2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Highway Robbery in BMW Seattle
      06-02-2019, 08:12 PM   #89
krhodes1
Drives: 2011 328i Wagon
2011 128i  [10.00]
2011 BMW 328i Touring  [10.00]
Originally Posted by USA-RET View Post
One reason to consider leasing or trading before warranty expires. All the Euro cars are expensive to maintain.
Initial depreciation is FAR more expensive than maintenance and repairs, even at silly dealer prices.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option
'11 128i Convertible - Space Gray on Savannah Beige, 6spd manual,
also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire
      06-07-2019, 09:40 PM   #90
DrivingPassion
DrivingPassion's Avatar
Drives: '15 M235xi
UPDATE: rotors retaining screw
- Broken Retaining Screw on rotor is finally drilled thru but cannot get the original remnant out. Used a tapering wrench and re-cut the tread and was able to screw in the new screw.
- new rotor installed.
- Worked on next front wheel rotor. Guess what? One of wheel bolts was stripped by the ImpactTool.
Guess I don't have a lot of luck with this car.
I'm going to take it in to the independent mechanic and get them to do:
- brake system flush
- replace that rotor
- align the wheels
2015 M235i xDrive 8AT
      06-07-2019, 10:35 PM   #91
dradernh
dradernh's Avatar
4415
Drives: 2017 M240i
Sorry to hear after all that's already happened that you ran into this glitch, too.
While I have a cordless impact gun and a high-quality regulator for use with a gas bottle, I've gone back to using these tools for installing and removing lug nuts:
      06-07-2019, 10:54 PM   #92
aerobod
aerobod's Avatar
3626
If the wheel bolt thread is damaged, I would have the hub inspected for thread damage and replaced if any is found.
      06-07-2019, 11:11 PM   #93
DrivingPassion
Drives: '15 M235xi
Thanks for the suggestions.
      06-07-2019, 11:13 PM   #94
DrivingPassion
Drives: '15 M235xi
No, the thread is fine.
It's the head of the nut that got stripped by the high power ImpactTool.
Perhaps, the lug nuts are already old.
I just ordered 15 to replace some of the worn out ones.
      06-09-2019, 09:39 PM   #95
DrivingPassion
Drives: '15 M235xi
Thanks to the Irwin Bolt Extractor (Bolt-grip), I got the sucker out!
And, replaced the left front rotors.
Of course, the car just wanted to be fair with me so the retaining screw for the old rotor was also stuck and I had to drill it out.
      06-09-2019, 09:41 PM   #96
DrivingPassion
Drives: '15 M235xi
What a journey .... screws and bolts can get stuck and break.
Bolt extractor carbon steel drill bits can also break.
Just had to be patient and keep plodding along.
Also, if you are using an ImpactDriver to remove and tighten wheel lug nuts, do invest a torque-limiting stick to reduce the torque.
