05-05-2019, 10:42 AM | #23 |
Rep 448
05-05-2019, 10:53 AM | #24 |
Rep 5,577
Can you soak bleeder screw valves in PB Blaster to try to break loose the bleeders w/o snapping them ?
I'm not sure you want PB Blaster to soak onto brake lines. |
05-05-2019, 02:06 PM | #25 | ||
Rep 5,262
Maybe they are including cost for machining the rotors but I don't think bmw allows it. They usually just replace them or keep them as is |
05-05-2019, 03:50 PM | #27 | ||
Rep 3,497
My 2˘ regarding dealer shop pricing practices... The principal thing to remember with any labor quote from a dealer is that the service department is using the Flat Rate Manual (aka Flat Rate Guide, Flat Rate Book). These documents are created by each manufacturer for each of their models, and it establishes the number of hours required to complete each job in the shop. IMHO, the times in that book tend to be on the high side – it frequently works out to hundreds of dollars per hour, regardless of the shop’s stated hourly rate for labor. Brake jobs are a classic example: typically, they're in the book as a 6-8 hour job, and it might take that long to do the job if the brakes are a rusty mess. Mind you, this job includes changing the rotors and the brake pads, inspecting the calipers, the caliper pistons, and the brake lines, and either bleeding or flushing the brake fluid. This job can sometimes take even longer than the book says; in that case, the dealer will still only charge you what the book says the job should take. However, I'd suggest that the typical brake job takes around 2-3 hours, and whole lot less in many cases. For example, if the system is clean and the parts come apart without any extra work on the part of the technician, he or she will get the job done fairly quickly. I don’t know if the following practice is widespread or not (I assume it is): some years ago a couple of Northeast shop owners told me that dealership technicians get a percentage of the cost of a job. I never asked if that applied to both labor and parts, or just labor, but my guess is both. One shop owner told me he’d lost his best mechanic to a dealership because, even though the work was going to be more boring, he could make quite a lot more money working for a dealership. This helps to explain why replacing parts is generally the conversation when you’re talking to a dealership service representative. Dealership technicians function as parts replacement specialists – they’re not mechanics in the traditional sense of the word. The end result is that sometimes that can mean a dealer representative saying you need a new caliper instead of them dealing with a seized bleeder screw in the way a traditional mechanic would – something that would make a lot more financial sense for the owner. All of this leads to the question I always ask: why do owners go to the dealer when it’s not necessary? By not necessary, I mean: the car is no longer under warranty, the inspection or repair can be reliably carried out by a capable independent without affecting the owner’s warranty, it’s not a recall issue, etc. That is, there are other shops that are able to perform the work that dealers’ shops do, that don’t replace parts when they don’t have to, and that (usually) have noticeably lower hourly rates than the local dealers – so why pay more by using the dealer’s shop? Note that independents will be using the Flat Rate Guide, too. And yes, some will permit you to bring your own parts; the ones I’ve used that allowed me to do that increased their hourly rate to offset their loss of income from using the parts I supplied. With those shops, I did the math to see which made more sense for me. I’m an old guy who’s been dealing with experienced mechanics for fifty years, and for me today’s dealership shop experience can be like traveling to Bizarro World. At the sort of independent shop I prefer, I can talk to anyone in the shop, from the owner to the fellow doing the least of the jobs. They are personable people, into cars, and they enjoy discussing my needs and my options. I won’t use a shop that won’t let me observe the work being done. It’s not that I wish to look over the mechanic’s shoulder while suggesting better ways for him to do his job; instead, I want to learn more about my vehicle and how to properly take care of it. Generally, however, I don’t hang out in the shop – I’m in there only when there’s something new or interesting going on. None of this is to say that I don’t understand why dealers are operating the way they do. For example, compared to independents, dealers have tremendous overhead, including that imposed upon them by manufacturers (e.g., every decade or so, outfits like BMW decide on a new marketing approach, and enforced changes like those can result in millions of dollars of expense for the dealership owner). Along with the used car lot, the shop bays are where dealers make most of the money they need to stay in business and prosper. That’s fine, but I’m unwilling to support that model any more than is necessary; that includes my BMW, as well as the wife’s Mazda 3 and my Toyota Tundra. Some members may have better or more current information than I've offered above - I welcome any and all corrections, improvements, etc. /end dissertation Regarding the seized bleed screw: assuming the caliper bleed screw threads become damaged during bleed screw removal, this link will take you to a number of pages & videos showing how you avoid buying a new caliper as a result: https://www.google.com/search?as_q="...er+bleed+screw. I don’t imagine there are many (any?) dealers willing to heli-coil a caliper bleed screw (even assuming they knew it could be done), but a capable independent shop should be able to do it. OTOH, the dealer would almost certainly void your warranty on the caliper. For me, I’d say “So what, you were already going to charge me for a new caliper.”. Of course, YMMV. In summary, I (obviously) suggest finding a good independent. There are various resources for finding one, including this forum. I’ve used shops operating under the BIMRS.org umbrella and found them to be suitable for my needs; more here, https://www.bimrs.org/. BIMRS.org members are focused on keeping up with the complexity of our modern cars, including access to current BMW factory technical information. Quote:
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 05-05-2019 at 04:02 PM.. |
05-05-2019, 04:46 PM | #28 |
Rep 485
Thank you, dradernh, for the effort in helping me to understand and being encouraging. Yes, your explanations made absolute sense about dealerships.
2015 M235i xDrive 8AT
05-05-2019, 05:16 PM | #29 | |
Rep 860
Gary
Current: 2020 F87 LBB|Exec|DCT|slicktop Other: 2017 F15 35i,|MPPK, 2012 F25 28i Past: 2008 E92tt 6MT, 2001 E46 6MT 2009 Z06 1997 Camaro SS 6MT |
05-05-2019, 05:39 PM | #30 |
Rep 1,264
try...
...www.bimrs,org to find a reputable indie shop. I would try soaking the bleeder with Kano Aeroquil or similar penetrating oil. Overnight soak is best. Then use a deep 6-point socket to break them loose.
BM235iW97.00 |
05-05-2019, 05:58 PM | #31 | |
Rep 5,577
Unicorn123186.50 |
05-05-2019, 06:44 PM | #32 | |||
Arsevader
36
Rep 128
As the bleeders are exposed you can use a box wrench which will grip each side of the bleeder. |
05-05-2019, 06:49 PM | #33 |
Rep 485
I looked up a couple of videos and it does not sound that difficult.
The only hairy parts is the metal clip that is hugging them and the brake pad sensor. I did not see any adjustments or calibration needed. Do you guys have any recommended best videos or instructions to do this?
05-05-2019, 06:56 PM | #34 | |
Rep 5,577
Lifting the car needs good stable equipment. Pressing in piston, opening up brake reservoir and maybe sucking out old fluid and putting in topping off with fresh fluid. https://www.2addicts.com/forums/show....php?t=1587779 |
05-05-2019, 07:39 PM | #36 |
Rep 213
My dealer charged 282.40 for an oil change, brake fluid flush, and coolant change.
My Michelin PSS lasted 32k miles, which included 3 track days and one night at the local 1/8 mile strip. At 47k miles I'm still on the original pads.
2014 M235i
2015 X1 xDrive28i M Sport 2009 Cooper Clubman 1999 Wrangler Sahara 1995 318ti Club Sport |
05-05-2019, 07:43 PM | #37 |
Rep 213
Tell me about it; I'm on my second Chapter 7.
2014 M235i
Unicorn123186.50 |
05-05-2019, 08:53 PM | #38 | |
Rep 407
05-05-2019, 10:20 PM | #40 | |
Rep 225
My 235 was just in for brakes as part of service. So I brought in a set of pads for them to use instead of the BMW pads. SA said that it would be an extra hour they would have to charge me for. Couldn't believe it. They were just going by what was in the computer system. So I declined and just swapped the pads when I got home. Took about an hour total. The BMW SAs are also on commission - at least my preferred dealer. It is in their best interest to sell you more services. The alignment thing I just got offered on my 340 that has 17000 miles. Apparently this is recommended every 15k? Just crazy. Best thing to do is DIY or find a good indy. Another option might be to negotiate with the dealer. There is one in my area that would do that when I balked at some pricing - not sure how common it is. If they don't budge just take it somewhere else.
18 340i F30 mostly stock |
05-05-2019, 10:50 PM | #41 |
Rep 294
Drives: 2019 M240i Coupe RWD
05-05-2019, 11:24 PM | #42 | |
Rep 5,577
Though, my rear sensor had crud and webs in its junctions so it was worth for me to get in there and clean things out after 35,000 when installing new sensor. |
05-06-2019, 08:51 AM | #43 |
Rep 255
drader,
Excellent summary. E-Type V-12 huh? I always wanted one of those but never had the gumption to take one on... Passion, Looks like you have gotten a great deal of sound advise from the Team here on the forum. Good luck!
Current Fleet, 16 F22 M235i xDrive, 15 Audi Q5 3.0 TDI (my Wife's), 07 E85 Z4M Roadster, 01 Toyota Tundra 2wd Long Bed
Retired (a few of them...), 08 E60 550i 6M, 01 Audi S4, 70 Fiat 124, 88 E28 M5, 72 Datsun 510 2Dr, 73 TR6 |
05-06-2019, 10:02 AM | #44 |
Rep 485
Yes, indeed, you guys have been of great help. I totally appreciate it a lot.
On another front, another independent BMW shop came back with this quote: “ I would need the last 7 of your VIN number to get an accurate quote. Brake replacement required pads, rotors, and sensor. Typically replacement of brakes runs around $800-1000 per axle. Wheel alignment is $175 and brake flush runs between $155-205 depending if you have the M sport calipers. “ |
