 PM | #4 | |
Rep 24
10-17-2014, 10:53 PM | #5 | |
Rep 1,178
Wife has the N26 with the ZF auto in her X1 so I have lots of time behind the wheel with that set up, granted in a much heavier vehicle. The N26 in her car just feels better and more urgent than the N26 in the 228i I drove. Maybe there was something wrong with the car I test drove, but the engine felt kind of flat. Under heavy acceleration it did not have nearly the get up and go that I expected. I'm well aware of the performance numbers that the 228 has been putting down, but the car just didn't feel at all fast. As for the transmission, I also had hoped that it would be a step up from what i'm used to in my 335. The throws were still typical BMW long, with a slightly rubbery feel. I'm not saying the 228/6 spd combo is bad, what i'm saying is the great ZF 8 spd auto does a significantly better job of extracting all of the power from the N26. Enough so, that even though I am a die hard mt fan, in this case the engine benefits so much from the auto that its worth compromising the added fun factor of the manual. |
10-18-2014, 12:14 AM | #6 |
Rep 272
I only was able to test drive 228i auto before but I ordered the manual one and I can tell you the 6MT is not much slower (if any).
Even BMW's spec has it only 0.1 second slower with manual on 228i while on M235i it is 0.2 slower so it would seem the smaller engine is a better match with the 6MT. |
10-18-2014, 05:50 AM | #7 | |
Rep 809
Drives: 2014 228i Msport
A peasant and proud of it
Save The Manuals!!! |
10-18-2014, 08:58 AM | #8 |
Rep 6,026
[QUOTE=jeremicium;16798006]
Maybe there was something wrong with the car I test drove, but the engine felt kind of flat. Under heavy acceleration it did not have nearly the get up and go that I expected. I'm well aware of the performance numbers that the 228 has been putting down, but the car just didn't feel at all fast. As for the transmission, I also had hoped that it would be a step up from what i'm used to in my 335. The throws were still typical BMW long, with a slightly rubbery feel. /QUOTE] No disrespect taken....I didn't build it, just bought it! What you are describing does not sound like a manual vs. automatic issue to me. Unless you are suggesting the gearing is not low enough in 1st, once the clutch is disengaged, a mechanical coupling is about as direct a transmission of power as it gets. It almost sounds like you drove the 2 6MT on "comfort" vs "sport" settings, or worse yet....Eco! The way you described your experience is exactly the difference between the engine mapping which goes with each setting. As for the feel of the stick, perhaps there is variation or the 2015 was improved over 2014 but I have a very different experience. Yes, it's no Miata stick but if you want long throws, find a W204 2007-2012 C Class! The 2 is feeling pretty good to me....I guess it all depends on your personal baseline calibration. |
10-18-2014, 12:23 PM | #9 | ||
Rep 1,178
[QUOTE=Sportstick;16799005] Quote:
With regards to the gearbox itself, like i mentioned above maybe i'm a bit ruined by the S2000 garage queen, and by the fact that I was expecting a big improvement over my 3 series. It wasn't worse than the 3, just not really any better. |
